Everything posted by Andyjo
Alright, so my dad's friend has this 99' Outback Legacy, and i helped him replace his front brakes and rotors, the problem is that how when going about 15-25mph (haven't tested higher speeds), the brakes make a knocking noise, with a frequency just about the speed of the wheel (ie: 1 rotation, 1 knock). We poped the wheels off and made sure everything was seated properly, and that all the bolts were tight, retorqued the wheels, and it still does it... any ideas or suggestions? ALSO, his ABS kicks in WAY to soon, like... almost to a stop and it'll kick in a little.
Ok, so i got my codes checked today (freaking fuel temp sensor...), i flipped the 4wd switch, and no new codes came up. I'm not sure if you run the 4wd, then turn it off and have them check if something will come up.. but with the switch on, and checking the CEL stuff, no codes poped up. SOOO, that means it should pass inspection if you don't hit the switch before you go to get it inspected
between tranny fluid changes, drive alittle, and crank the wheel all the way to one side and to a few circles, it'll get that grimmy tranny fluid mixed up real good Also, to see if you have an LSD (Limited slip diff), jack up the rear end of the car, and turn one wheel, if the other one goes the same way you have a LSD, if not, you have an open diff. (I think... or did i say that backwards... someone correct me :-p )
to post pictures click on 'Photo Gallery' on the top toolbar thing (the dark grey), then a screen will come up, just under where you clicked on 'photo gallery' there will be a yellow link that says 'upload photos', you can do it up from there, you can also make albums by going through the 'album admin' w00t! more lifted subarus! yay!
$1.84 Impreza
Andyjo replied to pappy52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
hey.. what's wrong with zip ties... they hold my bumper cover on -
I ment potsdam, because both Operose & I live there, that's 2 in one town... one very small redneck town
98 Outback
Andyjo replied to iathon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
changing your fluids doesn't change the gaskets/seals. -
Hummer H3
Andyjo replied to PetterFan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WRONG The new hummers are not equipt to go 'offroad' i mean foresters arn't either, but they'll still do better than those large pieces of trash. -
Hummer H3
Tell them Hummers suck, and make you look like a prick if you drive one. End of story. -
As you can see in the title, i'm cheap, and have a bunch of old brake pads with about 85% of their pads left, i replaced the old set because ONE pad was wearing out faster than the others (sticky caliper slider thing). So i fixed that and put on the new pads, but now it's doing it on the other side... so i was just going to pop off the caliper, cleanup the sliders again and throw on an old pad.... I know you're not SUPPOSED to do this.. but i'm a cheap bastard.. am i going to warp my rotors, or mess up anything by doing this... i mean.. the pads are still good, they just need a little breaking in (get it.. ohh... i'm funny ), maybe a nice trip to the highway with the brakes engaged... hmm.....
Sounds like it works good! =) Now it seems that Potsdam NY is the new hot spot for 4wd 4EAT Subarus!
with the wire cut you're in 4wd, with the wire connected you're in AWD so, if your switch is in the 'ON' position, you will be in AWD, in the 'OFF' position you will be in 4wd. You might want to solder the connections eventually, because you don't want something happening and have it jump into 4wd on the highway/whatever. You also might be creating more resistance than the TCU is used to, and piss it off somehow. Most Stuff, after using this mod for about a week (less maybe?) i've discovered that if you run in 4wd, and then turn it off, the NEXT time you start up the car the 'AT OIL TEMP' light will flash a few times, and turn off. And the time after that all will be back to normal. I haven't gone to check if any codes have poped up with this yet... i'll have to head over to leb. and goto an autozone and play with it while they check for codes.
