Everything posted by wrxsubaru
which fuse for the power seat???
I own a SVX and my power seat wont move, the rest of the electricle stuff works, radio, interior lights but the drivers seat wont move. I want to check the fuse but dont know which one it is. Does anyone know which fuse the drivers side electricle seat is? Thanks
93 turbo legacy
wrxsubaru replied to 86BRATMAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ej22t already has extremly strong rods, and the pistons are cast but not that weak. I belive there is a person running a stock bottom end with arp head studs torked sown to 100 ft pounds putting out over 400 horse with no problems.
Should I demand repairs before purchase?
wrxsubaru replied to ravenix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou cant really demand them to fix something that is not broken or noraml maintence. Maybe it already has had the head gakets replaced not long ago.
Head Gasket w/cheap solution question
wrxsubaru replied to mjb240z's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have used stop leak with partial succes on head gaskets but has worked on a heater core multiple times, and have taken apart engines that have used stop leak. I really dont see how it will clog a radiator. It seems to coat the whole radiator system with a very thin layer of it self, i have never seen it build up, and have never seen a chunky stop leak. If there is a chunky stop leak use a diffrent brand. It really is only a temporay solution if it even works, but you can keep on putting more stop leak in it when the leak comes back.
2.2 chunked a rod at 95k
wrxsubaru replied to archemitis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe auto in my moms wagon is good after 185,000 miles. The center diff still works fine to all 4, or 2 wheels spin in the snow.
WHO has a low milage early model Legacy?
wrxsubaru replied to gotsubarus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow about a 338,000 mile legacy AWD 5SPD not bad on milage, how about 20,000 US pretty good deal.
Christmas wish list for your Subaru? [WARNING]
wrxsubaru replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX9.6 sec 1/4 mile at 144MPH, i want that car. I wouldent mind the 500HP baja either. I dident Know there was a wrx that ran that fast are there any other faster subes?
Outback performance/replacement parts?
wrxsubaru replied to UniqueTII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a outback with a 5spd then swap in the ej22t, 160 horse and 180 pounds of tork but with more boost a ehust and intake innercooler it would be putting out over 220 horse and still have alot of down low tork, that the ej20 does not have.
No need to raise the car
wrxsubaru replied to Pillowsplat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont even jack up my SVX to do it. SOme times i drive one wheel on top of the curb so it sits alitle higher.
What to look for in a turbo legacy?
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked at it and the body was in good condition, the interior was in good condition, but the car needs a water pump(leaking, and it makes bad bearing noise), a timing belt, the fan for the vents makes a knonking sound, the visors are gone :-\ , and the sun roof acts weird, but i think a sprong, or more are missing, but the engine ran great, the trannie ran good from what i could tell no rust and no under body damage. What do you think it is worth? The ej22t is a non inter-ferance enigne, like the 2j22 isent it? If it is I should be able to do the water pump, timing belt my self. Sorry but it is aculy turned out to be a 92. What could you do to improve the fuel econemy, any idea ho much the inner cooler would help, maybe a MSD ignition? Also how hard is it to install a turbo timer? Also how good of milage would you get if you ran 50% highway 50% city not always flooring it.
Seeking advice on powerchipping my 2002 wrx
wrxsubaru replied to sayre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stock WRX 5spd arnt crap there acully pretty good. If you look the people who break there wrx trannie 95% of the time are people who beat the crap out of it, flooring while shifting, not using the clutch, stuff that puts alot more stress on it than there shoiuld be since you can't break the tires loose all the stress of flooring while shifting, shifting with out the clutch gets put put on the trannie. I heard of people with huge amounts of power in the stock 5spd, and they dont break if you dont drop the clutch or "power shift" as some people put it. Therte not the strongest tranies 6spds are stronger, but the 5spds are not weak.
This weekend my dad is going to look at a 93 legacy turbo wagon to replace his 336,000 mile 90 legacy, and i was wondering what i should look for? I know that it has the 4eat that is prone to failure in the SVX, but i never heard of failure in the turbo legacy. Is there any things in specific i should watch for, How long are the turbos good for? How much shaft play should there be in the turbo, if i can check. I know that the 4eat is a "strong" trannie and with a good set up trannie cooler it shouldent have as many if any problems but how much horse power can it hold i think i may be able to get some mods done to it, a new ehust, boost controller for some more boost, and a inner cooler. THANKS
Rash of SVX's stolen and attempted stolen
wrxsubaru replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah they would be. I think iam going to take some extra precations when i am done with it. I have the car insured even tho its on jack stands, in case they steal i can get my money for it. Some people were looking at it, or at least what my mom said. Two "kids".
Is my Subaru a pansy a-- POS?
My dad got over well over 100,000-1??,??? miles on unturned rotors and they still had life left, but i was putting on pads, and had an extra pair i pulled while I was at pull a part so they went on.
wrxsubaru replied to sayre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRunning more boost is really the only way to gain a substaintial amount of power, if you get a better flowing exhust, Down pipe, up pipe, and the rest you would gain some power, and you should have less turbo lag, and a better throtel response, but it would void your warenty like almost all performace upgraes. The stock WRX should be able to handle a couple more pounds of boost shouldent it?
wrxsubaru replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhope fully they stop stealing them so they dont run out of SVX in Canada and start in Seattle.
why AWD?
wrxsubaru replied to p3pppx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI saw that nissian comercal and it dident really make any sence, they said the AWD drive hurts handling on the dry pavment, the drive train has little to do with handling (the viscos coupling center diff on most subes barley have any limited slip effect at all and does not cause any real binding be between the axels unless its screwed up), the drivetrain is set up only to get power to the ground, you can get the most power to the ground through all the wheels. The drive train does afect how the car reacts when it is given power, or more power and when you have all wheel drive usally the car has the most controlable changes when the car is given power. Example If subaru made a WRX with FWD, RWD, and AWD they would all have very close handling limits, but would all react diffrently when you gave it gass, and AWD usally acts to most controlable and is the fastest set up , because you can get more power to the ground. AWD also improves braking acting as its own anti lock system because the wheels are conected through the drive train. It helps alot more than most people think, ecpecialy with a car with out ABS. Also the Nissian Skyline is primarily RWD but when it dectes slip it locks up so its AWD.
Legacy oversteer quirks
wrxsubaru replied to DAlgie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah after beating on a $100 90 5spd awd legacy in the dirt(small jumps, big rocks, and trying to make it go any where:headbang:), the front end got quite abit softer alot faster than the rear, it made the car have just have some over sterr in the dirt, and the mud, made it alot more fun. If the front struts are worn out it definity makes the car have more over stear.
wrxsubaru replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many scrap yard svxs are there? Where can I find them, even arrons subaru juck yard rarley has a SVX.
issue with frameless window
wrxsubaru replied to p3pppx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah you can really slam the door with your fingers in the way on the window, about 4 years ago my family was driving from seattle WA to michigan in a 90 legacy and we stoped at a sube dealer for a front turn signal light assembley, and as we all got in the car to leave a sales man came up opened the drivers door while my dad was in it and slamened it shut on his hand, thats how I and my family learned about that one, i guess it was a very desperate atempt to sell us a new sube:D
Ac leak how to fix?
While i was taking out the auto out of my SVX iI restd my hand on the ac hose going from the ac compresor to the fire wall, and when I lifted my hand off of it it started to hiss/leak it leaked for about 20-30 mins at the end of the hose were it conects to the compresor. Is thee a gasket, I tried tightening it down but it dident stop or even slow down the leak because the bolt was already tight. ANy ideas on how to fix it? THANKS
Oil leak from a ej18, from the distribuator.
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont have a digital camera, but the distributor is on the back of the engine toward the fire wall, on the passanger side and the oil is leaking onto the crosmember and I think is leaking on the exhust shield which produces a very burnt oily smell by the time the car is warmed up.
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the distributor is driven by the cam.
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst ithought the engine that was being put into the legacy was a ej22,but it turned out to be a ej18,it has a distributor, and it is leaking oiliam positive.
We have a 90 leagcy that has a imported engine swaped in it and is not using the distributor, but what the ej22 uses, and now there is oil leak from the distributor. I was wondering were the oil is coming from, and could i just block off the hole for the distributor since the engine is not using it? THANKS
