90
nothing wrong with a small rant or two. I feel pretty much the same regarding newer cars... newest we have here is a 2006 H6 LL Bean Outback.. still going along pretty well.. has a periodic CEL, nothing of any significance, but enough to kill the cruise control... pull out the code reader, clear the code, good for another month or two my daily is a 04 Forester & we have an 05 for parts (car was brought in to the salvage place my other half works to be scrapped - his boss let us have it for a parts car - only has 168K or so. bringing it home has already paid off... my front power windows crapped out - both of them... was the motors that died... pulled the necessary parts from the 05 and I have functioning windows again, YAY! kinda got bummed the other day... found an 05 LL Bean Forester for 500 - motor supposedly shot.. but found out it had been sitting in the weeds for at least a year.. all that damp is not good so we passed on it.
yeah, broken wires in that gaitor is a pretty common thing.. the other half's 06 Outback had a whole bunch of broken/damaged wires. In his case, rear defrost quit working, rear wiper quit, and the license plate lights no longer functioned.. when we dug into it, obviously there were several that had completely broken, and a bunch of others that were barely hanging on... ended up reworking all of them.
yeah, normally you would, in a dying situation... but i think yours is beyond that. and as you well know.. aftermarket alts are just crapola - hopefully things are not severely damaged. might also be a good idea to go thru main box & fuse box, make sure there is nothing is blown. keep us posted on the neutral switch.
interesting.... is my understanding that it should only be in open loop when engine is cold/during warmup.... once it hits full operating temp it should go closed loop and stay there, even in cold weather, until shut down and cooled off again. I dont think it has anything to do with the barometric unit (pressure), this is more a temperature related thing. temp sensor for ECU (or ECU itself), thermostat, etc - possibly O2 sensor(s)? hopefully you can get it sorted out soon.
yes, had (the one in my avatar).. it has since gone on to another home, and yes, it was up there in mileage. Now driving an 04 Forester, silver in color thinking that would be a good idea, just to make sure. and if i recall correctly, it is also recommended to chase the threads in the block, and thoroughly clean the bolts... never done a head job myself, but i do read a lot. lol
you can get brand new stuff from Rock Auto for around 900 bucks. i personally would go with the walker SS exhaust kit - includes everything but the cat - and then get the appropriate cat to go on your car - also avail at RA, but sold separately.
- 2 replies
- exhaust
- exhaust system
(and 2 more)
Tagged with:
finding the correct line can be a challenge,... they are not all listed on the same diagrams... look for "water pipe" under "cooling system" for the one on top of the block..... and the one at the front, that runs vertical, is listed with the water pump... (i think this is the one you are looking for?)
CV Noise
heartless replied to sunraker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
a mm or two is not going to make any difference as far as the axle goes - a cm or two would be more obvious. worn bushings are not going to cause axle noise as you describe - the control arm would have to be significantly moving/ready to fall off for that to happen. a bent rim can be caused by a multitude of things, including potholes, curbs, being run into in a parking lot, etc. Body putty can also be the result of something relatively minor such as being run into in a parking lot. again, not sure what you mean by "play in the shaft" - the central part of the axle is a solid piece of metal, with joints at each end.. inner and outer.. and they are designed to have a certain amount of wiggle room. I am going to suggest that you thoroughly inspect the inner wheel well liner... look for any rubbed or worn looking spots.. cracks.. etc. Turn the wheels to where you would typically hear the noise, and check tire clearance with the liner.. try wiggling the liner, too... see if it is loose anywhere.
