Everything posted by ericem
Id look at ceramics. Check out tirerack.com I run the ATE ceramics they are very good from my short experience with them. Brake pedal feels real nice and MUCH better then the metallic pads. Also be sure to grease up your sliders and make sure they are not sticking. (when i did my brakes a few were rusted solid, might need a torch. and you could see the uneven pad wear)
Well, while doing my brakes. I tried to shake the CV on the left and right side. Seems like the right CV has more up and down play then the left side AND the rears are solid. Something there a issue? Which might explain rough acceleration still? Thanks.(also my brakes feel much better Rears were glazed and rear rotors had chip marks and alot of sliders were rusted one was rusted solid in the front, torch took care of that one and I could see the uneven wear on the pads, just cleaned up the rust and greased....)
Hello I love using my torque wrench and tomorrow im going to jump into the brake job (doing 4 rotors and front pads) so I thought id ask. I torque my wheels to 70ft-lb's by the way and I for the brakes I bought brake grease for the slider pins and anti-squeak. I think thats all I need right(and yes I have 1000's of tools )? Thanks guys!
1992 Svx
ericem replied to Nate007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WOOT! -
1992 Svx
Ohhhhhhhhh -
1992 Svx
Would probably help the tranny and diff if you change the oils to synthetic and got a cooler for the transmission. -
legacy doors
ericem replied to 82glsw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
no problem -
legacy doors
Front doors 89-91 are the same wagon to sedan. 92-94 are the same wagon to sedan. -
Was looking at EMPI. Are all the boots usually good?? Looking at them here: http://www.autopartsway.ca/autoparts/quote.cfm?ID=1993~K6010-181548~000578373~SU~LEG-4WD-001~CV+Boot+Kit http://www.autopartsway.ca/autoparts/quote.cfm?ID=1993~K6010-182652~000578374~SU~LEG-4WD-001~CV+Boot+Kit These boot kits ok?? One is inner and one is outer. Forgot to add the CV is from a 91 SS.
