Everything posted by Scott in Bellingham
SJR 2012 ** group buy**
10 % off
once you place the order post here the Order #
yes Ill email all that setup a order
'86 GL/EJ22 sputters and dies
good to see your still alive :cool:
those that are committed goto www.sjrlift.com and make the orders in the notes area specify USMB Group Buy I will send you the Group rate , when 5 come it will happen
EA to EJ Fans Question
pusher fans in front of the rad works for me , if its lifted say 4-5" theres room for a puller fan in behind on the drivers side
I need 5 committed
Skylar 4" kit EA82 shortysayhi ej/ea adapter plate Dj7291993 ej/ea adapter plate LiftedLegacy 4" or 6" EJ lift kit for a '91 Legacy and an adapter plate heres 5 if everyones commited Ill do it, whos ready?
SJR Lift Kit install question
in this pic below you can see the 2 parts sitting together how they mount, it add bracing to that arm mount
$130.00
yes go up to 2004 on the legacy line
Walker Pics 02/25/2012
heres a few, click one one to go to set P1050463 P1050458 P1050453 P1050452 P1050447
need help with ej swap
I also do them check it out here www.sjrlift.com
10% off most lift kits 30% off EJ- EA engine Adapter plate state what parts you want and I'll tell you the price, I'll need 5 solid orders to make this happen , Ill need all payments in and all orders will be filled at the same time ,as time goes on Ill give more details heres my site www.sjrlift.com , happy shopping
need to know bolt sizes for chassis on brat!!!
front engine crossmember and strut tops, 10mm x 1.25 thread radius rod/tranny mount 12mm x 1.25 Thread x 30 long rear shock bolts top on body 12mm x 1.25 T x 30 long rear diff 12mm mustache bar to body 10mm x 1.25 x 30
NWWO FEB. 25th Walker Run
good well talk tomarrrow the 3dr is alive again good power love the new moter ( thanks Zap) was checkin it out and forgot it has a OPEN diff so the oils drainin and Ill weld it up in the morning this time on the car , see ya tomorrow
Just heard it run, this should be a good muddy run , jeff still have that red 3dr ? I could use the doors and other parts
EJ22 roller rockers on dual port heads?
are the older say 90-93 cam the same as far as the lode size and shape as a roller rocker cam, the reason I ask is I have a set of delta low torque cams Im putting in a engine that looks like this, the only difference I saw was the RR cams have a couple narrrower lodes
Ill be there , puttin a new delta camed EJ into the white 3dr coupe, its been sitting since last summer with a BHG
will a EA82 Y pipe fit a EJ22 single port engine
thanks guys Im trying to put the single port into my 3dr that has the dual port
I got a Impreza single port EJ engine need a Y pipe or wonderin if My ea82 Y pipe will fit
Barbie Jeep Power Wheels Buildup
My daughter outgrew the stock PW so doin a few mods Specs 85 Honda ATC 110 engine , rear axle and hubs 1x1-.065 tubing 145/70-6 tires, (the rear ones just for mockup) 1" round tubing for rollbars, CB radio building this for the kids but its big enuff daddy can drive it , plan on building 2
91 legacy adding D/R and 8" lift
I can ship you one right now www.sjrlift.com
Im going to try and make this one
to add a Dual range you will need a engine adapter . redrilled flywheel, a custom tranny crossmember and a lengthened driveline , that would get you started
