submonkey
Everything posted by submonkey
  1. The headgaskets were done before I bought car and I don't have any paperwork. Was just wondering if it's common practice to do them while they're there.
  2. MY car a 2000 Legacy GT had the headgaskets done under warranty(previous owner). My question is it common practice for the dealers to do the timing belts when they do these warrantys? My car has 94k and I just trying to figure out if the did the timing belts already
  3. Good rule of thumb is. Euro: Bosch Jap: NGK or Denso American: Who cares
  4. We'll I have a 2000 Legacy GT and I'm getting 17-18mpg all city:confused: So if you find something that helps please post it!
  5. I guess it's not to far off then. One thing I do notice is the gas pedal is fairly stiff, so it seems to take off pretty quick as you need to apply what seems like alot of force at the start(compared to Volvo atleast). Maybe I'll try lubing the cable to allow easier modulation. My quest will continue I guess.
  6. That maybe the case (wifes D.D.), just Put a botttle of techron in and will see if it helps.
  7. What em I missing! New plugs, air filter, O2, all done. Runs great just can't get better then 18 city, I was hoping for 22 or so. On a side note my 95 Volvo 850 T5 wagon gets about the same but has a 110 more HP's. Any suggestions? Thanks Jay 2000 GT, Auto, 91k
  8. Thanks guys looks like I can get one from 1stsubaru for about $96 so will do that.
  9. We'll I'm getting 17mpg:eek: I checked plugs and they were new autolites, changed them to NGK V powers and new air filter. It's got 90k so I'm thinking might be time for a O2 sensor. Found a Denso for $95 are these any good? wheres the Best place to get a cheap one that works good. Thanks http://cgi.ebay.com/ebaymotors/SUBARU-IMPREZA-LEGACY-OUTBACK-00-02-OXYGEN-SENSOR-O2_W0QQcmdZViewItemQQcategoryZ33557QQihZ013QQitemZ230009354348QQrdZ1QQsspagenameZWD1V
  10. We'll I've posted a few times about older GT's and decide to get alittle newer one. 2000 leg GT wagon, 88k for $9200 good deal? This is my first newer style Suby, so probably will be hanging out here alittle more. Anyways pretty excited even though it's the wifes. Jay
  11. I don't think so it was pretty loud. I really didn't notice it at first start-up, then test drove about 2 miles stop and heard it. Was reving it from under the hood and it was very audible sound from 1.5rpm to about 3krpm then would go away. No sound at idle though. It's to bad it was a nice looking ride.
  12. We'll it was warm after test drive and was still there. Checked the oil and it was new, but appeared to have too much in it! Dealer said that the head-gaskets are good). I guess I'll just keep looking.
  13. We'll I just checked out this 97 legacy GT with 102k. When I first started it everything sounded good. Went for a tset drive and heard a sound from the engine compartment like knocking or something. Open hood, sounds fine idling, but when you give it alittle gas between 1.5k and 3k rpms it sounds like it's knocking or detonating or ? It' definatly loud and disturbing but goes away at about 3k RPMS. Just wondering if this sounds like a common problem (easy fix) or should I run away fast. To me it almost sounds like the timing isn't advancing right or something. Anyways we wanted to buy it until we heard that noise. Any insight would be great! Thanks Jay
  14. O.K. I've done some searching. Would it be safe to say that at 104k that it's either already had a headgasket failure and replaced with improved gasket? Or if it hasn't then it probably won't have a head gasket problem. Any insight would be great.
  15. We'll I'm considering buying one for my wife. It has 104k, auto, power everything etc.. They(small car lot) want $5999 for it. What would be considered a good price? And what problems have there been with these motors I.E. headgaskets, Bad tranny's, anything that I should be aware off. Thanks for any info. Jay
  16. Instead of a throttle pull, i use a long scraper wedged between seat and gas peddle. I seem to have same problem. Good luck Jay
  17. I know the feeling, I'm german car guy. So i drive my wagon for practicallity and my older bimmer for curve carving. Jay
  18. I've heard good things about a product called POR15, basically wire brush rust away then add this product and paint it will eliminate the cancer. I'm in spokane to and you can buy it at KC auto-paint supply. Jay
  19. That guy walked before he talked nice!
  20. Talk is cheap it's free. If you want to take 6k and build something fast then do it instead of talk about it. Personally even after 6k your still going to have a car worth about $1500. My 02
  21. I used a dual a-pillar from a honda in my wagon, don't know if a rx is different. Looks good with alittle trimming.
  22. I've used the steam method and it does work. I had a bmw 2002 with dual 45mm webers on it that made alot of carbon. Spray bottles work good
  23. Just wondering if anyone knows the diameters of the turbo intake and the 85/86 vane style maf? I would go tear it apart but my son won't let me.
  24. I to used that kit with no problems.
