Everything posted by lmdew
EJ22 Questions.
lmdew replied to dave valiant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got a couple of good motors and the ecu. What are you looking for? Lmdew@hotmail.com
93 Legacy Wagon Rear Tire Wear
I've got server inner tire wear on the rear of a 93 Legacy wagon. We did swap the complete drive line a and suspension from a 92 wagon, but as far as I know 90-94 are the same. No camber adjustmets, I believe? What's the fix? Thanks
High Capacity Radiator
Looking for a quality high capacity radiator for a 98 Legacy Outback Wagon MT. The OEM radiator is only 1/2" thick and the tubes are very small. Subaru must have made this the minimum capacity possible.
Coolant Issue
lmdew replied to JBRIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the exhaust for coolant smell. If you have it there, its the head gasket. The waterpump may be leaking down on the exhaust. Look along the driver's side on the oil pan flange.
New Outback Price, Pet Barrier, Trailer Hitch
lmdew replied to Sconnyite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what are they going to give you for the 97 with the bad engine? If the price is right, I'll take it. Lmdew@hotmail.com Any pics?
92 Legacy fuel sending unit trouble
lmdew replied to 4FOR4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe passenger side has the pump and sending unit. The drivers side has a sending unit and a fuel pickup to transfer the fuel over the hump in the tank. Both sides are used for proper fuel gauge readings. If you need the units, I have both from a spare car we parted for my son's auto to manual trans swap. Lmdew@hotmail.com
2.2 Oil Pump Oring
If there is no signs of leaks, are you changing the Oil Pump Oring when doing the timing belt? I usually do the cam and crank seal along with a water pump every other timing belt, but I've seen some talk on changing the oil pump Oring also. Your thoughts?
big troubles HELP!
lmdew replied to dawlfandave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is common, first lube it with liquid wrench. After it sets for awhile, try using a pliers to put pressure on the sides of the insert. This might work, but if they are corroded, you will most likely end up pulling the insert out. You can try driving it out from the back if you have access, otherwise just pry on both sides of the bolt. You may be able to glue them back in, otherwise its the dealer or junk yard for a replacement. Good Luck
94 legacy overheating
lmdew replied to J-roo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis happened to my son's 93 Legacy, 2.2. It was a combination of the cooling fans going out and a HG leak. Being a new driver, he didn't notice the fans were not working properly. This caused a minor overheat, resulting in a head gasket leak. It was minnor and did not cause problems all of the time and the overflow bottle was never low as the coolant was not being pulled back in to the engine as it cooled. Have a shop check the coolant for exhaust gases. That will confirm the HG leak. Good Luck. COS
Starter problem fix?
lmdew replied to STinger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure all of the cables and ground point are clean and free of corrosion. Poor contact can cause these conditions. Good Luck
1990 Legacy Water Pump
lmdew replied to robmc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd ask to make sure it didn't max out the temp gauge. You may have a headgasket problem if they drove it with the pump problem for any length of time. Just a thought.
How to replace ATF for 97 OBW?
lmdew replied to hb_kim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo change all of the fluid, pull one of the cooler lines from the radiator and run it to a bucket. Allow about a quart to pump out, stop the car and refil the trans. Keep on doing this until you've flushed the system. Works Great.
IAC Replacement
lmdew replied to MailManX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have several used if you want to try one. $15+10 shipping. Lmdew@hotmail.com
1990 legacy overheat problem
lmdew replied to danley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd make sure the fans are working when they should.
98 Outback Legacy Wagon Door Locks
Anyone have the ation sheet for the auto door lock module? I picked it and a security system up and would like to the auto door lock unit. Thanks
98 Outback 2.5 plugs
I got the plugs changed but what a pain. There is only about 1.5" between the engine and the frame, so little you have to put the tools in one at a time (socket, extension, ratchet). The only way to make this job less of a pain would be to raise the engine. Anyone have a solution? I know you only have to do it every 60K or so, but the designers weren't thinking of the Mechanic.
(Yet another) wheel bearing (?) post - FIXED
lmdew replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 93 Caravan has been making that noise for the last 90K miles in turns. If it isn't broke, don't fix it. Just a thought
15" Rims on a 2003 Outback?
lmdew replied to pulloff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you go to tirerack.com and check both cars you should be able to tell. They have both stock and other size wheels available. Good Luck
cracked radiator
lmdew replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a 96 Legacy Wagon, I don't know if it has the same radiator, but if it does, its in good shape and the yard gets $40 for them. Plus shipping, its a deal. Lmdew@hotmail.com
water pump question
lmdew replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI change mine every other timingbelt change. Of course I check it carefully along with all the other parts at every change.
Oxyen Sensor values???
lmdew replied to rayclark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX0.45 to 0.49 is considered optimum for most cars. If you can drive the car with a recording multimeter hooked up you can then get the average. The Fluke 87 meter will do this, they run 130 or so used on ebay. Not cheap, but its a great tool.
91 Legacy OEM Muffler
lmdew replied to ScoobySchmitty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a good Muffler and pipe you can have for $20 + shipping charges. I'm in Colorado. Its off a 92 Legacy Wagon, should bolt right up. Good condition Lmdew@hotmail.com
2001 outback's engine died
lmdew replied to st2eelpot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do you need for the 2001? Lmdew@hotmail.com
'98 OBW needs major engine work - advice?
lmdew replied to Shady Bimmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to sell the car let me know what you need for it. I'm looking for a standard OBW 97-99 with a bad engine. Lmdew@hotmail.com
Emergancy Answer On Fuel Pump Needed!
lmdew replied to terryb52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm in the springs, I can fix it or give you a good deal on a used pump. My son and I just did a engine and trany swap on a 93 Legacy into a 94 Legacy and we have a spare pump. Give me a call 268-9750 Larry
