8
You can do the head without pulling the motor, however it's a little more cramped. You're probably right about it being a valve type issue. The bottom ends tend to be pretty stout, but without removing the head, you really don't know. The CEL isn't going to be displayed because OBD1 ECU's are a little limited, and if the issues is mechanical, the ECU isn't going to really know that anything is wrong. Newer OBD2 ECU's that detect misfires on particular cylinders would probably have thrown a code. Just curious....how were you pulling the codes from the ECU? I've got instructions on my site www.surrealmirage.com/subaru/engine.html Also, here's some pics from my engine rebuild, which may give you some idea of how things are put together and confidence of doing the work yourself. http://www.main.experiencetherave.com:8080/subaru/images/ej22t/
The oil separator goes on the back of the engine. Here's a pic http://www.main.experiencetherave.com:8080/subaru/images/ej22t/05/DCP_4421.JPG Here's a pic of the plastic separator http://www.main.experiencetherave.com:8080/subaru/images/ej22t/04/DCP_4381.JPG What it does is help reduce the oil vapor the crankcase blowby gasses. It sort of performs a similar duty as an oil catch can, by providing a baffled restriction for the gasses to go by/around.
Found the info I was looking for today when I was testing my own fuel sender issues. The test does work, I tested it on my car. The only issue I can see is that it sounds like the newer cars do not have a separate device to turn on the low fuel warning light like the older cars. Anyway, here's the scan http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Legacy_Low_fuel_warning_light_test.jpg
Nope....the neutral switch does not prevent the car from starting. The neutral switch tells the ECU when the car is in neutral so the ECU adjusts timing and what not so idle remains steady. It doesn't really do much on a MT, but on an AT, it does. The clutch interlock system prevents the car from starting without depressing the clutch.
That'd probably be a good idea. How do you currently have the oil pickup configured? Is it stock? Are you using the stock subaru oil pan? There is a new oil pan design that has a secondary set of baffles. You can see the difference in these pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/06
There's a guy that does amazing dent removal down here. I had him do my car a few months ago....then about 3 weeks ago so asshat at the airport put a huge ding and gouge on my rear driver's side door. I had the ding removed, but the paint is still buggered. Freakin people need to be slapped around!!
What sort of pressures are you seeing out of that engine?
Replace the knock sensor first. The plastic gets old, cracks, and the sensor shorts out. The O2 sensor may or may not be bad, but if you have not replaced it and your car has higher mileage, it'd be a good idea to replace it. The idle switch is built into the TPS sensor, and you can adjust the TPS to properly set the idle switch, if it needs to be adjusted. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/TPS_testing3.jpg What I recommend you do is clear the ECU, drive the car around, and see what codes come back.
Yes connect the two black connectors together. If you've had the battery disconnected from the ECU for an extended period of time (hour or so) more then likely any stored codes have been erased. You don't need to start the engine to pull the codes, if any are there. Just put the key in the ON position with the black diagnostic connectors connected.
