Everything posted by Scoby4wd
Sticker removal
Use the rubber wheel. I took my entire Brat targa strip off with one recently and it was super easy with no paint damage.
EA81 - fuel pump carb prime issue maybe?
interesting I hadnt considered that it is flooding. I will check when I get home.
Hi All, When I first got my Brat, I noticed if it sat for a while it would take a bit of time to start. Basically it would just crank and would generally take 30 seconds for fuel to make it to the carb and startup. After initial start, future starts would be quick while using it until it sat a while. However this past weekend even if it only sat for a few minutes, it would take a while cranking and I would generally have to floor it to get it to start. Once started it runs very well. Running a stock Hitachi carb Any suggestions? Bad fuel pump or something else? Thanks
Brat jump seats for sale
Would be interested if you can ship to NY
Gabriel struts for 4wd with ride height adjustability
This is true as well.
Subaru GL-10 Classic Car Licensing
Yep I registered my Brat the same way in NY. Alot of classi car insurance companies wouldnt insure old Subarus I found.
thought about buying a set of these but read some bad reviews. You can find them on ebay. Model is Gabriel G55726
Careful what you wish for-89 gl 3 door
would you sell me that grill?
Any Interest in All The Hitachi Carb Stuff?
pm sent
A/C question
So I can confirm the compressor is cycling when set to heat. Does anyone have a wiring diagram of this system? I couldn't find any type of controller anywhere, unless it is part of the dash controls.
A/C question
Ok, so maybe my system is running normally. Ill have to let the heat run for an extended period to see if it is actually cylicng the compressor. thanks for the info!
A/C question
I have a question about the factory Subaru dealer installed A/c on my 86 Brat. When I initially brought her home, the blower did not run. To fix, all I did was clean the contacts on the fuse and relay that is attached to a bracket on the passenger strut tower. It is definitely the genuine Subaru system and not an aftermarket setup. While I was testing, I noticed that no matter what setting I had the control slider set to, whether it be heat or a/c, the a/c compressor always kicked on. I dont think this is normal. Does anyone have any suggestions to troubleshoot?
Wanted: center wheel caps for mid 80's Subaru GL steelie rims
I just ordered a set of those caps from Subaru.
Stupid things you have done fixing or driving your subaru?
In high school I had an 89 DL Coupe 2wd auto that had been rear ended badly and repaired poorly by me. Since I only paid $50 for the car I used to beat it mercilessly. Once, I was pushing a train of shopping cars through a parking lot at high speed and rammed them hard into a dumpster. Another time I was pushing a cart which somehow rolled and wedged under my right front fender ripping it out. Another time I was rallying down a dirt construction road and hit a big ditch. The floor board in the back dented up and we hit the cieling in the car we hit so hard. When I hit the gas it wasnt moving, but then I looked down and it had popped into neutral. I put it in D and off we went. Eventlly the hub splines stripped out and I junked it, but the damn car ran great with only 78k miles.
My new Brat
I definetely will. On another note I saw an old post that said you have some jump seats for sale. They wouldnt still happen to be for sale, would they? Thanks!
How to remove mouse nest/debris from around heater core?
does anyone have a how to for removing the dash? Specifically, I just want to remove the soft dash top from my 86 Brat and replace with one I have in my Hatch which is in better shape.
My new Brat
Did not know about either of those shows, I usually go to Bear Mountain and the small car show near Home Depot in brewster on Friday nights. Ill have to check those out.
My new Brat
Yep its the factory bumper, with the little 5mph cushions removed. US had different bumpers than Australia.
My new Brat
Thanks guys The seal replacement wasnt difficult. Removed the radiator fan and the skid plate. To take off the crank pulley, I got a breaker bar with a pipe on it and braced it against the ground, unhooked the coil wire and blipped the starter. The nut unscrewed by hand at this point and the pulley comes right off. Used a universal seal puller to remove the old seal and then carefully worked in the new seal by hand using a large socket to keep it straight. While I was in there I pulled the oil pump too.
My new Brat
Thanks alot guys. I thought it was a steal, I paid $6k for it. Paint is definitely original and I dont doubt the mileage at all given the condition. The targa stripe is in rough shape, I am debating replacing it. Not sure if this is a good idea or not. I see a nice repro is available.
My new Brat
Thanks. Im not sure where the build sheet was originally, it was given to me already framed. I'm pretty grateful to have it, I think its a really cool piece.
My new Brat
Hey guys, Joined about a month ago after having bought an EA81 hatch. Because of my rekindled love of old Subaru's I joined some facebook groups and happened to find this 86 Brat for sale. I've basically wanted to own a Brat forever, so I couldnt resist. So far I have resealed the oil pump and installed a new front crank seal, fixed the fan blower motor, installed a new dist cap and rotor, and put the original wheels back on with new trim rings. Planning to do the oil pan and valve cover gaskets maybe this weekend. I'd like to add jump seats at some point but otherwise Ill keep it stock. I have the original window sticker which is pretty cool. It has no rot and almost no rust, which is amazing since its always been in VA and PA. Interior is original and in excellent shape. Paint is original too. Only has 80k on the odo and runs great. Gets alot of attention and someone already offered to buy it, but Im keeping it.
Are the center caps actually blue or is that just like a protective sticker over the emblem?
Beauty rings for wagon wheels
Thanks I didnt realize I could just buy a standard set, wasnt sure if it was subaru specific.
Have an 86 Brat and I am wondering if anyone knows where I can find beauty rings for the wheels? Thanks alot John
