Everything posted by lmdew
2024 Ascent — Any Problems?
lmdew replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDito on GD. He's moved on from Subaru to Military Trucks I believe.
lmdew replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2006 is as new as I'll go.
1994 Legacy Blower Motor
lmdew replied to sockmonkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey all should be the same housing. Did you compare the old to new? I've replaced many and as long as the fan is clocked correctly all holes will line up.
2001 Forester - Cam moved during timing belt install
lmdew replied to kruteck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlways a good idea to turn it through by hand, through all four TDC strokes. But as he said you are good. Glad you got it.
Blower Motor Wiring Ghost,
lmdew replied to ithomas13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOADPRO is a great tool to add to your multimeter.
1990 Legacy MAF - which one is the right one??
lmdew replied to CharlieLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru parts. www.car-part.com may help you find one.
1997/1998 2.2 subaru vanagon conversion
lmdew replied to mongrelone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes to the above!
lmdew replied to mongrelone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it runs fine, do the seals valve cover, cam & crank, timing belt and oil pump reseal and call it a day. No need to rebuild. If it isn't broken don't fix it. IMHO. Great engines 300K+ miles and still going strong.
05 Impreza Speedo, Trans, timing Belt
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I've been off island for a month for work. Yesterday, with the cruise on, RPM dropped for a second two and then came back right away. This happened 2x in 15 minutes. I was down to a 1/4 tank, so I filled up. Well with a full tank it happened again. It died completely but started right back up after shifting into N. No CEL light or codes. I poked around in the engine bay today, moving wires... Nothing I could see. I'm sure it will run great again.
Tach and speedometer stopped working (intermittently) yesterday
lmdew replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com good source of original used Subaru parts. Don't get an aftermarket alt.
lmdew replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSelf-serve yard and pull one. Pretty cheap! Go in and drill the bolts out. Put in standard bolts when you bolt it in.
1999 Forester AT EJ253 - Misfire Pulling Away from Stop
lmdew replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoolant Temperature Sensor been changed?
2007 Outback wagon rear ended, totaled
lmdew replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrame shop? I've had pretty good luck with a winch. You have to strap the car to a tree or something secure so it does not move as the brakes are not enough. Hook to the old bumper support before you remove it and see what you can get. The problem is all the sheetmetal that is moved in is not hooked to the support. Another option is to cut out a good section at a yard and place it over the top. It will not be perfect and you will have to do some fitting to get it close. JB weld and some screws to hold it in place while the JB cures, then grind off the screw heads and body filler. No weld fix.
High mileage 2002 Forester, oil options
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst question is were is it burning oil from, past the piston rings, valve guide seals..... Don't know that's worth doing a leak down check, but that would provide some answers. How much is it burning?
2003 Legacy Outback vibration between 32 and 40MPH
lmdew replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it change if you apply the brakes lightly? Rotors could have rusted up a bit while sitting.
1999 Outback Stuck on Defrost
lmdew replied to Johnny Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the lower kick panel on the drivers side. Get your head under there and look up at the side of the airbox. You will see the motor and linkage.
lmdew replied to Johnny Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I'd indicate earlier,: The temp control is a cable that routes down to the passenger side of he center counsel. you can look up and see it move as you slide the temp lever. The vent control is electrical, push button control. Yes, sometimes it's the board in the controller that fails. You can change out the board. It goes down to an actuator on the drivers side of the center counsel. Pull the lower kick panel and then crawl up under there and you will see the linkage. I've had the linkage fail, the actuator or the control board. You Pull and Pay yards are your friends. Poke around there first is always a good idea. Once up under the dash, you could disconnect the linkage and move it where you want and safety in place somehow. Most of time it's the circuit board on the dash.
Please Help Me EJ22
lmdew replied to JesusLady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com is a good source for used parts. You can get an idea of what used engines are available and there costs.
Please Help Me EJ22
lmdew replied to JesusLady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPictures of the Cam, and crank alignment marks would help, but that will require the timing cover to be pulled back off. Most likely bent valves. They could do a leak down test on the cylinders, they would hear where the air is leaking out of. They need to have experience with doing this for it to be valid and the timing marks need to be correct. Pulling the valve covers and getting a look at the cam and rocker arms may provide some insight as well. Good Luck!
EJ22 30 PSI on all four cylinders HELP
lmdew replied to Bobthecat01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad you are so far into the engine already. Yes, I'd say timing as well. I know you said everything was good. Did you add some oil into the plug hole/cylinder and check the compression again on each cylinder? Were you holding the throttle wide open when checking and had a good battery? Did it jump right to 30 on the first stroke and then not go any higher?
2002 Subaru Impreza TS - AC Compressor 2002-2003 Only?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the compressor and evaporator coil with good used from Colorado. New Condenser. The old condenser was restricted just blowing through it. Serviced today and it's working great!
1994 legacy gt possible tailshaft replacement
lmdew replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXu-joinf first, I'd think. You can put the FWD fuse in and see if it makes a difference.
no start weirdness a month after front end impact
lmdew replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be. I've had some good luck with fuel tank additive to clean the sensors. It's a resister on the level arm. How's it work when you fill it? Gallons added, add up?
"Broken" pitch stop mount
lmdew replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow much of it is there? Pretty much just there for an accident, so not a big deal if it's not there. Not much you can do without pulling the dash. Weld, not with all the wire and insulation on the inside. Bracket and rivets, limited strength.
Project 1990 Legacy Wagon No Crank
lmdew replied to bigshankhank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrosion/green crap in the wire. There should not be a significant voltage drop under load. I just fixed the better half brake lights on 2006 Forester. No brake lights, all three out. Of course the brake switched ohmed out just fine. I swapped it with a spare I had. Fixed. When I opened up the old switch, one contact was pitted and burned.
