4
Everything posted by the sucker king
i haven't driven without one. but a lot of people here have, mostly to squeeze a little benefit out of driving off road. When somebody asked why I ran the swaybar on my lifted hatch instead of going without, my answer was that i was afraid of a bad handling car handling even worse. Now that I've driven it around for a while I realize this car so rarely breaks 55 miles per hour that it probably wouldn't matter much. The bottom line is there is nothing wrong with taking it off and seeing how you like it without. Lots of folks here have, and the wheels don't fall off. I don't think doing so will buy enough articulation to damage you cv joints.
I bought these off McBrat several years ago. He has doubted if I would ever get around to using them. They make a great car look greater. Have never seen pics posted of these on a car before, so here ya go
ea 81 weber air filter question
the sucker king replied to millhouse's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some people will say the taller filter breaths better, I have never noticed a practical difference, have used them both, now I use this air cleaner because it is cool looking. It will fit under the hood fine (oh and the 2.5 inch did hit the hood of my unlifted car as well)- 5 replies
- ea 81
- weber carb
(and 1 more)
Tagged with:
thanks for posting the grey interior. that is the darker grey that i like and would consider for my hatch. The original DL interior for my hatch was a lighter grey that I didn't like. I am still intrigued by the notion of a black interior, which with the above mentioned hatch has been mentioned here a couple times. Please anyone with a gen 2 black interior please post a pic if you can, I do not recall ever seeing one. as I mentioned I am considering painting all the hard plastic pieces as well as my dash. I wonder what the seats looked like that went with a black interior. Of course I can use or make seat covers. Has anyone ever dyed carpet?
Headlight suggestions?
the sucker king replied to RallyAlex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had the silverstars in (two different) 1980 hatches for years. I am not trying to argue. 80 and 81 subarus have unique and nearly identicle wiring. If I were the OP, I would try the silverstars, as they are readily available, plug and play, and VERY noticably brighter. I would do this before I would go messing with the wiring. That is my advice. -
I've never had any problems -
just put in sylvania silverstar lamps and I bet you will be happy. -
no you don't need to remove the dash to do what you want to do. The heater core is not where you stated you think it is. It is basically right in front of your gear shifter, between the fire wall and your radio console. You should be able to see the in/out water lines on the watercock somewhere to the right of your gas pedal. If you end up replacing the heater core, you will need to remove the dash, and it is a pretty big pain in the arse, but is doable
on the lugnuts- they are hard to find, as an alternative you can buy ball seat adaptors online for dirt cheap and use them with the stock soobie lugnuts. I have used them with no issues, as have others here. However i can not find the link to the website i bout mine off of. And just to be clear, I used them with the same 15" pug alloys that is in your avatar.
hot rodded ea81 is trans. strong enough?
the sucker king replied to ArtRat007's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In my opinion you are never going get so much power out of an ea81 that the trans can't handle it. EJ swaps are common and they don't overwealm the EA trans. I would think the axels would be the weekest link anyway. I wouldn't worry about it. -
Do I Need to Adjust the Valves?!?!
the sucker king replied to tundrabrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It is different from the solid lifter valve adjustment. Here is the procedure from " how to keep your subaru alive". You should be able to download this and zoom in and read just fine, if not let me know. I would think the builder did this, but I dunno. Let us know how this goes, I have never done it. -
yeah thats what I meant by dark mustard. I only recall seeing that color in 80-82 cars, I have had two with that interior, both 80 hatchbacks, one a white dl and one a pale yellow 4wd STD. It's not my favorite, but I guess it's cool in a retro way. definately dated looking. That one is particularly clean Bratrod. I have a clean dash that color that I pulled from a 81 white gl wagon. that's the one I am going to paint. Thanks for posting. Did you get my pm about the bushings you were looking for?
Hatchback Speaker Setup
the sucker king replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ive got these on the way! http://www.pioneerelectronics.com/PUSA/Car/Speakers/Speakers-By-Size/TS-D6902R
