lmdew
Everything posted by lmdew
  1. Do you still have the Car? I need a good 2WD Auto for a 90 Loyal. Lmdew@hotmail.com Would take the whole car if you think it would make it to Colorado. Thanks, Larry
  2. I have a 1999 Pase I 2.5 with 12K on it from a 1999. Paid $2500 for it and then didn't use it. Looking for $2200 + shipping. If you could get the car to Colorado Springs, I'd Install it for $2500. CCR is a great Shop, they've helped me many times! Just giving you anothe option. Lmdew@hotmail.com
  3. I have a good used rack and pump if you need them. Lmdew@hotmail.com
  4. 98 Legacy OBW with a single sunroof, the rear passenger side latch is broken off. Not much in the manual on this, It looks like it pulls the sunroof down to make it water tight. Is this part of the drive or a individual part?
  5. You should notice it starting to slip when you give it the gas. The rpm's will come up more than normal. As long as its working, there is not much damage you will do. The flywheel should be resurfaced when you do the clutch Kit. Looking at around $200 for the Kit+Labor. Later, Larry
  6. The waterpumps have two weep holes. The one on the back side, you can't see until its pulled. If the pump is leaking, you may be loosing a small amount of coolant and it's not be sucked back in from the overflow bottle. You'd run fine until the coolant got low and then you'd see the overheat, but the overflow bottle will still be full. Good Luck!
  7. The speedo shaft has a nylon gear on it that strips. There is another gear on the passenger side output shaft. You can pull just the pax side and change the gear/gears. It's a pain. I don't know if its worth it to fix the trans. You can change to a manual trans, but its considerable work also. Have you had a shop give you an estimate? That would be a good first step. Good Luck!
  8. The trip is on, I should be there about 1pm on Sat. the 12th. I deleted you email. Hope you see this an contact me. Larry Use my work email, as I have my hotmail set to dump all spam while I'm on vacation. Thanks, Ldew@airwis.com Please send you address and phone contact!
  9. Everything went right in. Just make sure you remove the top Trans support when you are going back in with the lower engine mounts. I left it connected to help support the trans while the engine was out and it held the lower engine mounts about an 1" fwd of the holes. Once I pulled the bolt, life was good.
  10. **Update** 5/20/04 passed Colorado Emissions test without a problem. I've driven it a couple of hundred miles and the ECU showed no codes. I like the combination very much and for a $125.00 for a used engine you can't go wrong! Just did a 2.5 to 2.2 swap on a 98 Legacy Outback. I'd picked up the 2.2 with 52K on it and then watched for a Outback that needed an engine. The swap went well (thanks CCR Inc. for the information). I only have to trace out the vac. lines, as there is one extra. Also will make some brackets for the power steering lines, as neither set will bolt up. Anyone need a 2.5 as a spare? Just pulled a 2.5 motor out of a 1998 Legacy Outback Wagon. It was missing on one cyc. The Shop thought it was a Head Gasket. Good Fixer, 109K was running fine other than the miss, when I pulled it. $550+shipping. Lmdew@hotmail.com
  11. Is the coolant being drawn back into the radiator, when the engine cools? If not you have a leak somewhere, most likely the HG. A leaking HG will force the coolant into the recovery tank, but many times will not draw it back into the engine when it cools. Check the fluid at the rad. cap when its cool and see if its full. If not find the leak, HG or otherwise. Good Luck, Larry
  12. The sensor is on the drivers side, just behind the manifold where the gas cables connect. Its straight down, a single wire goes to the sensor which is about an 1" dia. A single 12mm bolt holds it on. Do NOT over torque the new one. You can take a resistance reading, but I've not had much luck checking them that way. Good Luck.
  13. Are you looking for a used unit? I pulled a motor from a 95 Legacy and the ABS was in good shape, only 52K on the car. Let me know if you want me to pull it, I could get it WED. I believe the yard gets $75 for them and another 20 would cover shipping. Larry Lmdew@hotmail.com
  14. If you need the sending units, I have both $25+shipping Lmdew@hotmail.com
  15. Look for oil and or air bubbles coming to the top of your coolant recovery tank when its hot. Make sure the coolant is drawn back into the radiator when the engine is cool. If it doesn't do this is its a HG. Make sure you have all of the air out of the collant system. Very slow fill when you add coolant with the bleed screw out. I also like to add a coolant flush Tee to my heater line to let the air excape there. Good Luck
  16. No, a stiff 1.5" blade putty knife will assist you in getting the pop in fastners. The door handle trim is the hardest, about the center of the trim top and bottom there is a tab that clipd over a pin. You need to gently push them up to release the trim. If you have problems and don't mind driving to the north side of the Springs, I can get you back up in no time. Larry
  17. I was thinking about doing the same swap, but after all of your issues I think I'll stay with the 2.5 Good Luck! Sounds like the relay that puts power to the ign side of the system might be stuck closed, always hot. You might pull it and put a meter across the contacts. It should be under the dash, I believe.
  18. If CCR has trouble getting a harness for you, have them give me a call. I have one from a 96 Legacy, 2.2 sitting as a spare and it would get you going. Larry 719-572-3706. They helped me before and I'd be glad to return the favor.
  19. I do believe its a hydraulic clutch so check the fluid and then bleed if necessary. That's not how Subaru's are, there clutchs are OK
  20. I'd change the harness over. I had to do a like swap on the harness going from a 90 to a 93 Legacy 2.2 motors. Tie string to the end of the terminal when you pull the wires back under the intake. It makes re-stringing the wires a lot easier. Let us know how it works out.
  21. Any problems with doing a power brake flush on a 98 Legacy Outback with antiskid brakes? I've always power flushed my cars, but this is the first one with an antiskid brake system. The manual doesn't say much and the board had no posts I could fine. Thanks Larry
  22. The Stock WRX wheels and tires have been fine on my 98 Outback. NASIOC is the place to pick them up. $300 + shipping is the norm with very low milage. Some get lucky and pick them up for close to $200.
  23. Thanks for the info. I'm going to loosen both sides and pull them together with a strap and tighten things up.
