Scott in Bellingham
Everything posted by Scott in Bellingham
  1. I should have one in Bellingham got a pic of what you want? are you talking rear hatch?
  2. OK guys whats the lowest gears we can have in a Subaru transaxle? Ive been running EA82 Dualrange 5 speeds the 85-88 model they have a 1.59 Low range ratio with a 3.9 final ratio my question is can I go any Better? if so what bits and parts work from what models I play offroad and like the Subaru layout just would prefer some lower gears and stronger rear axles thanks Scott
  3. heres mine http://www.sjrlift.com/images/SJR_Buggy1.jpg
  4. Parts are available here in NW Washington complete rear diff if needed
  5. That size tire requies a Forester or Outback strut to clear, may require a lift and or body trim
  6. with your Forester you can go upto 29" tires , the spacing is not needed that would be for a Impreza or non outback legacy 215/75-15 is about 27" that's good with a 2" lift
  7. Is recommend a 2" lift. http://www.sjrlift.com/index.php/catalog/lift-kits/0-1-1-2-lift-kit-ej-fits-90-99-18-612017-02-10-17-18-35-detail
  8. So 4" at the rear subframe? And 3-1/2" at the diff?
  9. I make and sell whatever lift you need heres a 4" http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-ea71-detail
  10. Need a engine adapter I build and sell them www.sjrlift.com
  11. MT of any make. New I like the Maxxis Bighorns
  12. is that a chunk off axle on your rear bumpber? whats that for?
  13. I have a few pictures on instagram and facebook
  14. Ive dented most my wheeler tanks, no holes, my white wheeler I just added some 1-1/2" tubing as a guard/bumper brace
  15. no, looking at doing it to my 78 gen1 wagon now
  16. General rule 3.9 manual trans, 3.7 auto and turbo, 3.7 has larger spline count on transaxle stubs
  17. Adjust center bearing till it doesn't hit
  18. My 2" kit comes with 1" spacer for the crossmember http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-ea82-detail
  19. 235/75-15 will fit in stock forester struts, I'm developing a bottom strut extension , I've built the prototype
  20. PM me on the details of buying a bunch of these
