Everything posted by ericem
heat shield!
ericem replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ya true maybe a high temp one? Some must be high temp up to 600-700F range. How hot does it get really? -
heat shield!
Is it possible to spray some foam in between the heat shield?? -
Well checked with the guage. Got 21 in-hg. So seems good was consistent. Plugged it in via the power booter line. I think my problem is the powerbooster has a leak. Also setup the TPS correctly as the manual stated with a feeler, revs perfectly, when i gun it, rpm's flow just like they should no pop's or delay. I did the powerbooster test btw. Now i need to find a low mileage powerbooster. For now ill push the stock booster. Also shifts better now that the TPS is setup. Another good thing done was change the veryyyyyy thick and black oil. Also noticed there wasn't really any oil So flushed out the bad oil and refilled with some high mileage oil 5w-30. Definitely explained why the engine was knocking hard
Well today got the vacuum gauge. Also bought a feeler guage so I can setup my TPS. I screwed around with it a bit by guessing seemed a little better still was a guess. So I read what the manual said how to calibrate the TPS. Now waiting for my mother to get home with the car so I can do everything. Now its 10 PM where is she Anway lol where should I hookup the vacuum guage? BTW a manual came with the guage says 12-15 means incoorect timing? and 18-21 hg is good. That sound about right? There is more info on it though.
I was looking at this motor and could not figure out what and where the spark plugs wheres and spark plugs are. Also will this motor be able to run off a EJ22E ECU and will the tcu work?? Comes with the tranmission you see there as well http://www.jdmtigerjapanese.com/product_info.php?cPath=28&products_id=185&osCsid=8ndcu8rfcv4apmi5lkgvvthrj2
Replacing the seals will be fun. Going to get a seal kit I guess while im at it. Just thought Id ask incase anyone knows. For the rear housing of the transmission does it have a gasket? Or is it sealed with RTV ? Going to remove the rear case and inspect the shoes and test the solenoid. Really annoyed with this torque steer and front wheel slippage. Winter will be pretty bad so I better rebuild it. Someone at a subaru dealership told me there is a small screen filter which sometimes gets clogged and created the AWD lag. Thats if the transmission was actually rebuilt. So ill be finding out.
