Everything posted by mtsmiths
Off Topic - Honda -old subaru owner
mtsmiths replied to robertwheeler's topic in Non Soob Cars and Bikes Discussion
http://www.msnbc.msn.com/id/20438234/site/newsweek/ (forgot the link) -
Hondas future? I might be interested when I no longer need AWD (like after we move to Molokai). -
Paint! 444
mtsmiths replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Use some polishing compound (wax free) on the entire panel before you paint, to removve the oxidation. Then after the paint has WELL CURED, do it again to blend it in. THEN wax the whole thing to seal it. It will look so good, you'll want to polish out and wax the whole car. -
I'll add Rislone to quiet noisy lifters ... otherwise, ditto.
I was preparing to wash The Pretty One's 'new' '06 Atlantic blue Outback yesterday afternoon. After squirting the usual dish soap and adding warm water to the bucket; I was led to add a couple cap-fulls of 'Spray-n-Wash' to the mix (hey, the bottle was staring me in the face on the garage shelf over the washer/dryer). WOW! A no-wipe, perfectly spot-free car. To test the concoction, I washed the Barbie jeep, which being black is a notorious spotter. Same results. Try it, you'll like it.
http://www.snopes.com/photos/accident/pedestrian.asp The pedestrian was a by-product, that almost didn't make it. When you see the vvideo you'll be amazed that he did!
Took the car to Subaru on warranty repair yesterday. All fixed. So, the solution to the late model headrest quandry is: 1. Locate headrests from an '05 or earlier car with matching upholstry. 2. Remove your headrest, and carefully pry out the adjustment bushings/ locking tabs (one per seat). If you break one you can order a new one, they are available in all colors. 3. Reverse the locking bushing to place thte tab on the correct side of the headrest post (the side with the notches). 4. Insert the replacement headrests ... done. Alternately, grind new notches into the post on the correct side. I would make the new notches between the existing ones so as to not weaken the post. You can now relax in the front seat without having your chin touch your chest.
I've installed several aftermarket sunroofs in various cars. I believe that the roof of the century series is wa-aaa-y too curved to accept an off-the-shelf flat sunroof. I think (although I've never been a professional body man, nor played one on TV) that you have only two viable options: 1. Cut the entire forward roof section out of an '00 - 04 wagon and take the headliner/bezels too and graft it into your car. VERY exspensive, and if done wrong an awful mess forever. 2. Sell your current wagon and buy one with a sunroof.
Instant follow-up: The local Subaru dealer just called me and they got the parts to make the '05 headrests work correctly in the '06. Here's the scoop. You can (sometimes) dig the plastic bushings and locking tabs out of the seatback and just turn 'em around and snap 'em back in. They ordered new ones 'cause they sometimes break when you're trying to get them out. So to put earlier headrests in just replace the bushings and snaps turned around the other way. Don't know the cost, this is a warranty job. Guess I won't be grinding the posts after all.
I like the idea of bolting a generic gunrack to a dog fence between the back seats and the 'wayback'. If you need (or want) something more permanene, and don't mind drilling a few holes, I've seen stationwagon gun racks mounted to the wayback side window frames, so that the guns are parallel to the side of the car.
Both of which beg the question ... WHY?
anybody ever put a wagon rear door on a hatch?
mtsmiths replied to Spiffy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, could you splice a wagon greenhouse/tailgate onto a hatch from the 'B' pillar back? Mind you that comment is made with no knowledge of the actual measurements. -
The Pretty One left for work early this am. WHen I went out to drag the garbage can up the hill I noticed a few drops of what I assumed to be water on the garage floor. No overnight puddle, just one drop every foot or so the length of the garage, then no more in the driveway. Came home at 6:00 ... still there, even after 100 deg heat all afternoon (prolly higher in the garage). Clear, slightly oily, viscous enough to retain a bead after all day, slightly acidic on the tounge and very salty, no metallic taste (yeah I'm old school, when in doubt, 'taste test' ). Right along the driver's side tire line. No idea at all whatthehell it is.
