Everything posted by angerthis
check engine light EGR question
Eliminating the EGR will it cause my check engine light to come on? because the code that keeps coming up says its the EGR solenoid Or is it just the solenoid That may be no good Oh yeah I'm working on a 92 loyal The one I did the 4 wheel drive conversion on if you read that thread The picture I included is obviously where the EGR used to be
My 92 loyal 4 by 4 conversion
Got to try out the four wheel drive The four wheel drive conversion work perfectly
91 loyale ea82 loose crankshaft pulley bolt/ possible engine upgrade?
If there is a hole in the block your engine is done and if its just a hole in the cylinder head you can replace just the head and whatever other parts that broke and be good to go but it sounds to me like you had an oiling issue and it threw a rod and if that was the case you can just find another 1.8 block and use your heads and everything else on that engine block
are all EJ series engines share the same bell housing
angerthis replied to angerthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere would I find the code for the Automatic transmission at? thank you for let me know about the bell housing differences
Mainly curious if the bell housing is the same off of a EJ 2.0 and the EJ 2.2 And how is the easiest way of telling gear ratio for the transmission
My 92 loyal 4X4 conversion question
thank you that's what I was needing to know something so easy that makes sense I might be able to figure this one out thank you Cuz I do know my 86 rx 4 wheel drive shifter has the little button for the low light on the dash to come on But the transmission that I'm using in my loyal is Out of an 87 GL sedan and it does not have the same switches as my RX for the 4WD low light to come on so I do have a multimeter I will check it out and get back to you thank you
Fiberglass Accessories and Reproductions
What about doing something like EA 82 center console for when people go from a push button 4 wheel drive to the dual range 4 wheel drive
So I take it nobody knows Please please help
I never did get to catch up with the guy at WCSS16 that owns the yellow RX I really wanted to talk to him about his car What else has he done to it?
This yellow rx that I seen at WCSS 16 Super clean and a little nicer than mine but I guess if I were to make mine a streetcar rather than an off road car I would make my car kind of like that Anyone knows who's rx that yellow car is? cuz I like what they did with the interior look like thay used a 95 ish Subaru Legacy GT dash board I'm not sure though
thanks man I've got some more good pictures I will dig them out and post them here
First pictures My lifted Radio Flyer Subaru wagon Mainly used for hauling around spare engines Second pictures My 86 Subaru rx 4 door sedan Third Pictures My RX and my 92 loyal when it was still front wheel drive Fourth Picture My RX and my buddies 87 Rx coupe With the wheels that I sold to him Because no longer needing 13 inch wheels since I have my 14 inch pugs
Ok you all scene my add with my four by four conversion Was needing to know On my dual range transmission What sending unit is for the reverse lights, What sending unit is for the 4 wheel drive light, And I assume the other sending unit would be for the 4 wheel drive with low light Not sure exactly but I assume that's what it is. Can any of you tell me which one is which Can't quite get my words out in writing So if any of this does not make any sense please let me know and I can try to explain it better Because I am trying to get my reverse lights to work and maybe figure out to get the 4 wheel drive light to work on the dash Cuz obviously going from a front wheel drive car to the dual range 4 wheel drive Transmission None of the plugs are the same so i just gotta figure it out and wire them in
Here are some better pictures of the car more complete
Yeah just use the blue loctite not the red I just dealt with the same thing with my 92 loyal But the best thing I found is to locate a EA82 turbo crank pulley because it's got a little dowel that also hold it in place it weighs slightly more but it's not enough to really make a difference but always remember use the blue loctite not the red
Thanks man it is a rilly nice car i would keep the car but i have my 4 door 86 RX Even though I have a lot of blood sweat and beer into this car but i bought this car with the intention of doing the 4 wheel drive conversion and selling it
Hear are a fu more picks of my 92 loyal the pick of just the wheel is what will be going on the car
Let me think about that can you send picks to me by email at angerthis@gmail.com
I'm not sure if it will be ready by this next weekend I think I'd have to bring my 4 door sedan rx It's got the good tires And the LSD to make it up the snowy hills If the pocketbook lets me I'll be there
I am building a 92 Subaru Loyale originally a front wheel drive car it is now dual range 4 wheel drive You can check out my Craigslist ad I will post more pictures later as I go along The things that I have done is rear disc brake conversion A dual range four wheel drive transmission With matching rear end I have completely gone through the engine its all fresh new gaskets looks good And I will have here shortly a set of aluminum saw blade 13 inch wheels to go on it tire size 185/80R13 The interior is in immaculate condition Just thought I'd start showing the work that I have done to it The first two pictures of the car are of it when it was still front wheel drive the very last picture of it is with the four wheel drive suspension on it The grey Subaru rx is my daily driver http://bellingham.craigslist.org/cto/4784192932.html
'93 Loyale Sedan rear coilovers
Just go to the wrecking yard And get yourself a set of 92 or so Honda Accord front struts take the springs off those struts cut Two and a Half Quiels off or what everit takes to get them to go on your factory rear struts it's not hard at all you can rent the tool from your local auto parts store so you can remove the coil spring safely
Another 91 Subaru Legacy automatic transmission?
angerthis replied to angerthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXK so do the vent lines go to anywhere?
torque converter reinstallation
angerthis replied to mrawrench's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe best way to put the torque converter back in Is to pull that long shaft out of the transmission There is a little metal clip that has to connect the shaft to the torque converter and then you put the shaft and torque converter in all as one unit than tern it like one full turn if that it will go right into place
On my girlfriends 91 legacy four wheel drive Automatic transmission It has to vacuum lines Coming out of it Or is it a vent tube at the top of the transmission towards the front by the engine I'm just curious of where they go or do they just hang there not hooked up to anything if you need more info please let me know I'll be happy to give it to you
91 legacy flywheel flexplate thing?
angerthis replied to angerthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI meant to say fell off the cherry picker:) so I decided just to go for it I used the torque converter from a front wheel drive legacy on my girlfriends 91 Legacy all wheel drive work great seems to do just fine
