Everything posted by ericem
Squeaky brakes.......Looking for a solution
ericem replied to mckeand13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo one here uses anti squeek before installing new pads??? Its this rubber liquid i pour on the back of the pad wait a minute then install never ever hear my brakes squeel at all. Also now started lubing and cleaning my sliders. Using ATE ceramic pads and plain brembo rotors front and rear.
I have a annoying crack I get from the dash when I down shift
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes!! When is warm outside there is 0 crack noises on take off or downshift manually. But when its cool outside thats when it is most annoying. Well I did drive with torque bind for a while so I guess I should change all the easy mounts like the transmission mount, the bar that goes from the firewall to the bell housing and see if that helps. Hmm about the flex plate I wonder. Someone told me that to seems to drive fine but seems weird seems like its not giving as much as it usually does. At idle though its normal no ticks, just sometimes I get a tick when its cold outside, but I think its the lifters.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't seem shot but I can definitely get it to flex a bit and wiggle if I try. I was thinking about replacing that piece with one from a wrx or something. Its a awfully thin bar.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a automatic. Definitely is flex as even in D when you get off the gas you can hear it. Its pretty rough and loud. Still haven't replaced my front cv's though which have alot of play could that be the reason why? I almost seems like the car is seperating LOL.
I am bored lol so I thought Id ask, I also searched but didn't come across anything. But anyway today was pretty annoying when you put the car in manual mode or heck even in D i get a loud crack from the dask board as it seems when it down shifts. I am wondering what I would need to fix this horrible flex in my car. Maybe a motor mount, tranny mounts? the brace going from the firewall to the transmission bell housing maybe? What do you think is the issue please tell me :-p Thanks.
Crazy Gas MPG rating
ericem replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExactly when I was screwing around with my speedo cable and unplugged it I got a power light. Didn't drive crappy though and I didn't get a check engine light. If its not working at all there is a piece that often fails on the differential where the speedo cable plugs in that breaks. http://bbs.legacycentral.org/viewtopic.php?t=32903&highlight=speedo http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg
Rust in rear wheel arches (near suspension) a common thing??
ericem replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure if you don't wash it often and salt gets trapped in the area. Do you have pictures?
Downsides to the 2003 3.0L v6?
ericem replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy do you need to use 91 octane? It's not turbo.
90 leg pays the ultimate price for a grateful owner
ericem replied to tysn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSay you want $5000. They are very rare mention Good that you are ok. Better see all the doctors ASAP. Have any pics? Poor Subaru.
Suspension Woes in a Baja
ericem replied to ScottD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind a alignment shop preferably lol.
Pearly Baja????
ericem replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm I still prefer silver or yellow
vibration at idle & AC
ericem replied to adwolf1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy car does the same thing still, and I still haven't installed the new CV's. The front's are both remans with alot of play on the diff side.
Is There a Trick?? Gas Tank Removal
ericem replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery good point!
Canadian Dollar, eh!
ericem replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm this is a good oportunity for a new vehicle and some shopping across the border. ONE ISSUE NO $$$$$$$$$$$$$
White Outback w/ Black Leather?
ericem replied to Bishop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://cgi.ebay.com/ebaymotors/Subaru-Legacy-AWD-OUTBACK-2006-Subaru-Legacy-Outback-NO-RESERVE_W0QQcmdZViewItemQQcategoryZ31869QQihZ011QQitemZ320160951688QQrdZ1QQsspagenameZWDVWQQtcZphoto Thats odd says the title is other
92 Legacy Pulling
ericem replied to mudduck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe a CV? Could be the tires still like they are out of balance or a belt broke. Doesn't hurt to check the calipers and make sure the sliders slide
ericem replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX:banana:
Gotta turbo legacy! **PICS**
ericem replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome. I guess it wouldn't hurt to clean out the IAC valve see if that makes it idle properly. Also try dumping seafoam down the PCV valve and put some in the fuel tank. BTW no they did not all have 5 speeds a 5 speed in a 90-94 turbo was rare.
Pics of the "SEXY LADIES"
ericem replied to 86ruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI WANT THOSE RIMS NOW!!!! Which rims are those?? The car's look awesome man!! Even with the hub caps
Strange squeek
ericem replied to sgregory's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne of the most likely issues LOL.
94 Legacy factory CD player issues...
ericem replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 89-91 legacy's had the AUX standard and CD player on higher end models. 92-94 did not have AUX standard as they cheaped out and CD player on higher end models.
ericem replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe take it out. Look to see if there are belts and gears that are messed. Then Spray some contact cleaner on everything. Then Plug it in. If it doesnt work take out a hammer then take out a camera and take pics
radio/cassette problem in 93 wgn
ericem replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts odd. 90-91 had aux. Then the rest didn't. What happened? Still even alot of cars today do not have auxillary although a 17-18 year old car would
Rear horn?
ericem replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven better. Blow up that damn car before it hits you
Rear horn?
ericem replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDude you don't need a horn. You need something that will throw something at there car. Like a basketball
