176
Everything posted by lmdew
It's most likely the Oil separator plate that is leaking. Don't change the main seal unless it is truly bad as the new one may leak. Plan on spending 2 days as you will want to get the flywheel ground. If the engine is due for the Timing belt, pull the engine and do it all at once. It sounds like you can see the oil coming down the enegine, if so were is it coming from. If you do the T=belt, do the cam and crank seals and the oil pump oring and lock-tite the oil pump backing plate seals. Grip-force on Ebay has great clutch kits. I've purchased many from them and have always been happy. Larry
Most likely it's just cut right under the dash. The wire would be running out the drivers side firewall, in a large wire bundle about 1.5" in dia. It runs along the bottom of the top frame rail under the drivers side fender.. Pull the lower kick pannel and I'm sure you will find the wire cut under the dash.
Just wanted to confirm my thoughts before I order parts. I picked up a 99 OBS with the 2.2 motor. I believe this will have the new style TB Tensioner on it, but I will be able to change the tensioner and backing block to the old style tensioner and then use the 95-98 Timing belt Kit. Sound right? I'm out of town so I can not open it up to check. Thanks Larry
I drove the seal back down and the leak stopped. It's a pain, but if you take a 3/4" wrench and go over top the seal and up against the axle shaft you can push it back down. I'm going to check the local bearing shop to see if they stock the seal. I also checked a 2001 Forester and the rack has a rubber boot over the input shaft so the seal must be inside now.
1999 Legacy SUS
lmdew replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tape will not pass emissions, they are smarter than that most of the time, as are most buyers. I always make sure the CEL comes on with the first turn of the key and then goes out after the car is started. Most emissions also plug into the OBDII which will show any fault codes. If codes are in the computer they will not pass emissions. Do it right or don't do it unless you are out in a area where there is no emissions check and you don't care if the CEL light is always on. -
It would be an neat setup. I had the only dodge carvan with a 3.0 6 cylinder 5 speed for a long time. The 6 caravan never came with a 5 speed but the dodge sedan did. It was pretty much a direct bolt in with a few welds for the trans support and shifter. I'm thinking the Subaru would be easy. I need a good CHEAP 3.0 with a bad transmission to check it out.
1999 Legacy SUS
Make sure the original engine and the replacement have the same EGR configuration, EGR or No EGR. Otherwise you will have the CEL on. -
1999 Legacy SUS
You can pull the covers and check all of the timing marks. If everything is lined up, you could do a compression check or better yet a leak down check. If you do the compression check on a cold engine by hand, you will not get full pressure, but if you had a bent valve it would show up. I like the 2.2 swaps as there are very few HG problems comparied to the 2.5 from 96-99
