Everything posted by Scott in Bellingham
Redo-in the 3 door coupe , going higher, yota axle
took it wheelin at walker it really preforms well its going to get beat this summer hope to go out each month
Walker Valley ORV July 7th
this picture is what stopped all the fun, this is after I welded it up at Jeffs , thanks Jeff for letting me use your shop, skid plates are over rated had a great day all in all was good to get out on the trails again, plan to go again in a few weeks, the pics are shown in reverse order as they were taken
P1050890(1) click on these to get bigger and goto my flicker account P1050893 P1050889 P1050887 P1050890 P1050879 P1050876 P1050872 P1050861 P1050874 P1050864 P1050869 P1050855
had a good day overall ended in group of 3 jeep cherokees pics later
d/r swap in legacy
short list ea-ej adapter plate EA82 redrilled flywheel ea82 clutch and p plate 93 Impreza FWD front axles custom mount for tranny longer driveshaft a complete EA82 Dual range trans with linkage 85-88
the wife and Ill be at walker tomorrow be in this
What would be the ultimate frankensoob for off road
I have atubing bender so the cage is no problem
Solenoid brake line lock traction control
I just weld up the spiders and go wheelin, on my first wheeler I tried a dunebuggy cutter brakes like these right idea but needs more force then I could give by hand
the body on the gen1 EJ is only about 1" wider then the EA82
so you got time to burn on a offroader? Im in bellingham can help out at my shop I like choppin parts off cars with a sawZall and M serios about making a fiberglass kit to convert the old subarus into a road legal buggy , my choice would be the EA82 wagon or the gen1 legacy wagon just because they are so plentiful and cheep the EJ would need outback or forester struts
I think your right on using the EJ platform as theres more or them and they have the better engine, just need to remove a bunch of weight zzzzzzzzz
lets do it, if you make one I could make a one piece fiberglass nose that would be hood fenders and grill all hooked with clearence for tires, I would use a wagon and cut the whole back off up to the gas tank and we could make a one piece rear section out of fiberglass, I live just over the line we could do it in a weekend
got the coupe goin now to go wheelin , who wants to go?
NWWO 4th Mid Summer run July 6th 7th and 8th Evens Creek (take 2)
I wont be there,just to lang badrive, but I may be at Walker Valley ORV park
you got a link to a map on how to get there? it could be a option for me , just a long drive
WCSS 14 - Jefferson County Fairgrounds, Port Townsend, WA
we are plannin on goin and hope to go wheelin with Zap at his place, probobly roll in friday with the popup trailer , this car with some mods and grafics just registerd looks like Im number #80
heres the cam # upper hose I got these at rileys you can see the # it also fits a 93-97 chrysler/dodge 3.3 v-6 concord and Intrepid lower hose lower hose fits a 91 BMW M3 lower , I trimmed 3" off the top end these hoses have 1 end smll for the rad and one end big for the EJ I ran the car today it goes nicely good combination regular hotrod , just have to get the mouse smell out they moved in since the car sat these last 4 months
heres one I had
EA to EJ Swap Clutch Question
have you done this?
Suzuki Sidekick vs Subaru
weak point with the subaru is your rear axle setup the sidekick will have a stronger axle and you can buy a locker the ea81 is the weakest ea82 axles and stub shafts will break with a locker newer gen stuff is stronger
go with a EA82 body (85-88 will have the dual range) do a EJ swap and install Delta low torx cams 4" lift 27-30" tires redrilled chevy wheels
on all my wheelers with a ej22 ive used the old ea82 4x4 parts, only failure ive had was operate error, you learn to luge it or spin the tires. dont slip the clutch
Is it possible
it should work,
Delta Low Tork cams ,in the pic the top one is the stock one, delta regrinds the stock cam to give it a new profile, these ones give it more low speed power where you need it for offroad, I used no smoke thick oil for the assembly lube, I made that cam sprocket spanner wrench as the bolts wouldnt budge with my impact wrench, its almost done finish it up tomorow then hit the trails, the mice moved in and left nut shells in the bellhousing
mo
