Everything posted by cookie
96 2.5l OBW head gasket project
cookie replied to sublute's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou fingers are better than you eyes. Run your fingers over the area with marks. If you can feel any gasket still on there do your best to remove it.
cookie replied to sublute's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe old trick is to fin a piece of plate glass and use that to back your sand paper. Preferably larger than the head surface.
Upgrading Shocks?
cookie replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomebody reccomended the GR2s to me several years ago and I've had them on two cars now. My current Forester has had them for nearly 40,000 miles and they still feel fine. With a WRX swaybar in the rear the cornering is far better than stock on the Forester with much less roll. It's nice that both ends drift at about the same time with no big surprises like old 911 Porsches gave you. The "oh ************" feeling of suddenly having one end let go. I'd certainly buy another set if these ever give up.
cookie replied to sublute's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomebody probably fixed it for you. No need if the screws are tight and nothing is damaged.
Which to buy OBW or Forester?
cookie replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepends on where you live and how you use it. A Legacy type would be a pain to me as I do lots of city driving. When I have had people in back there is little footroom in the Forester. My opinion is the Legacy or OBW are better for trips as they are roomier and the Legacy itself handles better than either OBW or Forester. The Forester is a good choice for city living and hauling furniture which I seem to do far too often. Not a lot of difference in mileage and pretty much the same running gear.
Fitch Fuel Catalyst? Anyone here hear of them?
cookie replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the mythbuster's website. They did most mpg boosters, maybe not this one since it is so obscure. New plugs and a valium would be better for your mileage.
Clutch doesn't disengage
cookie replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo Gene, the hydraulics should move forward when there is play and take it up. We can write about this forever but nothing is going to change. You may get by for a bit by bleeding and you may not. If it was my kid's car I'd change the hydraulics regardless because they have hit the sell by date. Fact hydraulic clutches are easy to operate and build. Fact. For durability they suck. Give me a mechanical linkage any day and I'll just push harder and save $200 every few years. My leg will be stronger too.
How hard to change a front axle?
cookie replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom below for me too.
auto to 5spd swap 92 legacy how hard
cookie replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt really has to be a labor of love. Do yourself a favor and get an entire car to strip parts from. I have been back to junkyards so many times for one tiny item and learned the hard way. These days I'd just get a car with a manual as I no longer have the time I used to use doing stuff like this. If you are young and have the energy have at it.
Trans seals - front drive axles
cookie replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe may be old TC but we ain't stupid yet.
2wks@still no go re-mixed atf @front diff oil
cookie replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOooh, just reread this, that sounds sad. Tranny may be easier.
cookie replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually your hydraulics are not working. You should be able to have no ability to move it froward by hand. Start by bleeding it and that might get you by temporaily, but it's not a real fix. I have only seen maybe 50 of these that acted the same way, best to bite the bullet and change the hydraulics. Check the hose to as there was a TSB on some of them for hose and slave, I changed them but it was not cured on mine util I did the master. Anythime your clutch starts on its way to the floor with hydruaulcis it is time to at least bleed the system. Then it gets to the point where you can pull it up with your foot and that's when you had best do domething unless you like driving without a clutch release. Been there and done that, hard to throw the toll when you don't want to stop and they yell at you.
cookie replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe salve and master should last about 100,000 miles or several years. My 99 has already required both. The clutch pedal often sticks to the floor when either are shot. Chnge both and you are good for another several years.
cookie replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have no flow from both tubes? I ask because the radiator cooler section is known to block sometimes. The answer to that one is an external cooler.
Help!!!!!!!!!!
cookie replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy local hardware stores has a circlip selection. Does yours? If not the time honored circlip relacement is to circle it with mechanic's wire in the slot and twist off.
cookie replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's miserable enough to set preload on a regualr rear end. You used to have to use grease or mechanic's blue to see the contact patch. Adjust ability is good becuse otherwise you have to use shims. Never done it on a Subaru and don't want to. If you set it back exactly where you go it it will be fine, but otherwise you can run into gear whine or worst case running on the gear edge and haveing it break, very expensive error.
Strange rattle from under the center of car?
cookie replied to tuner-automotive's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCall Rudy at San Carlos transmission 650-622-9210. He fixed mine and perhaps he can point you in the right direction. If you can get the car up on a lift and move a stethascope back and forth, if your noise is in the transfer case that may be the problem.
2000 Forester Engine Question-Need to Replace Engine!
cookie replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was trying to figure that out myself. I have a 99 Forester that I'm planning on eventually using a 2.2 in. I'll have to check to see if it has EGR. The extra bolts would seem to me to make it necessary to use a 99 up 2.2.
cookie replied to tuner-automotive's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis could sound kind of like my car. It made noise while backing off for a couple of years. I posted here and setright assured me that many old Subie manuals did that and kept on going. Well mine did for maybe 40,000 miles before the transfer case blew. There is a spacer in the rear of the case that keeps the rear bearing from allowing movement of the gear set back and forth. After some time the transfer gears wear a bit and create play. The gearset then moves backward under load and slams the spacer, and moves forward causing a slight mismesh and noise while backing off. This eventually work hardens the spacer and in my case it shattered. At that point spacer parts went through the rear bearing and into the gearset.This totally trashed gearset and rear bearing and actually locked the car up for a moment. This is really no surprise to Subaru as there is a fix for it. You just install a thicker rear bearing and remove the spacer. Now, $1700 poorer I know this. All I needed to do when I first heard the noise was pull off the tail and change to the thicker bearing, maybe $150.
Brake Leak Where is It ?
cookie replied to 96OutbackGNW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYears ago I heard of a car that ate brake fluid no one could find a leak on. It turned out that a pinhole in the vacum chamber sucked fluid into the engine. No idea if this could happen to a Subaru.
Front Axle removal '01 Forrester
cookie replied to jnaught's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoy does geaseing or anti siezing splines make a difference. After all that effort to get my axles out I had a defective one changed in the shop that rebuilt my tranny. The guy hit it twice with a plastic hammer.
AWD Slow to Engage
cookie replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd go with the old Nipster here. At 270,000 miles the clutch plates should have quite a bit of wear as well as everything else being a bit tired. those engage somewhat slowly when they are in good shape and wear will just make them later. If it becomes unuseable I'd also look for used first, one of those is actually easier to find than the later ones. I just wasted a lot of time looking for a 99 Forester tranny and since it has moved to the additional bolt holes it was tough. Along the way though I saw a number of used automatics that would have fit your car. At that mileage I'd be tempted to drive it as long as it was working.
cookie replied to jnaught's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy Forester was a @#$%^& to get the hub out of one side. The other came out with a hub and drum puller and a couple whacks with a six pound sledge. The drivers side took me most of a day and the puller was grinding chips off the axle and distorting when it finally came free with a four foot pipe on the puller nut. I think without the sledge hammer I'd still be there. Somebody may have gotten some of those Forester axles in with a little too tight a press fit. I suppose it could have had some corrosion but everything else was pretty clean. A really good puller would help like a professional job with hammers on the end of the puller. The cheap Chinese auto parts on I used nearly died on the job.
Squeaky brakes.......Looking for a solution
cookie replied to mckeand13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBMW also uses a grease. It is compounded to stay put. You do the back and the metal sides of the pad where it touchs the caliper only.
CV boot hell
cookie replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found both of my front ones failed between the same oil change. Of course one might have been gone for a while and I didn't notice until i was doing the other.
