25
Everything posted by nipper
\\\ Why not stick it in the back like all the Vanagons do? nipper
OK a few questions, has the raditor cap been replaced. has the cooling system been checked for trapped air. Next is not to do a pressure leakdown test, but to check for exhaust gasses. ALso remove and inspect the raditor to make sure all the cooling fins are in place, it is a little early to need a raditor but you never know. Check the raditor for flow too. nipper
http://en.wikipedia.org/wiki/Engine http://en.wikipedia.org/wiki/Motor_car http://en.wikipedia.org/wiki/Motor_vehicle Also back in the day the electric motor was far more popular then the engine. The car as a whole is a motor vehical, the engine by itself is till an engine. It's just an engineering quibble, but a motor is electric, an engine is mechanical. so ttthhhppprrrrttttttt nipper
I have one and i dont like it. The oil and oil temp sending units are oe, and the pressure sender (which is huge), from the JDM wire length tells me it mounts on an oil galley some place on top of the engine. The temp sensor looks like it mounts an something adapter like. I bought one off ebay, and oddly the fitting for the oil filter does not match OE. It has me very annoyed. Thats why I would rather use galley plugs
the stock sender is just a switch. I actually have a JDM factory oil pressure gauge, but cant fin out where to screw it in. Can somone show me the oil galley plugs and thier location? Last time i put in a gague on a car, i just teed off the oil press switch port and put them on either side of the T. If space is tight you can bend some SS line and locate them someplace else on the engine. nipper
When you put the FWD fuse in, it disables the rear wheels (the clutch pack). So the front wheels spinning is normal (meaning GET OFF THE GAS). The tires will spin if they loose traction for some reason. the FWD light should be on. I dont really understand what your saying... try explaining it again. Also you dont mention if the thump went away, im betting you have torque bind since its obvious the Duty C solenoid (which is energized when you put the fuse in ) is working properly. Do your tires match, are they all inflated properly? Have you driven on a flat or spare recently? SOUnds to me the FWD fuse is behaving normally. nipper
