176
Everything posted by lmdew
YOu can still clear coat, the sanding levels the paint and preps it for good adhesion of the clear.
The large fitting on the bottom goes to the Oil seperator on the back of the block and then oil drains down to the pan. The top fitting goes to the PVC valve on the intake. The 1/2" fitting coming off the middle goes to the Intake air box on the back of the intake manifold. Depending on the year and model, it goes to different locations. Look over the airbox and you will see the fitting.
First, don't drive it over filled, its bad for the trans. To get the pan to seal to the trans, both surfaces must be Clean, Clean, Clean. Then a nice even coat of RTV, I like the grey. bolt it up a little at a time in a cross pattern, and only to the proper torque. Then let it set for 24 hours to let the RTV cure. You should be all set. If its way over full, it may be leaking from the dipstick tube, where it goes into the trans.
VIN Check Please
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks, good info. -
VIN Check Please
Just trying to find out where the Forster has been. Thanks -
I've pulled many engine from the yard and only got one with a bad rod bearing, that one the filter was crushed. I rolled the dice on the engine thinking it may have happened at the yard. No such luck. Was the car in a crash, I like those the best as you can pretty much say they were running when it happened. Pull the injector connectors one at a time and see if the sound changes.
Strut mounts?
lmdew replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I always watch at the yard for a car that has newer KYB struts. $35 each its a steal. I trashed good rust free top hats a week ago. -
Check the main engine harness connectors and make sure they are moisture free, clean and tight. The fuel pump is trying to keep pressure in the system and the #3 injector is being powered and porting pressure. The injector is most likely good, you have an electrical issue. You can verify this by swapping the injector plug to the back injector, if that one starts acting up it's electrical!
The two bottom bolts on the strut should have been just bolts, straight through. There is NO camber adjustment on the rear struts, unless you put the after-market strut bolts in. The only adjustment on the rear is the toe, which is done at the inner tie rod bolts. You could not have changed a thing. The next time you change a strut, but the brake line bracket and slip the brake line out. That way you will not have to bleed the brakes. Just cut a slot in the end and bend it opena and then bend it back. Some like to cut a slot top and bottom so there is no bending. Larry
I'd take the old on to a radiator shop and have them match it. Prices are very competive on radiators, so the price should be close. What is the Month your car was made? I'd also take the VIN # along. Most of them I've delt with are all the same, there are some differences on some on how the fans mount.
Gauges are best, but if you don't have them and want to do a quick check of the clutch, disconnect the pressure switch connector and jump the pins in the plug. You can do the same thing at the AC relays. Don't let it operate this way for more than a few seconds. You'll still need gauges to go further, but at least you know where the problem is.
The pump often leaks right at the pump and then runs down the front of the engine and blows back over everything. Take it to a car wash and clean the bottom as much as you can. You can clean by the pump, but don't clean the alt. Fill the pump with Dextron III trans fluid to the correct level and then check for leaks. The lines do have fittings at the sub frame just behind the engine but they don't leak there very often. I do have a rack and pump I just pulled off a 97 which will bolt right up.
bleeding brakes
Go to Ace and get a lawn sprayer and some air QD's. If you can get a spare MC Cap, drill a hole in it for the QD. Cheap Motive Flow bleeder. -
If you have the external filter change it. Don't drop the pan, as there is only a screen filter in the transmission and it does not have to be changed. Drain the fluid Fill the transmission pull the transmission line off the radiator and put a hose on both to send them into a gallon jug. Start the car, the old fluid will pump out, it will be dark red. Stop when it's about 2 liters and refil the transmission. Keep doing this until the fluid being pumped out is clean as can be. Put the radiator trans hose back on and run the car and check the fluid level. This change does not shock the system like some of the power flushes do.
