Everything posted by Andyjo
Wagons only - post your pictures here!
Andyjo replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall three of them together
I own a Subaru...again...finally!
Andyjo replied to jergar999's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWagon or Sedan? oh, and welcome!
How cold has your Subie been?
Andyjo replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe green roo has seen -40 F or colder... started at like - 30 F, the black one.. i'm not really sure, because the temp meter said 'E' as in 'Error'
Help me decide on a newer outback
Andyjo replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso on the color issue... Black is insane to keep clean
Boston Area Help
Andyjo replied to nydsol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had my car worked on in marloborough, it came out really good, but it took a while, and isn't really close to boston.
Andyjo replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think the 05 is lighter than the 04 too... not 100% sure though... but i'd say go for the 05, i have an OBXT, and the handling quite a bit different from my lifted OBS w/ no swaybars.... in a good way... The ride is alot smoother, and the interior is (in my opinion) alot nicer in the 05's. Also, i think there's more aftermarket support for the 05 Outback for handling and stuff, swaybars, etc.. because it's pretty much the same as the legacy GT. Go w/ the 05, it's closer, and the silver two tone is hotttt! Oh yeah, i think the 05 has the gun-metal grey rims? wanna trade w/ my OBXT rims?
Slottod rotors of 2005 Legacy GT?
Andyjo replied to SkipII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfor high stress braking slotted is the way to do, drilled rotors have a tendency to crack between the holes, more so than the slotted ones. and yeah, if you're not getting your brakes hot on a regular basis, it's not worth it. and of course, going to a bigger (larger dia) rotor means you need a different caliper and all sorts of jazz. Also, don't forget to bed-in a new set of pads/rotors when you get them, that makes a WORLD of difference.
Andyjo replied to SkipII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbrembo, ecb.... if you're going to do it, do the front & rear at the same time so you don't get wierd power differences. i've got rears for my obxt (sitting in a box), i'm just waiting to get the fronts.. going w/ ecb green pads when i get all the part together (and ss lines of course )
freezing issue!!!
Andyjo replied to Zefy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 The block heater would be the way to go if you can find the cable. if you can get a kero heater under there, and a TON of tin foil!!!
**call For Pictures**
Andyjo replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the full size ones kickin' around http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0316.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0315.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0313.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0312.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0310.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0309.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0308.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0307.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSCI0311.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05874.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05877.jpg (don't mind the flat tire...:cool: ) http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05587.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05501.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05498.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05506.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05484.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC054792.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC054782.jpg http://i121.photobucket.com/albums/o206/AgentBCOC/DSC05476.jpg That should keep keep you busy for a while... if you want to use any, let me know, i'll get you the full size, and blur the liscence plate on the ones i forgot.
Andyjo replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX100% flash? you realy hate people w/ slow connections don't you? :-p i might have some pics of the obxt kickin' around if you're interested.
Cargo box on a lego wagon - what works?
Andyjo replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup, and chopped a little off of the rear lip, because i didn't feel like drilling another set of holes, when i was about 3mm to far back. i managed to keep one of the mounts for the front and back in the 'slider' part, but i also had issues because the obxt has a spoiler at the top of the hatch, i don't think 99 legacies had that. I have seen some of the new boxes are re-designed to allow hatches to open better (pretty much just a larger sliding range, and an angled rear section i think.
Andyjo replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got an evolution 1800... it will NOT fit without modification
Uneven exhaust on '06 Outback ...
Andyjo replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi wouldn't worry about it too much, my obxt does the same thing, and most cars w/ twin tip cans have a bias towards on, since it's the same system, no biggie. if you had 2 separate lines though... that would be a different story.
my 91 legacy sport sedan wont start.Help
Andyjo replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi blame a leaking vaccum line... .doesn't matter what's wrong with it really, it's that line under the airbox... always is.
Blus home :)
Andyjo replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks good! I got mine back from the shop too! and i wish i had told them to do the 'other stuff' too :cool:
Wheel Lug Question *Wheels On*
Andyjo replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReally? i never heard that, good to know!
Andyjo replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlug nuts? they'll look prettier w/ alloy nuts, goto a junkyard, and pull some.. like.. 20 to be exact as long as your lug spacing is 5x100 you should be all set, and i do believe that's the spacing for your car.
New Pics Of the Imp
Andyjo replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah why isn't it covered in mud?
my 04 outback sport needs more, well...sport
Andyjo replied to litewaitdave1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you have double port exhaust, i had single port :cool:
Andyjo replied to litewaitdave1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy borla's (all 5 sets) were genuine :cool: and they all cracked :cool:
Centre diff lock on AWD auto
Andyjo replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's what we need!
Andyjo replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe it's the latter of the two methods, but i could be (most likely) be wrong. how about a switch like this: i couldn't find the uber secure usb hub on thinkgeek... requires 2 keys, some flip covers, one of those big levers..... and yeah, if you could get it to be 'almost full lock' that would be good, because i think when it's binding, the ATF Pressure in the valves below the solenoid build up enough, and blow out the oring on the bottom of the solenoid. (or that's at least what mine looked like )
Andyjo replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow... that's some crazy EE talk... damn sparkies.... I believe someone looked up the signals once. I thing there is an underlaying signal (square wave), which is then pulsed in another set of squares, and controls by the pulse width (does that make any sense to you?) I started working on a circuit design at once point... i think 2 555 timers and a potentiometer to control the pulsewidth somehow... yes... muhahaha the frequencies of these things.. i have no clue :-p
Andyjo replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've played with it before... i think you just nominated yourself to hookup the oscilliscope I think it was thhhheee..... 11th pin? http://www.ultimatesubaru.org/forum/showthread.php?t=50264 that should give you a little more info... as for locating it... i haven't heard of anyone doing it w/ a newer (00+) roo' I would totally suggest you run it through a relay, and not just a switch, there's alot of current that goes through there, and it can burn out your switch (like it did mine :-\ ) And yeha, if you leave it on, and descide to tow a trailer 265 miles on the highway... yeah.. goodbye solenoid.
