Everything posted by nipper
Temp runs high in traffic
nipper replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour raditor is either clogged or the cooling fins have fallen apart. Powerflush is a waist of money and can cause other problems. nipper
How does the AWD work?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReverse and first, along with WOT force a 50/50 split. It takes a split second for the hydraulics to react. Your car is fine. nipper
Who owes me a beer
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope no story, just someone that i heelped with a problem that lived out here...
Who owes me a beer
Well im in Portland, heaqd gaskets and all . Only problem is a loose wiper arm and that dam buzzy heat sheild again. Car is nice and dirty from playing in Mount Hood Nat forest... so where is my beer
awd,ecu,wheel locking?
nipper replied to billyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPart time four wheel drive does not have a center differential (the old dual ranges) nor a visous coupling. Basic 4wd systems dont have this either. The front wheels turn at a differnt speed then the rears on curves (even slight ones). SInce thetwo axles are mechanically attached to each other, there is no way for the "wind up" of the driveshafts to be avoided. IN the rain The fatser the car is traveling, the more faster windup will build up. THere will come a point where one of the wheels will spin faster then the other three, depending upon which one looses traction for an instant. This can result in a loss of control. This warning about driving over 5o applies to all vehicals with a simple 2 speed transfer case and part time 4wd. nipper
How did subaru increas the ground clearance on the new outbacks
nipper replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a membership nipper
AT tranny whine -- normal?
nipper replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts just a coincidence that it is at higher altitude. The dleay to reverse and the whine are both symptons of a bad front pump. This is not a good thing nipper
nipper replied to billyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnever buy cars from this man, he doesnt understand the differnce between AWD and part time 4wd. ANything one sees on the track is not considered nomral useage or driving. On the highway i have heard about it but it is with part time 4wd. In this litagous society, if this ever happened for real, subaru would be out of business. How one can seeanything happen, then establish a cause and effect from witnessing it without an analysis and some engineering background, does not know what he is talking about. AWD has been used in eurpo for years on the autobahn (where 140 mph is not unusual). Subarus have sold for YEARS and regularly driven over 70 mph in the rain. Say, i have a bridge to sell too if your freind is interested . nipper
nipper replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXor email subaru and ask them?
HELP: 2000 legacy/outback side mirror question
nipper replied to melisslissliss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've done the same thing. Go to a windsheild place they can do it. nipper
nipper replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall they have to do is move the lowest part of the car up to gain clearance. There are many ways to do it, some very subtle, some not. BY moving cross members, raising the rear diff, the exhaust system, lengthing drive shafts, tire size, it all adds up fast. nipper
90 Legacy won't start. Any ideas?
nipper replied to 90sub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXover heat, no oil, bet now it has no compression, i hate to say DOA so qucikly, but it sounds like itto me. SUbarus can take a lot of abuse, but very low oil and an over heat, i dont hold out hope. You can try a new coolant temp sensor, but i dont hold out a lot of hope. nipper
yorque converter price
nipper replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStep one, remove engine ... (or remove tranny) i havent priced one in ages. Google it. nipper
Tranny Problem in 2000 Forester? (M/T)
nipper replied to LameRandomName's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have but in a nissan. When it happened to me the linkage just popped off. This may not be a big deal. nipper
Salvage yard 5MT has torque bind
nipper replied to jjou812's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot much you can do on a manual. If it has TB the VC is shot. You can swap the VC units if you want from the old one. nipper
Vibration after axle shaft installed
nipper replied to MountainBiker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchange the axle. It shouldnt have any effect froim the lift. i bet the axle is bad or the worng one. Easy way to find out is jack up the car, turn the wheel to lock, and rotate the tire by hand and see if you can feel resistance. If the issue wasnt there with the old axle it shouldnt be there with the new one. Where did this "new" axle come from? nipper
Replacing stock stereo in 05-06 Legacy
nipper replied to aboone1970's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWOHOOO as that was a huge complaint nipper
Best place to run wires through firewall?
nipper replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi used the gromit where that cable passes through. i poked a hole in it, then sealed it with black silicon. i can take a pic and post it if you want .. though i dont know how in h*** one gets those big pics posted nipper
speakers for 98 legacy
nipper replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi bought them from ebay, OE speakers. Jamie has them also, Someone will supply the link for her.
Warranty question
nipper replied to 2005outback4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get the maint done anywhere, just keep the receipt. nipper
Engine Overheating
nipper replied to rgibson4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXill be in portland in a few days
AWD Legacy transmission (slipping & stiff) baffled
nipper replied to docrw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbad bad bad thing to do on ANY auto tranny car pre 1969. You have just been lucky, but i bet even those you did some internal damage to, just it never showed up. Every mfg tells you NOT to do this. nipper
Boiling Coolant 2.5l fresh headgaskets Help!
nipper replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe water an oil fumes would to make the white mix nipper
Ridiculously high mileage on one engine, with no head gasket change
nipper replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasy because there are a large percentage of people here with 2.5 with high mileage on them that have not blown HGs. SO you always drive with something that is going to make a huge pile of waste no one wants after 20 years? Just because some people have had HG issues (and yes 15% qualifies as some) doesnt mean they are bad engines. Any engine will blow a HG if it is not maintaned right, allowed to have air bubbles in the coling system, or gets old enough. Over 140,000 miles the odds of blowing one increases on all engines. THe aluminum block and head with a metal alloy gasket with differnt expansion rates determine this. In reality as subarus age, they are less likely to blow HG as opposed to hindas, toyotas or american engines (and at that point the american cars arent worth owning anyway). If we apply the same theopry to the subaru TB and awd units, then that is crap to since they do wear out for a number of reason, and this board shouldnt exist for such a poorly made car. ill take a dohc 2.5L anyday. i'm going to bow out of this thread since its pointless, and go back to beating blu up on dirt roads of wyoming nipper
high speed braking shimmy
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour not coming NEAR Blu with a hammer ..... nipper
