Everything posted by Island Roo
Carb Block VS. Turbo Block (EA82T Rebuild)
i was just answering his Q if heads were same
from what ive seen they are the same MPFI & Turbo
im thinking of using the carbed block also just dont want to tie up my turbo car w/ no motor while its snowing, gonna have to find a pair of turbo heads and all the other paraphnalia, i have 2 running EA82 carbed cars slready for parts
hub Q
cool was just wondering if i could drill my spare fronts for the back, and now i know!
hub Q
87 GL10 hub/rotor. are they the same front and rears?
4.44's are HERE!!
anything i can help with! so that might make me gods evil hench man? what type of car are the gears fromi mean a specific Subaru, like a WRX, or specifically cut for the EA82 trans? hows the research on the EJ22T going?
brat out of wagon
has anyone cut their wagon into a brat? asside from the fact that it wouldnt have the cool factor of an original brat, there are lots of wagons up(i have 4) in Canada but few Brats, also is there an 84 up 2 door sedan?
got my D/R in
replaced the clutch etc, slid right in, none of the tighten through the starter hole B.S., just the shifters to finish up, and strated the big one EA82T pass side head gasket, no coolant into oil no oil into coolant, would just pressurize the system, and could go out first thing next day and it would still have pressure
carbed block for turbo
didnt know yer Leg was turbo!
Ok..so what can i do to an EA82
what are the stock HP of each engine? the Na carbed na -efi and turbo?
thats good i wanna make some more
My first car...project
i was unaware that 93 had d/r trans?
TD04, how do you mount it in an ea82?
ya its gettin a little cold for that kinda tomfoolery, im trying to find out which head gasket went pop and hoping its not a head, oh and then the D/R swap, bought me a car trailer today
i have to do my turbos head gaskets and have a carbed block(not here yet) and was gonna swap for a bit of extra compression, is there a spot for the knock sensor and the crankcase vent hose right beside it? thanks
gotta gremlin
have you unplugged any connections? i would get the battery checked and clean the batt terminals , dont overlook the easy stuff
Here she is...
looking good! wish there were rust free brats up here or any brats for that natter
Vanislru- dont you mean IF you get it installed?
yota aluminums + studs
they dont match, but i still have the Isuzu rims they are only 6" wide w/5" backspace compared to 7"w/ 4.8" backspace but less work and a bit nicer looking, but the trade off is 1" wider stance, first i have to get the bad camber angle figured out(no i dont have the 4" lift block in backwards) toyota wheel: Isuzu wheel:
ya gonna have to swap it all
ya but these are the original alums that had the washer style wheel nuts
anyone running yota alum rims. 1st you have to run the yota wheel nuts right? so the question is when i redrill rotors do i have to use yota studs or subi studs gonna work?
Special CV tools
i use a composite hammer, i have a nice tool for pulling the outer back through the bearings, it was originally for Suzuki LJ80 front diff but i modified it, i'll take a pic, it sure makes life easy
EA82T won't budge by hand... FIXED!
the diesel will work like a fine oil to free rings etc in piston area
sounds like you have the basics covered, you may need to pull the heads and check the pistons and rotating asembly. You could pour diesel in the cylinders and let soak a day or so, how long since it actually ran?
Allied Armament Customer Pictures
i'll get on once i get my rims and tires on
