25
Everything posted by nipper
starting a full time business NEED your inputs and ideas
nipper replied to sube101's topic in Products for your Subaru
http://www.ultimatesubaru.org/forum/showthread.php?t=119224 one of these! -
Very easy. Remove over flow clean it, reinstall it and fill to full line. Remove cap. Start car. SLOWLY add coolant Stop when full, wait for the t-sta to opne. (you will see a surge out the filler neck) Resume slowly filling system. Replace cap. Drive car around block. Allow car to cool off. Check coolant level Repeat (once if needed) and that should do it. This is the proper method for all cars.
Bad battery cable is another possability
Except he said he is hearing a solenoid click when he turns the key. At least thats what i thought he said
have the original one?
Exactly how are these passing testing, what are those tests.
Have you tried hitting the starter? What is the voltage reading at the solenoid wire (disconnected of course). I am wondering if you have a tired iggy switch assuming the starters are not stuck somehow.
Try Neutral (amuse me). To me this sounds like a bad starter....or... You did the jump test, now try clamping a jumper to the engine block and the other side to the negative terminal
Does the starter motor spin and the engine not turn over or does it just sit there and look at you funny?
Bled the brakes three times... still no pressure.
nipper replied to thebr0wn0ne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Suggestion, the car is old enough anyway, think about replacing the MC. Also i gravity bled both my justy and outback. I didnt need anything really aside from a hose. I just opened up the bleeder and let our evil overlord Physics take over. Went faster then I thought it would, and on both cars i Replaced calipers. -
What he said, thats my vote. -
Woo slow down before you make a very expensive mistake. i do not know what you are installing this in, but subaru uses a lighting controller, which breaks the lighting into zones. The lighting does not go to ground, but goes back to the controller. Modern cars generally use this same kind of system. You wirit wrong you kill your dash lights and have to replace a black box (which is 100.00 new in a sooby).
Can also be a bad cable.
sweet little car, i love these cars
Welcome to the site,
