Andyjo
Everything posted by Andyjo
  1. I think they are, i believe i saw some at advenced auto last time i was there, i checked out the backing and they looked similar to the stock subi bulbs.
  2. you just answered subie94's question. The reason i have the T is so that i can plug the snorkle in rain/snow situations where water would possibly get in. It's just a threaded cap that i can throw in, the intake on the inside is also threaded, so when i go swimming i can just plug up that hole w/ the same cap, and use only the snorkle. It was also requested by my girlfriend that the snorkle be removable... because she wasn't very fond of the idea in the first place, so the joint right inside the fender it in place w/ silicon gasket material, so i can just pop it out whenever i need, and throw a rubber stopper, or something like that in the fender hole. It runs very nicely with both ports open though
  3. WoohoO! it's done, and painted pretty black. I still need to go re-sand it and paint it again. it works oh so well!! oh yeah.. bending 2" sch 40 pvc is not fun! now i just need to wait for the water to not be frozen to give it a test run!
  4. Siping? sorry, i don't know the terminology, does that mean cutting the big treads into smaller ones? just slitting them into say 5-10 slits? if so, my snow tires are 'siped' and they're i believe there's a large advantage to them vs. some other snow tires i've used before.
  5. At least i threw some spray paint on it It looked really funny before that. The second hole looks pretty funny too... but whatever... now i just need a plow and some smoke stacks for my exhaust! who's got that picture of the old wagon w/ the smoke stacks...
  6. finding the wire is the hard part... i haven't gotten around to playing with it anymore, i got a little excited about building my snorkle If i finnish that up tomorrow, i'll try to do it up hard core.
  7. I'd say most subarus are pretty hard core in the 'toughness' factor. I offoroad my impreza (OBS) quite a bit, have smashed in many components on the underside, and it's still running strong... My recent problem happens to be the fuel sending unit... but i think that's because i cruched the gas tank w/ a rock
  8. So i had to up the pipe side to 2" PVC, opposed to 1.5", it the motor just wasn't happy w/ the 1.5". I also changed the configuration of the fittings inside, which ment i had to put another hole in the fender But no worries, I'll bondo up that hole when i'm done.... here's where it's at now, without the rest of the snorkle built.. this is just the pipe out the fender, with a cap ducttaped on
  9. make sure your bearings arn't about to explode... or else that could be a real sucky drive... check tire pressures, tire circumferences (make sure they're all within 5%). Might want to change your air filter (i did before my long trip...), uhh... drive safe, don't get dead.
  10. i like the jello idea. if not jello.. maybe some flour, or corn starch
  11. he's gonna have issues fitting it to your car if he doesn't have it The mudrat front bumper is just HOTT on a baja... the one on his website makes me want one sooo bad...
  12. Congrads blitz, you got post #100 on this crazy topic. just curious, what makes the 02' worse than the 00' ? On a note related to the topic, i believe i have found the currect bundle of wires, coming out of the tranny, but i have to find my voltmeter to test the prongs w/ stuff...
  13. you could put an in-line resistor on the line to the windshield wiper fluid pump... drop it's voltage.. get less range...
  14. So after talking to Austin for a while last night i decided that i'd throw a snorkle on my subie After about 1.5 hour in the hardware store playing w/ PVC pieces i got enough stuff to keep me busy for the afternoon. I only got the internal stuff worked out tonight... the external will have to wait till after xmas. I want to be able to take the snorkle off, so that's why where's a T in there, with all sorts of threaded crap everywhere. Here's the internal workings.... Here's it after i "put it in it's place"... required some hack saw & hammer action. Here's the hole w/ the pipe plug in it.. the cap is a little large, and the fender didn't want to go back on w/ it on there.. hmmm... i may have to re-think the directionality of this system... More to come!
  15. i think subieclimbs is useing them (King Springs = Scorpion Spring) on his outback. I wanted to get a set for my impreza when i lifted it, but my funds were lacking for the springs very hott. i can't wait to get my taller springs, and 28" all terrains
  16. Because i'm a nerd (Engineer). That's about it... I'm thinking i'll get the 3 pole switch, and just run the 2 other positions (Variable & 4wd) to the same resistor, for now, just incase i get a sudden urge to play w/ the variable split at some later time.
  17. Here's the King Springs Site: http://www.kingsprings.com/ Here's their coil spring catalogue: http://www.kingsprings.com/kings_master_catalogue.pdf The subaru stuff starts on page 10.
  18. I went to the local shop and asked them if i could borrow the right tool for a day or 2, they didn't have a problem with it... because honestly, when do you ever use a 14mm allen tool!
  19. I think it's like 12 bucks! If i do it up before i leave for school i could get 2, save on shiping for us NH folk
  20. There isn't room for a full size space in my impreza :-\ i guess i could take the BFH to the hole in there... actually.. i think the issue i had when trying it was that the tire/wheel were too tall in the hole (i guess you could call it width... the 6.5" )
  21. Oh yeah, you're most likely going to need a shop to change out the bearing, because you're "supposed" to use a hydrolic press to get them in and out.. pain in the rump roast if you ask me. I've had it done 3 times now (twice they didn't know about the legacy bearing), cost about.. $300 labor + parts, but if you get parts via Jamie it'll drive your cost down
  22. sounds like a bad bearing, try turning one way, and then the other to see if the sound gets worse (turning while moving)
  23. i have that problem, it originated when i removed my drivers side rearview mirror (because i broke it off w/ a kayak...). When put it back on it started to howl, and i haven't gotten around to fixing it yet. I'm guessing a little silicon caulking or something will seal up the holes...
  24. it was like that in northern NY the other day, like you said, 1/2" of ice on the car... even w/ it running (after chopping ice for 1/2 hour to get IN the car) it took about 1.5 hours to get all the windows cleared off. But after that, ohhh boy was it fun to drive around
  25. gary, from your previous post, it sound to me like you did it? at least the AWD/4WD switch, work well? easy to find the wire harness? oh yeah, and if you throw the FWD fuse in, will the wire read 12v? that'd be an easy find...
