Everything posted by wrxsubaru
2004: 2.5TS or 2.5RS?
wrxsubaru replied to neptune's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was told the RS has the same suspension as the WRX. Thats what made itthe RS,over the other imprezas.
Stage 2 turbo problem.
wrxsubaru replied to GT-B SPEC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah it sounds fuel cut. Is your car is a auto ? I know when my friend hits fuel cut in his supra it kills the engine for a sec, but sence its a manule it is forced to re start, and the check engine light comes on for a couple secs.
wrxsubaru replied to neptune's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe RS has the WRX suspension, harder springs, struts, and larger sway bars. I Think the RS also gets rear disc brakes, and WRX seats. I am not positive on all on this tho.
Blow by?
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts sucking. Any other ideas.
svx transmission lockup
wrxsubaru replied to milari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a difrence between the NA legacy and the SVX, but you could use the auto from the legacy with out problems, but you would probley also have to change the rear diff ratio to match the front diff.
Blow by?
I just changed the timing belt, water pump, crank seal, and cam seal, and now if you lift up the dip stick or, opent the oil refill cap it blows out oil. I just changed the PCV valve and it dident cahnge any thing. Thanks
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt only goes on one way. Ill take it off and put it back on.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, i got the cam pullie off using a strap wrench. Im put the cam pullie back on, and now the whole cam gear wobbles alot. What bearing is bad? The seal i replaced opn the cam, was popped out completly.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWere can i get the tool? Ive called around and cant find it.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont think it has a nut shape. I put the timing belt back on, to try the same method you told me to use for the crank pullie.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the crank pullie off, but now i cant get the cam pullie off, i shoved a wrech in there to jam it, and it did, but the wrench broke before the bolt came loseb :-\ so i put a craftsman wrench in there ( if it breaks i can return it), It bent the wrench so it has a 35 deggre angle in it now this bolt does not want to break.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks alot, i was thinking about doing some thing like that but was scared it would screw something up.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried tday but couldent get the carnk pullie off, i had my dad step on the brakes, and have it in gear, but the pullie would move about 270 deggres from drive train slack, and then i couldent get the bar i was using any further becasue it would hit the frame. Any ideas on how to get the pullie off? Did you just use a impact wrench? I know there is a special subaru only tool for this, does any one know were to get it, or a place to borrow it from?
Quick what is the top dead center mark on the crank pullie?
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there a top dead center mark tho?
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow are you spose to take off the crank pullie, i left it in gear ( manule, and it makes the car move around if i try to losen that way.
What is the top dead center mark on the crank pullie? And which mark are you spose to use on the block?
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes any one know if the parts are the same for the ej18, and the ej22, becasue we havea imported engine that is a ej18 in the leagcy. I was told they were all iner changable.
Bad oil leaks
wrxsubaru replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSence I cant find a legacy to replace it this weekend, ive decided to to do a timing belt job, and replace all those seals in there. Are there any instructions on the internet some were? Thanks
SVX steering pump belt squeal
wrxsubaru replied to 95svx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe belt might not be tight enough? I think you should have around 1or less inch of movement on the belt up and down.
Bad oil leaks
Today i was installing some rear camber bolts on my SVX, when my dad pulls up in his 90 legacy 5sdp. The first thing i hear is tiking, the valves were tiking pretty bad, so i opened the hood to check the oil, there was some smoke :-\ , so i checked for a leak, and found out that oil was leaking from the timing cover any idea what seal went bad? So any way i added some oil, about 1.5 quarts :-\ and turned on the car again to see if the tiking would stop, it dident. Maybe the car has very little oil presure, or maybe perament damage, i dont know, but here is my main question should we keep the car? The car needs a new heater core, i guess complete timing belt job, and the car is poping out of gear in 4th, and maybe 5th. The car gave us way more than we expected with 345,000 miles do you think we should give it up? I can do all the work my self, and can get all the timing belt parts for around $100, but we could get a another 1 gen legacy for under 1 grand in decent conditon and with alot less milles, and probley alot less work, with a better trannie , and heater core.
Any rally racers want to help my daughter with a school project?
wrxsubaru replied to All_talk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah i think there are only 2 people from the U.S that get paid for rally dirving in the world.
race car gear box SVX any good ( help )
wrxsubaru replied to Neil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe person i bought my svx from (bought it with out reverse) broke by putting into reverse while going forward. I know that the auto trannie are one of the weak points to the SVX but that weak point can easily be fixed, and then you would have a great race trannie that is probley beffeier than you would ever need.
wrxsubaru replied to Neil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe U.S SVX auto tranmissions are not weak, the problem with them is cooling, if you do a level 10 rebuild to one there good for over 500 horse power with the stock gear set. The level 10 rebuild increases the size of the fluid passages which makes the auto bullet proof, if done right. The JDM, and euro SVXs have a diffrent auto than the U.S auto, it has a diffrent center diff set up and i think it is a totaly diffrent trannie,but it still suffers from failers I dont that trannies weak point.
Towing limit of a H6-3.0
wrxsubaru replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think subaru list it as 1000 pounds, with out trailer brakes.
Hood off Impreza for Legacy??
wrxsubaru replied to stylus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont think they fit, ecpecialy if its from a 2002- now Impreza.
