Everything posted by michael appel
ea81 axle eater
I agree it is the exhaust and check the camber it has a partial issue there
27x8.5x14s on 93 Legacy w. 2" strut lift? Rubbing?
most tire shops will allow you to test fit the tires first before buying I would suggest doing it this way they can order the tire and have them sitting there for you
Lift kits
60 bucks plus shipping
Lift kits
website for everyone http://subarugllifted.webs.com/
Lift kits
no worries I just dont want you to overthink it is all 60 plus shipping
lift kit install
sweet we have to wheel together lol
Thinking about going solid axle
jeep axles are expensive to repair but a good axle non the less the transfercase from a jeep is very unreliable they have bad input shafts for the front and dana 30 and 35s are good but not past a 32 inch tire 33s are very hard on the axles and they tend to bend and twist under pressure they will need gusseting past a 32 there are alot of up grades but you will find that gearing is in the 3.08 and 3.55 gear ratio 4.10s were in the 4 clylinder maodels and hard to find. go yota they have 4.10 1986 and under and parts are cheap for them and stock can handle up to a 35 and they have better clearance and transfercases can ber modded for different gearing to more options and upgrades and really kind of the way to keep things cheap and they are very strong
2" lift help on rear
I used angle iron in the rear and used a press to get the shape i needed
Get what you want swampers will fit you just have to massage it a little bit lol But go for what you want because like he said you will regret not getting what you want
Lift kits
I have a friend running 2 inch crossmember and 4 inch strut it is doing pretty good Are these axles the ones ran when it was stock this could be the problem since they ore ran at a different angle now they are going to have problems when you buy new ones they will be use to running at the angle of the lift remember that the geometry needs to be good to if the car is still off camber it will pull the axle out a little more. But I can send you a extension and blocks if you like
Lift kits
You know you dont have to drop the crossmember but it you want to I have some made already you will need an extension to
Lift kits
anything that pulls the engine crossmember down will require a steering extension
Lift kits
Yo have a 2 inch already correct
lift kit install
Doin a sweet job post a full pic of car please im interested in how it looks also Im selling lifts if anybody chimes in for smaller lifts or just that alittle bit more I will send them to you
Lift kits
I just finished a forester a week ago
Lift kits
I could build you a 3 inch and sen you the steering linkage to 400 dollars
Lift kits
100 dollars yes I make the strut tops for both rear is super easy if you want to do your self not brain science lol
Lift kits
- Whos is this
wow its lifted now thats cool- EJ22 swap into 1980 brat ea71
ej will fit and it isnt hard you just need a adaptor plate and motor with wiring harness- Seattle area Ej22 swap-
I put up the write up in the conversion section Ill see if I can find it and send it to you I did my own swap took me about four days wiring only 2 days- Finally- my new 4wd D/R wagon!
need any help finding parts I make lifts for it let me know be obliged to help- I Finally Got Lifted! Now With More Vitamins! Pics!
beauty love the lift cant wait to see it in action- Contemplating a move...
Just do what you feel is cool Michigan is fine I only moved because of the cold but I missed it use to live in benton harbor myself I have alot of family in south haven and bangor and friends grand rapids and kalamazoo lol- Brought home another one...
Beg to differ had all the wiring ran out and running good within a week more like 5 days at the most - Whos is this
