cookie
Everything posted by cookie
and change the $12.00 pilot bearing. It was going to be $150 more but I got that off for complaining that they should have done it right the first time. They insist that they only change the pilot bearing when changing the flywheel and I insist that is stupid. A pilot bearing, throwout bearing, clutch disc and cover all have about the same expected life. Oh well, the car is back to being quiet and operating properly. Don't remind me that many of you guys have much better prices in your area. If the car had not done it on the first day of rainy season I might have chosen to do it myself, but the weather kills my enthusiasm.
as I am married to a Kiwi and we have many relatives there. The interesting thing about Kiwi is that they accept cars of all major standards.This means you can have BMWs with european only equipement, JDM cars, Ozzie cars, and America's best. This was where I first tried a WRX and came back babbling about them to my friends. Now that we have them too folks see what I meant. You might really nejoy a trip to New Zealand, I used to bring old British car parts home when I collected them, and now it's JDM heaven.
on a car this new so not many will have experience to share. Swapping seats is not as easy as it used to be with seat heaters and air bag wiring. You will at least need the relay and switches for the seat you will use. I suggest you try a car fitted the way you want as this stuff gets expensive quick. I am more familiar with BMWs and it seems to change to sport seats I recall someone buying the seats on ebay for $1500 and being out of the job for around $2,000. Subie seats should cost less if you can find a car with all the bits you want in a wrecking yard. I expect your car would be prewired like a BMW but I am not sure.
bottle of goop to prevent head gasket failure.The phase 2 only gets a small external leak usually and is not a big problem. I forget the exact terms but Subaru also extends the warranty on these engines for head gasket failure. This might be worth doing a search on the board. When I had mine done (second owner) Subaru gave me a bottle of goop and paid me back for the gaskets I had replaced.
compared to fixing it. Another worry for me would be transmission lubrication while towing. This should be easy to see if it was a problem though as they tend to blow sky high if they were towed without lube. If it is lubricated from the gears spinning on the input shaft this would be readily apparent as I have seen Jeeps nearly cut in half. A good question is how was it towed as I have seen a Forester on a dolly behind a motorhome with two wheels down.This is fairly stupid unless the driveshaft is disconnected.
coupling that can be easily damaged by towing. Do you have a manual for the car? There have been a number of folks who have had to replace the coupling after towing. If you do a search on the board you should locate some. It seems to fail in a couple of modes if I recall, one of which is to lose drive to the rear wheels. Seems like the part is around $300 and relpaceing it is about $700 all up. Somebody with a better memory than mine might be more help. I would stay away from a 98 anyway because of the head gasket problems myself.
If everything else is very good it may be worth putting in a new engine. If the rest of the car is tired you may have to consider trading. One tough thing is that it is hard to finance a new engine and fairly easy to finance another car. If you are able to do the work yourself that is another matter. The first thing I would do is tear the engine down and see just what it needs.I would be hesitant to put more than a set of cyl heads and gaskets into a 97 unless it was a very good car.
