Everything posted by nipper
Clutch shudder problems...
nipper replied to MaximusGradient's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmake sure they put in a SUBARU clutch kit and not an aftermarket one. The aftermarket ones can cause this. nipper
Gas Gauge Fluctuates A LOT
nipper replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine got soaked with oil when the engine blew. But in retrospect, it was giving out signs it was going. My aftermarket self diming mirror was flaking out. I couldnt figure out why. Once the alt was replaced it stoped doing it. At the dealer they said there was a lot of noise in the altenator (which they said drive it and the oil will burn off). That noise was the brushes being shot. So i am convinced it was just time at 198,000 miles. Thats a respectable number nipper
nipper replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXodd no one has suggested the 10.00 techron fuel additive that cleans fuel gauges. ALso check the wires at the gauge and the voltage, to make sure you dont have some other electrical problem. WHen my alt went bad, it first showed up in a weird fuel gauge reading. nipper
AT oil Temp light
nipper replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bulb is burned out, just replace the bulb. nipper
Engine Volume ?'99 Forester
nipper replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy brand new subaru 2.5L roars when you get on it, otherwise i cant tell its running most times. When does this roar noise or loudness happen? nipper
99 OBW, tranny click and jerk into 3rd
nipper replied to MiniTransAm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the cause may be some mechanical damage inside the tranny. These are hard shifting but well behaved transmissions. LOnger shifts when cold is normal. The rattle can be a heat sheild, but the clunk has me concerned. you may need to take it to a shop to have it diagnosed. nipper
I'm home...
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXooooooooo .. but i did notice the car felt more twitchuer , that explains it ... nipper
I'm home...
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtechnically one engine (HUGE hole in the side of the crancase where the engine temp sensor for the ecu is) and one altenator (explains why my little black boxes were angry at me) But even after payinhg a premium for the engine, it uses zero oil in 300 miles, no leaks, plenty of power, cruise control is much happier, transmission doesnt hunt anymore, and six 1000.00 payments is far cheaper then 300 a month for 60 months (or whatever 30,000.00 over 5 years is). I basically told them if i am going to do an engine, i don't want to open that hood for anything besides fluid changes for 8 years, make it happen. I had an 06 Outback for nine days. I liked mu 1997 better. It seemed more responsive (dual cams) and there was not a single thing in the new car that made it better then mine. In fact the awd seemed very FWD biased. When i took it mountain climbing the front wheels would throw rocks before the rear wheels hooked up with a learch. My 1997 (new AWD unit) feels seemless. ALso the inside of my 1997 feels bigger then the 2006. Gas mileage was the same. The 2006 had a really high and hard brake pedal. I will say that the cruise control is still to aggressive, and downshifts too far when a squeeze of the gas would suffice. Thats actually when my engine blew, the cruise decided to stomp on the gas, shifted down too far and BOOM. That and the previous owners habit of chainging the oil once a year weather it needed it or not didnt help. nipper
steering effort changes
nipper replied to mrCharlie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy gut feeling is the rack is tired. If its really stiff on a cold morning, then its the rack. nipper
Taking Bets on sensor- TPS, O2, Temp or ?
nipper replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX.25 cents on the IAC motor nipper
Vents make banging? :(
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have a bad mode door motor, its cycling constantly and needs to be changed. nipper
200 lbs on each cyl on '01 2.2L= healthy?
nipper replied to JM1NA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rule of compression tests is not so much the actual nymbers, but the difference between the cylinders. 200 lbs is high. A compression test needs to be done with all the plugs out at once and both wet and dry, with the throttle wide open. Actually better off with a clean engine, since you can see all the leaks, a dirty one can hide them. nipper
1999 Forester auto transmission fault
nipper replied to puritan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOOOOOOOOOoooooooooooooooooooooooo one of THOSE.... *hides the hand tools* nipper
nipper replied to puritan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCant now since you didnt let us tell you how to test it. Gut feeling there is nothing wrong with the torque converter. nipper
nipper replied to puritan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEr....... um .... boy i dont pay attention to this board for a day and someone gets into all sorts of mischief. I think this is the first i've seen somone pull a slushbox apart. i hope your keeping really really good track of things. An autobox is not for the timid to pull apart. There are rebuild kits that you can get, but usually one tries to secure the kit first when doing it themselves. There were a few steps that were skipped here, like a proer diagnostics. If we could time the delay, we could have gotten a better idea where the problems was, along with a few other diagnostic steps. The pump has to be measured with a feeler gauge for wear, and i dont know what the specs are. You really cant always tell things by looking at them, you need more diagnostics to know where to look. Its possible that you may still have the problem or worse, since this seems a little extreeme, nipper
I'm home...
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbut the headgaskets were still good .... nipper
I'm home...
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX5 weeks 9,000 miles isnt enough? nipper
I'm home...
Well Blue and I are home. New engine hasnt used a drop of oil in 3000 miles. Blu will get an oil change this week. Now one more problem, im just too tired to fiddle with it, but i think i need a battery, the one in the car is of undetermined age. 1997 OBW 198000/3000 miles The car fires right up, but the battery voltage is low (11.8) right after start, and doesnt build back up for a block or two (which really angers the black boxes in the car). When the car runs, the new alt puts out 13.5-14 volts, even with a full load. Since the car was run down to nothing once on the trip, and the battery was showing signs of wear, I am guessing its time for a new battery. I was thinking there may be a slow draw on the battery overnight, but the car cranks too well in the morning, so i dont think thats it. Oddly i noticed if the ABS light and brake light comes on, it means a bad alt, if the battery light and brake light comes on, its a low battery. Go Figure. nipper
10,000 miles later and I am getting that oh sooooo sweet smell...
nipper replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits a rental, i already took it on logging roads, im not about to care that much about it nipper
auto trans additives??
nipper replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the fluid is red and clean, you may have a seal thats is going bad. Have you tried manually shifting the tranny to see what happens. This would tell you if its a mechanical or electrical problem nipper
Shopping for a clutch
nipper replied to ctoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlighter flywheel is only for faster revving engine, not for your problem. How is the hydraulic clutch parts nipper
nipper replied to puritan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeventually. If it takes more then one second to engage you have a tired front pump and seal. 2nd gear which is used for reverse doesnt need as much volume of oil to engage, so it will not be as bad. How long to go from reverse to drive nipper
Putting '96 Legacy L seats in a 2k Forester
nipper replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey may be differnt, since they are differnt cars with differnt crash test results and charecteristics. nipper
Cruise control
nipper replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits not a simple system, but it is very robust. It can be a failed relay, bad brake and or clutch switch bad speed control unit. nipper
Speedometer has never been right on 99OBW
nipper replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXboth my scan gauge and GPS read a differnce, the gps about 4-5 mph, the scaqn gauge 5-6 mph. This is one of those things that go under so what. Depending upon tire inflation and wear this is not unusual. Also the spedos are sometimes calibrated on the safe (low) side. nipper
