25
Everything posted by nipper
Well he is on the orad. There was a teething pain from sitting parked for 7 year that has fixed itself (check ECVT light). Tuesday he gets an exhaust system. i know the he will be in good hands as one of the mechanic's there immediatly recorgnized him as an "old school sooby". He had half a tank of gas so i filled him up since i had no ides what 1/2 meant on this car. :clap::clap::clap::clap: 3 gallons of gas. :clap::clap::clap::clap: He has a 9 gallon tank. *giggle*
Send it again please i accidently deleated it
I thought i got the radio right. The OE readio actually hadtwo connectors where the new OE (weatherband!) had the one. There were two light leads and the new one had one. 50/50 chance, oh well. Still need to put 100 miles on him to make sure the CVT works properply and the carb is good. I think he shall just be called Justy.
Ah yes i should review 1989 SUbaru Justy 2wd CVT parked for 5 years or more.30,000 original miles
He is now (almost) legal. Just needs an exhaust system and inspection. Bugs to fix: Cant seem to make the auto arm of the alarm to work. Oddly when I turn on the lights the (new gen) subaru stereo lights go out Mount inside rear view mirror Put tools away that are in the car. I even ordered him a EZ pass.
This is an OBDI so i will defer to anyone else on this one, BUT it can be either one or two sensors, or even three (gauge engeine temp for puter and rad fan switch). I will let someone else answer. It is possible the ECU is the issue, BUT lets rule out an external short first otherwise you may damage an ECU.
Ultimate Desert Subaru
nipper replied to oregoncoast's topic in Meet n' Greet. Your USMB Welcome Center
2.2 the way to go. A nice external oil cooler and filter to ad capacity, a air filter made to deal with dust is where I would start. -
I think the only air cooled car I ever saw without "flaps" was a chevy corvair. I always thought they were sort of cool.
I can tell from expeirience that a subaru 2.5 with a rod through the side of the block will not only start but will also continue to move a car (up hill to a safe exit ramp no less). The ringing sound is not a connecting rod. I am going with flexplate or flexplate plus rod, but someone PLEASE put us out of misery and do an autopsy already The rod test is so easy someone do it.
ALl it is is just a solenoid that pushes against a tab on the throttle plate. Almost any car with a carb has one. They can also be called a high idle solenoid. Some are vac operated, some electrical. http://books.google.com/books?id=kGz6HC6w98YC&lpg=PA399&ots=7pQAkTvhq3&dq=idle%20kicker%20solenoid&pg=PA399#v=onepage&q=idle%20kicker%20solenoid&f=false http://www.auto-parts-online.com/products/idle-stop-fuel-cut-off-a-c-kicker-solenoid-es4026235.html They go by various names, high idle solenoid, throttle kicker, idle stop, AC solenoid.... Cheap american unit overbuilt may work well from a junkyard.
http://www.thetruthaboutcars.com/2012/06/review-1968-subaru-360-owned-by-lexus-lfa-engineer/
