Everything posted by Dr. RX
hello everyone
Patti, welcome, I'm surprized that Austin and you haven't stopped by, but then I haven't seen much of Austin since he started working at Carter's. I wasn't sure which Matt you were talking about, but now I understand.
ej20 in a old school subaru
Hey Austin, show me where the EJ20 and EJ25 are wider then the EJ22 or EJ18. I have an EJ20, EJ22 and EJ18 at my place if you would like to come over and measure. All of the EJs are narrower then the EA82s and only slightly wider then the EA81s. There are many EJ conversions in Australia, but not many in the USA, and I did one of those. The biggest mechanical headache is the tranny crossmember, you will have to modify a Legacy or XT6 crossmember, the front bolts right in, but that back needs to be narrowed. Like Austin said, you'll need turbo axles for the tranny. Be sure you know the tranny ratio, there are many different ratio for the EJ trannys, 3.90, 4.111, 4.444, 4.154, and I think there is another. Make sure you get a match rear diff. Ah yes, the ECU and wiring, I used an after market HalTech unit that came with a wiring harness for the engine. If you have a donor car, you could replace the entire front wire harness in your car with the one for the EJ series car, then you'd just have to tie in the rear wire harness to the EJ harness. It can be done, it takes time, don't hurry it, think things over before jumping in, and you should come out with a nice rig. But don't ever expect to get out of it what you put into it if you sell it.
Thinking of dynoing the RX...
DanBob99, the problem with a mobile unit is that it is usually only for 2WD (front or rear), the unit at FAME is a 4WD unit, and that last time I saw Tex's car it was a Fulltime 4WD, and you can run those on a 2WD unit. Tex, baseline??????? Your car?????? NOT!!!!!!!!!!! But if you wanted to see if your mods did any improvement, it would be good to run it before. Just let them not that you are trying to get a baseline for your car and they won't do any tuning. That is what eats up the time. I had them sort out UltimateRXs wiring problem for me, but we didn't get it running well enough to put it on the dyno. That would have been interesting. Witte, I think there is a 4WD dyno somewhere in the Portland area, but it sounds like you are working for a place that has a dyno. Hey do you still have that Legacy 5 speed?? E-mail me if you do.
Steam from the radiator...
Have the radiator pressure tested, that will tell you a lot. Is it steam or just evaporating water??
Made it Home...:)
Sorry John, I mis-read Austin's post. I don't know what I was thinking, to think that Andrew would come all the way up to Austin's house to trade cars with Austin. Yea, what the heck was I thinking???
Made it Home...:)
John, I don't think that was Austin, I think it was HondaSucks.
What is the deal with Subaru dealer parts dept.?
It's not just the dealers, I've gone into parts stores and got the same lack of knowledge. One of my project cars about 10 years ago was putting a V8 into a Corvair. So I go to the part store and ask for a part for the V8. The first thing that ask is, "What car is it in?" To which my reply usually is, "It doesn't matter which car it is in, the engine was in many cars." So they tell me that they can't find the part I'm looking for because the computer need to know which car. So I tell them that it is in a 67 Corvair, so they look it up and tell me that the Corvair never had a V8, to which I reply, "Oh really, do you want to come out and look at one?" So I walk them out to the car, open the engine compartment (by the way, the guy is standing in front of the car waiting to look under the hood) and show them the V8 sitting there. They scratch their heads and can't figure out why the computer is wrong. Another thing that I can't figure out is why a dealer will have a web site, but will not give you web site prices when you stop in at the dealer.
Little Roo is on her way to mudrats to begain her transformation.
That's cool Zap, I saw a lot of things while on payote, but I never saw any angles, well at least none with wings. Looks like we agree on something else.
artists out there on the board
I guess you could call me a professional artist since I have sold three of my paintings and one of my sculptures. Haven't really done much lately, I've turned to other artisan crafts, like gold smithing, faceting, and opal cutting.
Fender flaring?
The best way is to remove the fender, use a forming bag and mallet, then smooth the surface with an english wheel. After i get my garage built, I plan to get an english wheel and a forming bag and several different shaped mallets. But that is still some time off. The front is easy, the rears, it might be better to fab a flare then weld it and cut out rhe old fender.
How do you tell if you have LSD?
Alpine Raven, NO RX had AWD, in 1987 the had what is called Fulltime 4WD, but that is not that same as AWD. There is an open diff in the Fulltime 4WD trannys that is lockable, in the AWD trannys there is a viscous limited slip center diff in the tranny. Goatboy, the swap is easy, I've done several myself, and have one to do for a friend soon. But you only swap the center section, you keep the ring and pinion from the 3.90. If you were a little closer, I'd love to show you how, but it's a 3 hour drive from Portland to my place.
The 3.90 is a pretty good sign that you do not have a LSD. For the most part, from the factory, Subaru with LSD's had a 3.70 ratio, here is what the label on a LSD looks like. It is larger then the non-LSD tag.
Autocross with the RX
Yep, that worked. I think I'm still waiting for th video to download.
Bumm, Geocities (aka Yahoo) won't let me view the pics in your first post. Saw the mpeg, looks cool, but looks like a lot of smoke on deceleration on the second lap.
pics of my 86 RX turbo
Looking at Warp3's RX leads me to believe that there were no side decals on the RX sedans. Nice ride Warp3, do I have your data for my database??
new subaru RX owner..looking for info
Thanks Andy, now I have two to update the RX database. Ben, if you go to my web site (see my signature block) and look for the RX spreadsheet, could you e-mail me that information shown there? E-mail to Corky , I have the VIN so you don't need to seen that.
Really nice, can you tell if it has ever been repainted? It looks the original color. There was a guy out here selling his 85 RX sedan that was the same color.
Thanks Ben, for all those concerned, it is a real RX, you can go to my web site and check the VIN if you want, but I know that since it has the 56B combination in the 6th, 7th, and 8th positions of the VIN that it is a RX. I'll have to try and find my 86 dealer broucher, maybe Qman can find his quicker, I seem to remember a small decal on the rear door down low, but I can't remember what it said, I know on my 85 and 86 non-RXs it say 4WD TURBO in red. These decals are no longer availabe for a dealer, I was hopingf to get a set from another board member who bought out a Subaru dealers old parts, but he never came through. I have a source that I could get those decals duplicated if people needed them. Good luck on the spoiler, the original one on mine has two large chucks missing like Skip says happens, I looked a long time before I found one in a wrecking yard and carefully removed it.
87 RS turbo 3-door in junkyard
TROGDOR, you mean to tell me that you think the Fox would build that car and then just let it sit around? No, he would go out a try to prove the it is everything that he says it is. Those boys with the gum ball machines on the top of their cars would love to bust him again, and with his record, it wouldn't be a pretty sight. So do you see the connection now???
Fox, you just are not understanding, from 85 to 86 the RXs (all sedans) had 5 speed D/R 4WD on-demand trannys, they didn't get Full-time 4WD trannys until 87. The differenece was that the RX (being a turbo) had a ratio of 3.70 and the non-RXs (and non-turbos) had a ratio of 3.90. There arr no center diffs in the 85 or 86 trannys, that didn't come along until 87, with the Full-time 4WD tranny, an 86 RX would have three positions to the level, 2WD (FWD), 4WD Hi, 4WD Low.
So why are you down on RXs?? Why don't you set you sights on beating a WRX. Sounds like to me that you didn't learn anything from your jail time. You are a marked man Fox, if I were you, I'd lay low for a few years till someone else takes the attention away from you, and then I wouldn't rush out there and try to get it back.
Ben L, could you send me the VIN of your car, or post it here, that will answer the question. I must say, it Foxes behave, he did get a lot of the info correct, he just doesn't know that much about that model changes that happened at the 86/87 model year break. For the record Fox, my 86 3dr 4WD Turbo had an analog dash, the back lights were white, my 85 and 86 GL and GL-10 turbos have digital dashes, their back light is orange, that is where I think you got the orange light info, from people with digital dashes. If it is a RX, 5 speed D/Rs are standard, so is a LSD rear diff. Fox, apparently you didn't read my post, because you state, "baut all you got out is the fact that they werent white in 86. ", I also took you about the trannys that they had in 86. Here is my 86 GL-10 4WD Turbo, it looks just like an 86 RX except my car came stock with air suspension, and a moon roof. Note the little spoiler on the trunk lid and the air dam in front, there is also a little aero kit thing by the rear door. This car now has the RX suspension, a D/R 5 speed on-demand 4WD tranny and a VLSD rear diff.
Heck Fox, if you put enough money into a Justy, it could beat a stock RX, so what is your point??? Actuallu we have a rally Justy out here that has the fastest times at most of the RallyX races, that means that it even beats WRXs and STi's.
Damn it Fox, if you don't know what you are taklking about, don't say anything. The guy stated that he had an 86 RX, they were only 4 doors in 86 and were available in many colors, the white only didn't start till 87. The dash is analog not digital, so I don't believe the light is orange. Being an 86 it will have a D/R 5 speed tranny on-demand 4WD, the Fulltime 4WD didn't start until 87. I know you think you know alot about these cars, but it appears that you are confused about the model years changes.
If it is a RS, then it is a 1990, not an 87. In last 6 months on the 89 production run, the RX was available in black, with gold trim, it was a true RX with everything the white ones had. If the badges say RS though it is not the same as a RX. It did come in either turbo or non-turbo like XSNRG stated. It is also rather strange that it would have an automatic and a LSD. If it is the turbo model, then it would have the same engine as the 87 through 89 RXs have. It would be a nice car, but definately no RX Killer.
