Everything posted by Brumby Boy
What it should of looked like.
Brumby Boy replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats sweet i would definatly buy one of them ************ id buy 2 just for fun. no seriously i live in tropical north queensland in australia and there are brumbies running around every where. my dad use to spray sugar cane for alot of the farmers around the area and every one of them that has or does owne a brumby has said that the most stupid thing subaru has ever done was stop building the brumby. they also said that if they were to build a new brumby they would buy it in a heart beat. and personaly i would like to have seen the Baja brought to australia they would be good fun and handy:D -
Tell me what you think
Brumby Boy replied to Brumby Boy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah i had a look at them the other day and i realy dont want to justify that sort of money plus id rathed do the engine build myself as a learning experince. -
Is it a cicking type toise?? if so it is probably a cv but you say that it is still there even when there is no drive from the engine on the shaft. Check your wheel bearings by jacking up your car and butting the car on a jack stand and grabing the suspect wheel at the top and bottom of the wheel and wriggle it if it moves excessivly it it is probbaly your wheel bearing. Is your cv nut on the end of the shaft loose? if not that could be your problem right there. i had that trouble at work one day on a 91 RS turbo liberty. i thaught the wheel was about to fall of cause the wheel bearing was that far gone but then i grabed the impact gut and tightened up the cv shaft nut and that was that problem fixed
Rear jump seats for brat/brumby
Yeah thanks for the pics would it be possible to get some pics closer up and of the seat mounts and the belt mounts. would any 1 be interested in shiping a set including belts to OZ?? If so how much do you want for them?? -
Thank for all your help this should all be very helpfull but maybe ratty is right and i should just do the EJ22 conversion but if i go that far i will be turboing it with a worked EJ25. -
Thanks looks like i'll need some big $ and an engineer
Hay i want to lift my brumby like 12 - 18" but i want to do it legaly does anyone know how this can be done in OZ??
Where to get Weber adapter plate?
Brumby Boy replied to LostWater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you know how to weld you could build it yourself fairly cheaply -
Hay have you thaught about building a custom manifold to take the webber? check this site for some info on this mod www.subarubrat.com/engine.htm -
oh did i forget the cam regrind my bad
Thanks a lot man
Brumby Rear disk brake conversion
Thanks does this mod improve braking, i would asume so -
Hay is it possible that anyone could send me some pics and details on the rear wheel disk brake conversion so i can do it to my brumby??? any help would be greatly appreciated.
Looks like i'll have to go see the transport department l8er on 2day then. is there anywhere i can get them from for a decant price???? i ar rather curious. if anyone has any pics of these seats could they sent a few to brumbyworld@hotmail.com it would be much appreciated -
hay tell me what you think, i want to build a performance engine to put in my brumby. ultimatly i would like a 500Kw EJ25 twin turbo but for now i want to build a performance N/A EA81 with the current motor i have to minamise fuss. this is what i have in mind. Boreing, stroking, full head porting and polishing, custom intake and exhaust manifolds, webber carb, titaunimun valves and heiver valve springs, stronger con rods and push rods. i'm hoping to get at least 120hp over the standard 60 - 70hp. so let me know what you think and im open to sugestions. and for thoese of you that are going to ask why an EA81 to thoes i say because i can and want to work on a push rod engine
So are they road legal over in the states and would they be legal in australia and if so would i be able to get then in australia????? -
Whats the story with the jump seats in the back of the brat/brumby can someone explain the purpose of these seats to me please :-\
timing betl broke = bent valves the way i check is to renove the roker covers ond then the rockers ond cams so all the valves have to be open then i gut s spark plug of the porcilin etc so im lift wtht the bit of metal that screws into the head then get a metal hose fitting that will jam inside the gutted sparkplug then make sure it is sealed then get some hose and slip it on the fitting make sure its sealed then screw it into the hear and blow in to the head and if you can blow continusilay through the head the valves are bent if you cant the valves arn't bent
if you do it send me some pics if you don't mind it would look mad i'd love to see it i thaught i would have to get a full custom kit made if this works maybe not:headbang:
WHERE CAN I GET MINE?????????????
WRX suspension into a brumby, HELP????
Brumby Boy replied to Brumby Boy's topic in Subaru Retrofitting
Thanks a lot this should help me no end!!!! But no pic's hay??? Will the xt6 rear hubs bolt strait on the brumby???? -
Yeah thaught so
