Everything posted by nipper
Setting the Toe-in
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is EXACTLY my problem! AMEN someone who has been there and done that
Setting the Toe-in
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah i thought i had it all measured and was so happy when it finally went on. All the fighting with the double joint i moved the steering wheel grrrr even though i had it tied down.
Setting the Toe-in
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice thing about toe, can try it at home, screw it up or can't do it, drive it to the alignment shop. Now who wants to come over and help m out with the steering joint
Hard downshift into 1st gear 06 Tribeca, 5EAT
nipper replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would try Trans-X also.
nipper replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't it have premium recomended, There is only one way to find out, put a few tanks of premium in and see what happens.
Setting the Toe-in
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI already decided to take the Justy camping this weekend, and leave Blu at home. I was really really hoping someone would take pity on me about the sterring wheel. i need to find an extra pair of hands some place. With a double universal it is hard to judge. On the plus side i did not know that double joint was seized and i solved that issue. So jack stands come back out on monday. Geometry ewwwwww still need the spec i know it is here someplace
Setting the Toe-in
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just put in a used steering rack, so it is out. Aslo (mumblemumblemumble) i was off a tooth or two on the steering shaft so the wheel is off more then 90 degrees. sob. Really hoping i dont have to redo that as it is a pita with a lift kit.
nipper replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have any flashing lights on startup? Have you tried synthetic ATF? Subarus tend to be hard shifters with the 1-2. Mine comes and goes. Sometimes running an extra ground helps. There really arent any real complaints on this transmission aside fomr hard shifts when cold.
Setting the Toe-in
Since Toe is a three letter word, it is almost unsearchable. i saw someplace how to set your toe-in with a tap measure and the spec, but i can not find it. Anyone know the process or the thread? Thanks
School me on SVX engine
It will not fit without modification. The SVX 6 is a large long engine. Everything will bolt up, but you would have to relocate the radiator and supports i think. it is also a lot heavier. http://forums.nasioc.com/forums/showthread.php?t=148934
damage from unequal tread?
nipper replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually that was on topic, but i love how it was before they invented the driveshaft tunnel.
nipper replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot really, that one wheel example only applies if you get stuck or loose traction.. On dry ground you have 2wd and 4wd respectivly. A differential is a mechanical computer. It divieds the power between two spinning wheels http://www.howstuffworks.com/differential.htm Simplistically.. if the car goes straight, 4 turns of the drive shaft (1:1 final drive for math sake) will result in 4 turns of the wheels. Making a hard turn the outside wheel turns faster, the inner wheel turns slower, so one wheel will turn six times, one wheel 2 times, with the same 4 turn input. If traction is lost, then one wheel will turn no times, the spinng wheel will turn 8 times the drivshaft 4 times. This is why you never (on a 2wd open diff) never take a wheel faster then 30 mph because on that one wheel it would be 60. If both wheels are off the ground they may even spin in differnt directions.
Gauge Cluster Bulbs
They use colored reflections which makes for no loss of light, where colored bulbs do loos some light power (lums)
90 Legacy, Shifting issues.
nipper replied to Goobysoobs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou answered your own question sort of. The bushings in your shifter linkage are shot, an easy fix.
Gauge Cluster Bulbs
The color is not on the blubls, but the back paint behind the gauges. http://forums.nasioc.com/forums/showthread.php?t=690378 I know it is a newer gauge set, but this is how it is done.
Engine Knock?.... Oh Crap! The End Of Murphy???
You have an intermittent fault. Next time the CEL happens do whatever you have to to read the code.
- EA82 Dashboard BackLights Upgrade to H.I.D. White L.E.D.´s
nipper replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIN an emergency. you can get away with 2 tires, both on the same side of the car. This is ONLY if you do not have a VC in the rear diff. This is why i carry a full sized spare. I have it in my tire rotation. VC give no warning anything is wrong untill it is to late. An automatic will give you hints and clues before doom.
Since you think you know the noise, does it go away when you remove plug wires one at a time. It may be the beginings of knock or your paranoia. Don't worry, We shall all watch you do it, all 37,000 plus members.. MUHAHAHA
Viscous coupler OR couplers
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is true. Some people weld the gears together for dirt tracks or trails. Those cars are not pavementg freindly.
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.autozine.org/technical_school/traction/tech_traction_4wd_2.htm AWD systems and here is clutch type LSD http://auto.howstuffworks.com/differential4.htm
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnow i am confuzzled
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaruforester.org/vbulletin/f89/center-diffs-how-replace-them-46979/ With pictures!
