8
I will tell you this regarding the neutral switch. I tried testing it like you did, and didn't get squat when the trans was out of the car. I don't recall if I retested it when it was back in the car. Do your reverse lights work? If so, temporarily swap the wiring for the reverse lights to the neutral switch. The reverse lights should go on when the car is in gear. The cruise switch should be independent of what you swapped in. Have you checked all your fuses?
http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
Glad to hear it was just the sender.
2007 Legacy
Legacy777 replied to mystro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You may want to pick up the new subiesport magazine. It talks a little bit about the new legacy. Also, you may want to check out www.legacygt.com/forums -
moon roof?
Legacy777 replied to treeripe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, you can have one put in. Back in 02, there was a guy locally here in tx that had one put in. You just need to find a shop that does that kind of work. -
Yeah I hear you. The auto manufactures have changed. Even the japanese manufacturers. They have cheapened things since the early 90's. There's little things on my car like the strut covers in the engine bay that they stopped using on the 95 & later cars to reduce costs. Thanks for the compliments on the Legacy. it's undergone a huge transformation. The car was originally a FWD, normally aspirated, & Auto trans. It's now AWD, 5spd, & turbocharged. I'm the process of putting in a new turbo & air to water intercooler. http://www.main.experiencetherave.com:8080/subaru/images/td05/ The car has been across country, PA to WA four times, I drove it from PA to Memphis, and memphis to Houston, and Houston to Seattle and back. It's had some road time. However with all the performance upgrades I've done, it's lost some of its road manners. Josh
Pretty much anything will fit for the 94-01 impreza. The body style is the same. It's funny you mention that all you find is WRX stuff, because the 98 and later Impreza RS was what probably gained subaru the popularity for the big wigs to bring over the WRX. NASIOC used to be nothing but owners of cars like yours.....look at it now. There is stuff available, you just need to search around. These cars are like legos, so don't be discouraged if you don't see something specifically for your year and model. Depending on what you find, the chances are it should fit other models/years. If you have a question regarding something, just post. You may want to check out some of the vendor's/links on my site. www.surrealmirage.com/subaru Josh
More then likely different engine connectors. Hell....between the first gen legacies, there were different harnesses between the 90-91 MY's, 92-94, MY's, and 91-94 turbo MY's. Your best bet is to reuse the engine harness for the car that the engine is going into, and just splice any needed wires into the engine harness.
If it's at the same location as the stock one, it should be reading the pressure at the correct spot. As for pressure. The factory manual lists the following info for the pump. @ 600 rpm 14 psig 4.4 qt./min @ 5000 rpm 43 psig 11.10 gal/min The relief valve set pressure is 71 psig. This information is for the ej22 normally aspirated motor. Something definitely doesn't sound right. Maybe a bad gauge, or something didn't get put together properly.
Yeah that does seem rather low. Where do you have the sender installed?
