Everything posted by cookie
Replacing anti-freeze without air locking (don't tell the EPA).
cookie replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmoved to Montana I understand....the rest moved to California.
cookie replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould get a buzz off it... Who am I to talk, many of my generation tried smoking bananna skins???
cookie replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis also would not work well in San Mateo as you might hit a gang banger.
??? about impreza rs/l
cookie replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXproportioning valve. Any good race supply shop will have them. When you start messing about with brakes you often end up with a bias one way or the other. The factory will have worked weeks on setting up the original system for a proper bias and when we fit other componants we must compensate.
Which year has most head gasket problems from '97 to '02?
cookie replied to vintagejoe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnything with a 2.5 phase 1 is at risk for the internal expensive failure. Perhaps a real Subie expert will help here, but I think they ran from 1997 to 1999 in the Legacys.The first safe one would be a 2000 model year. For some reason the Forester got the phase 2 a year early in 1999. this is why I have a 1999 Forester as folks on the board warned me about the phase 1.
cookie replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthese days in many areas it is not a responsible method. In urban areas like mine the anti freeze ends up in the storm drains and so in our water. Pets think it's great and lap it up and die. I sure remember lots of folks doing this up in Maine when I was a kid. If it is warm when you start trickling the water the water will eventually come out clear.
97 Subaru Legacy Engine Knock
cookie replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand lose compresion a bit faster. Nothing catestrophic. We just have the equivalent of rebuiling a bit worn engine with loose piston skirts. I don't care for my slap on start up but it is so minor here in CA that I don't notice it anymore except when I am in or parking building with the windows down.
Is Redline Oil for real?
cookie replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat is excellent on a race course is not always the best thing to run in a half worn out engine on the street. In a race engine you look for low drag and resistance to high heat and load. The hotter the engine the closer to a hand grenade it is, and the more one experiments with lubrication the closer you get to not finishing the race. I had one friend who was the National hydroplane champ for many years in his class. His motors were truly hand grenades and he got one practice and one race out of them. On a street engine we are looking for a whole different set of characteristics from our oil. I have friends who are thrilled with Redline, but they use it on a race course.
Poor running on startup 2002 Legacy
cookie replied to calhounj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand odds on I would buy that kit Subaru is supposed to offer that also offers a cam sensor. They are pretty cheap and I almost think they would be good maintainence items as they have a moderately high rate of failure. These are cheap and easy to do for the novice.You might do a search and you should see how to change them.
Speaking of Timing Belts...
cookie replied to DiscoStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a water pump, tensioner, had the oil pump pulled, tightened and resealed,and had all the seals on the front replaced. I figure its easy when it's apart and all of those are items that commonly cause trouble. I hope not to go into the front of the engine again for another 90,000 miles. Keep in mind that I am a fussy ex mechanic who likes my car to be reliable.
99 Outback Impreza clutch problems
cookie replied to priscillab's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere have been some upgrades. My first Forester clutch was done at about 88,000 miles and I have the new numbers now. Gets rid of the chattering too. If you can't find the numbers on the board for the new kit I can look them up at home for you.
cookie replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCastrol Syntec. At least that is what I have heard on the Internet and you know that info is always accurate. I figure if you can trust it in a $12,000 engine for extended intervals it should be fine.
Injector noise?
cookie replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake it to a tranny shop for diagnosis. Internet does not work very well on noises.
Subaru going into the deep freeze!
cookie replied to Snowman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin a running Subaru. I have a heck of a time checking it with the engine off.
Dashboard lights gone
cookie replied to Offroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot actually burnt first. Sometimes they look fine and are fried. Before I pulled the switch I would test it to see if power was coming out of the dash light reostat. The other thing I would do first is make absolutely sure you don't have a short that would burn it up again. Yesterday I had this system out on my BMW but I have not done it on a Subaru. I am sure that switch should be fairly easy to change. The BMW has a lighted shifter knob that is famous for shorting out and taking out the reostat which is part of the switch. I gave the shifter knob its own fuse to prevent that.
cookie replied to Offroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe dash lights to power its lights. If you shorted this wire out the best thing that can happen is you blow the fuse to your dash lights. The worst thing is you can blow either the dimmer switch for the dash lights if it is seperate, or the whole light switch.
Ticking/slapping noise on start-up but then goes away
cookie replied to coloradosubarules's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou may have actually lowered the oil pressure and could cause lifter noise. An Aussie complained of this problem a while ago and said after fitting a new o ring his was cured.
cookie replied to Snowman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand change as much rubber as possible. In Maine when I was a kid rubber used to suffer at the temps we reached at Moosehead Lake and it should be colder there. Radiator blind?
2000 Legacy GT wagon.....reliability?
cookie replied to axxiom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have the phase 2. The goop seem to take care of possible leaks. I had the organic clutch in my 99 Forester and it was done at 85,000 miles. when the organics are in there the car seems to usually have chatter on clutch release. If you have that it probably means you will have early clutch failure. The good part is the late clutch kit works, but my##@$%%^& dealer did not replace the pilot bearing and that just had to be done 16,000 miles later.
Dead Miss!!! (sometimes)
cookie replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometimes when you put in cleaner it can turn deposits to sludge and clog an injector.
New Cats, mpg still rotten
cookie replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXafter that I would suspect oxy sensors.
cookie replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon Internet Explorer seach and there it was.
Aw rats, pilot bearing going
cookie replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaround here. Most of the good shops seem to be BMW and Mercedes, and Porsche locally. There must be somebody who knows Subarus north of Palo Alto. At least Carlsen mostly does it right.
cookie replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can't beat an inexpensive and easy fix.
97 OB 2.5 HEAD GASKET? (new member)
cookie replied to 3dig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsince you say the car is still nice. At least it would get the heads checked for flatness and while they were out the valves adjusted which is due. This car looks like the most miserable car to adjust valves in I have ever seen. It would be pretty easy with the heads on the bench.With the new gaskets I would think you'd be fine for the remaining engine life. The other possiblity would be a whole new CCR engine with new clutch, hoses, belts, etc. This would be expensive but would be a really solid power plant.
