Spazz698
Everything posted by Spazz698
  1. Mine didnt! Mine was cracked in a few places due to bolts not being torqued down (and 3 of the 4 bolts being used, and 2 of them being stripped from being crossthreaded and jammed in) When it finally cracked it just made a horrible sound starting up (think loose piece of metal in the housing) then that sound again putting it into gear. The inspection plate (if this is like my 93 legacy) will be towards the passenger side, you'll have to pull the cover off and I believe the pcv hose to look into it.
  2. So did I. The owner was on the news saying her son (I think) had put it on ebay. Repairs on that car's gonna be costly....
  3. How often do you see a 90s+ subaru on the side of the road (other than with a flat)? I NEVER do! My 93 honestly should have blown up on me a couple times but it never has!
  4. If you know what you're looking for, the handling in awd is different than fwd. I noticed a huge difference when I had the fwd fuse in (in my 93 wagon) even going in a straight line. So my suggestion would be put the fuse in and see if you can feel a diff, or you could do a couple donuts on dry pavement and see which tires leave marks Not recommended really, but I drive like a bat outta hell so I know all my tires leave marks, the fronts more than the rear from the power difference. or you could simply lift the car completely off the wheels (some shops might let you use a lift which is the safest way to go, or use jack stands, I just dont see using jacks and just jacks being smart in this case at all) and have someone put it in gear- it should cause all 4 tires to move just idling with no load on the wheels. I havent tried this method but to me it makes sense.
  5. oh yeah I'm very aware Im lucky they didnt go when I first got the car lol, 267k on those gaskets vs 88k from the last GM I owned. Unfortunately, I think the person who did my oil change overfilled it (as the anal oil checker I am since it's always leaked oil from the 2 rear seals that were replaced recently so I did check and the oil sat right at the first bend in the dipstick, way above the full dot and stayed there for almost a month til now) and I just happen to work at the shop so Im not sure if I want to bring it up or not. Why I didnt bring it up when I first noticed it...I dunno probably cuz I wasnt sure if my car was only leaking from those 2 seals but since I havent lost any til recently Im pretty sure. Anyways Im curious to know where the coolant has been going. It's not in the oil, so my guess is the exhaust. Can coolant clog the cat? sometimes it felt like my tranny was jerking but then I realized it could be too much back pressure, and now it feels Ive lost quite a bit and yes I have driven a few cars with no exhaust/fart cans for mufflers lol.
  6. I blew one/both head gaskets My car started warming up a bit after driving for a couple hrs, so I parked to check the radiator and I didnt even have a problem popping the cap off. That was low and when I filled it with water (I needed to replace it anyways and I was gonna do it fri) guess what I seen on the top-oil! So now I have to figure out how Im gonna fix this since I have to work, not only that how am I gonna get there when I do start tearing it apart- cant take a few days off I've only been there for a lil over 3mo- and also how does one flush the cooling system? I know Im gonna have to since there's oil in there, my work does have a pressure flush fluid exchange thing for coolant (forces the new coolant in, pushes old out) but I'm not sure that'll work in this case. So not happy I just got my oil leaks taken care of, and my tranny, but now I'm thinking the tranny issues were actually a combination of this and a possible exhaust leak somewhere. The tranny was overheating a bit, then on the freeway a week or two ago a truck in front of me kicked up a good sized rock or something, that hit my underbody. after that my exhaust was loud when I accelerated and my tranny never acted up til today. I know for sure 2 days ago my oil was full and now it's sitting about half. Lucky me my new bf works at a parts store! lol
  7. it sounds more like the clutch was overtightened more than a major issue. I wouldnt know why they would give you this much of a hassle to check that, assuming its like a honda you can adjust the clutch without needing much of anything.
  8. After reading a mess of posts about torque bind I think this is my issue. I cant find anything that says it only does it when its warmed up (or cold for that matter) but the symtoms do sound familiar. And does anyone by any chance know an easier way to grease the outer CV joint short of breaking the metal band and replacing it? My LF cv joint clicks once in a while and I just noticed there's damn near no grease in the boot. And I really hate dealing with those metal bands...
  9. I mentioned something about this in a previous post about something else but now the problem has gotten more specific so I figured Id start a new one. My tranny feels like its overheating. I looked in the legacy manual I have and I cant figure out how it's cooled. My primary fan is shot (so my secondary is on all the time and I cant use a/c or my motor will start getting hot) and my coolant should be replaced soon, its not completely bad but it is getting there. Im not completely surprised at all the issues with my car considering the mileage on it but Im wondering if that might be a reason for the tranny to overheat. It's that or a cooling line that Im gonna have to actually look for is blocked, but access to lifts for personal use it limited to school since work wont let me work on my car w/o a work order being on it and Im just not paying up to check/work on my own car. Im thinking its overheating cuz when its been on the road for over an hr or two it starts acting up, if I let it cool down it works just fine til it gets hot again. I make regular trips 45+ mi away so this is a problem for me and Im hoping Im not gonna have to give up on my car cuz sometimes I dont have time to wait an hr to let it cool down so I can get home and I wont drive it far after it starts acting up. Now that Im thinking about this this isnt torque binding right? I did have the fwd fuse in for a while when the flexplate was giving me problems (this was when I didnt know wtf was going on with it) and my dad didnt notice anything wrong with it when he drove it to my work from the shop (about 25mi away and the mechanic drove it for 30-45 min before that to make sure it was fine so it had time to warm up and get hot) and I pulled the fuse as soon as I got ready to go home so I never drove with it in. It feels like the gear is either sticking or like its towing something (think tow rope thats not being kept taut but not jerking the entire car)
  10. sounds like the tranny is having problems from the binding, but Ive never heard of it just losing reverse. If they give you the car free I'd pick it up, you shouldnt be spending half the car's worth on parts, just remember you'll still need to deal with the torque bind after you swap the tranny. I'd take it to a good shop and get a thurough diagnosis on it and go from there, many places will do the diagnosis for a fee then deduct it from the actual work done on it. Dont know if youre doing this yourself or not but I would take it to a shop to get looked at so you dont end up doing the "replace this part and see if this works" deal, it can get spendy. PS if you do pick it up and fix it, make sure you get the paperwork done on it before putting money into the car. Then if the guy wants it back tell him it'll cost him the amount you put into it, and another couple hundred for being the middle man
  11. I pulled the codes today, 24 and 42, both are air related (one's air control valve and the other is idle switch signal) I have a feeling the valve solenoid is faulty and has been for a while since I had intake issues almost the entire time i had it and it just now caused the CEL to turn on. Pretty sure the switch signal is my doing since I adjusted it so it'd idle where it should, was fine for a few months. The light was on before I put my car in the shop btw, the same day the flexplate started making horrible noises on my way home from pull a part (for a diff car) my car pretty much sat for about 2 weeks (used it once cuz I was desperate and late for work) and there's LOTS of miles on my car. currently 264800 (give or take <10 miles) but I did find out the tranny has been rebuilt for sure within the last 2 yrs and the motor probably has too, Ive found markings that'd indicate at least the top end (erm...sides...the heads and intake system at the very least) has been. Ive put 34k mi on it since I bought it at the very end of december. Im thinking it's time to change all the filters in it I can get to. New question: Once my car's been driven for a while it shifts oddly. I only notice this between 3rd and 4th, it doesnt like coasting in 4th (remember freeway driving!) it feels like Im driving a manual going 70 in 4th instead of 5th, that immediate slowdown/slight jerking thing (anyone got an idea what I'm talking about? lol) Kinda feels like its shifting a lil too soon as far as city driving goes as well. The tranny shop did check my tranny out to make sure nothing else was damaged and he said he couldnt find anything so Im wondering if this can be fixed by adjusting the bands?
  12. the flexplate broke about a month ago. Actually it never completely broke but it was getting there. Now I have a new issue: my car doesnt like to start. It's not the starter itself, that's doing just fine but it's acting like it has a fuel pressure problem, I have to give it a lil gas before it'll start and my idle yet again is off. Right now it's sitting lower than it should be and I'm still running around a grand at idle (when warm) Im not sure if this was from it basically sitting for 2-3 weeks til I got it into the shop or what. Now I do know this, the mechanic that did my tranny work went ahead and replaced 2 rear seals on the motor I would have had to pull the tranny off to get to since those were leaking and filled the oil back up a lil too high, it's sitting about 1/2 qt over. No overheating (well unless I use a/c, one of my fans crapped out and Im still trying to fix the more important things before this since I can roll my windows down) no burning oil or anything. I'm planning to do my oil change on fri (since I literally put my entire check into getting my car out from the shop) been babying the hell out of it since I wanna break in the parts I just bought not blow them up. I checked the fuel and vaccum lines and cant find anything wrong, so my next guess is either the air or fuel filter. Any ideas? I dont have any problems once it's started it's just the inital startup. oh BTW the CEL is on, I was thinking it was from the tranny issue but it hasnt gone away and from what Ive read it shouldve reset itself when the battery was disconnected so Im not sure yet, everytime I try to get my kid down for a nap so I can look for the wires i need to connect she never does and I cant do it in the dark
  13. I towed my 86 accord with my subaru with no problems, that thing I knows weighs almost as much as my subaru
  14. Mine were bad when I first got my car, I wetsanded with 1500 + 2000 grit for a few hrs. NOTHING got these cleaned up til I did that. Only downside is now theyre starting to get a lil foggy again (probably lack of cleaning ha) and now every time I pass I have to clean them off to make sure its nothing too bad lol
  15. I had this prob with my legacy, the pass side headlight liked to flicker a lot, come to find out the plug was on the verge of a total meltdown (literally...) the plastic around the low beam and the ground wires were almost nonexistant. Then I realized it was caused by 2 things: 1) bad xenon bulb producing way more heat than it was supposed to and 2) my lights being on all the time. replaced the plug, then the bulb a few weeks later (as it started to do the same thing to this plug but it was still useable) and havent had a problem since.
  16. yeah its the flexplate. Apparently there was some work done on it and the bolts are halfassed if you can even call it that. There's your choice of the stripped head or crossthreaded then forced into place til it wont move in either direction. There's a good chance the flexplate never sat up against the torque converter snug like it's supposed to, I like to think it was clinging for dear life lol. Anyways its cracked and I need to find a place (for cheap as humanly possible labor wise) who can fix it like...now... I found the 2 plates avail in puget sound sitting at the carter subaru dealership and now I have to hope my car will make it there before the flexplate completely breaks into pieces.
  17. Actually it's kinda been heading this way for a while but today the rattle got horrible. There's been a rattle, usually when I start up, that eventually either goes away or quiets down to the point I cant hear it. Ive been thinking it's the exhaust, it's all original and it sounded like it was coming from the cat so until now I assumed it was just the cover coming loose since there was no power loss or other problems. Now today I was coming back from a junkyard and on the last mile or so the rattle just got loud, so I decided to take a look at it since today's my day off and lo and behold, it seems like it's coming from the tranny. I swear on the last leg home I heard something that sounded similar to clutch grinding, but my car's an auto and I know it cant be the clutch packs on the car since it shifts damn near perfect. My dad looked at it and thinks it may be the torque converter or the flexplate (like a tooth or two broke, it sounds like a piece of metal is flying around in the housing) I dont want to drive my car cuz I dont want it to get any worse and Im having one hell of a time tracking down the flexplate (Im stopping by my school in a couple hrs to find out for sure, but if it's the flexplate I wanna get it replaced asap as I need my car first thing in the morning) Subaru would have to order it from out of state, and no one in a 50 mi radius has the damn thing. I might feel a little better if my other car was done but of course, it's not So anyways what other things can this be? I'm almost 100% its coming from the tranny. I dont really want to tackle this one but a few people so far have told me replacing the flexplate should only take a few hrs.
  18. Mine comes back about every 3k mi- so if and when I get the chance to do an oil change I stick like 1/4-1/3 can of seafoam in it soon after.
  19. I remember when I had a GL-10 (my first car!) it ran like no tomorrow. I know I did try to blow the motor up for a couple months, then totally gave up and sold it since I couldnt even get it to leak/smoke or anything. I sold it to a friend who snapped/bent a rod (or something...not entirely sure) not even 3 months after I sold it to her, got it rebuilt and blew the motor 4-5 months after that. Now I have my legacy, I love it. leaks, gas sucking and all. I'm totally willing to put oh, 400 into this car to fix everything wrong with it (given I had all of that at once) cuz I know it's not gonna break on me again unless it's my fault and if it's my fault then I deserve to fix it lol.
  20. I wonder if this is the same issue Im having with my car? (sorry I dont want to start a new thread it's so similar!) last 3 days my temp gauge has been rising higher than it usually does, today it actually got about 3/4 of the way up. Now it's been hot as hell here the last 3 days (80+, it was a lil over 90 today) Every time I notice it's up I'm stopped (today when it got up there I was stuck in traffic) the overflow tank has just as much coolant in it as its ever had, no oil in there at all, but I do have an external hg leak, small leak but I'm planning to make this part of my compentcy thing for school in fall as my next quarter involves this. I've checked the oil too btw, and I cant find anything wrong with it, the color's fine. So Im assuming I should burp it and see what happens? I mentioned this to my dad and my ex and both said it was normal since it's been so damn hot and my ex's car (honda) was doing the same thing for the last 3 days as well.
  21. OK I did the tint on my 93 wagon, the side windows are no prob but the back is a royal PITA. I ended up wasting a good 6 hrs total of my life JUST on that window. It's still ************ed up at the moment (2 tries later) but my tint is so dark you have to really look at it to notice it. I do find it a lil amusing, just because my side windows look perfect (with the exception of one crease, not bubble but crease) on one but then you see the back...lmao. Come to think of it I still have leftover tint. Think I'll try it one last time...
  22. Now if I were into SUVs I might be interested in this, I'll take an 06 STi, with its interesting front end and all. Tho my friend had a point when this commercial came up, he said at least it's not like GM's generic front end that goes onto all the trucks, just sized appropriately for the vehicle. First look at any GM you know it's a GM, at least you cant just say oh its just a subaru with it.
  23. I drove an 02 Legacy GT with sport shift- god that was fun. The best part- no clutch, no worries about misshifting or killing the car/overreving it...that car made me drool.
  24. my bf managed to shatter his clutch (not even a week old!) while racing, I remember he hit 2nd gear, then a HUGE cloud of smoke came flying out from under the hood and within the car itself. I was SO happy I wasnt in there. The car reeked of burned clutch right up til he wrecked it a few months later.
  25. sounds like it had/has a rear binding issue. Find one with a sportshift tranny! I dont know when they started putting those in legacys, the 03 GT I'm looking at has it, the sales guy let me have some fun Now i may be wrong but a 99 accord should get you more than 6k even if it's in just ok condition...I'd look closely and make sure the dealerships not trying to get you.
