82glsw
Everything posted by 82glsw
  1. i got mine from advance auto it came with the pinch bolt castle nut and cotter pin. i guess i just got lucky
  2. If you are replacing the balljoint the will usually come with a new bolt
  3. Drove the car some more and the problem still exist now i get the check engine light but goes off b4 i get a chance to pull the code. Im thinking that the mas is going bad.
  4. very few rx's had cruise
  5. when u hook the pump directly up to the battery where do u hook it on the pump
  6. 12 volt isnt low that is enough to run the pump.
  7. if the pump don't work when plugged into the original harness u may a problem with that plug. had that problem on my 82.
  8. the fog lights are missing but if u look closely the mounts for them are still there.
  9. nipper is correct corner lights are just parking lamps. im sure it could be easily be wired to blink together though.
  10. Replaced plugs and wires today. So far its running good. Find out more once i get some more miles on it.
  11. When you inflate your tires you are suppose to go by the vehicles suggested tire pressure
  12. Finally figured out what the problem was. Wires for the lighted visor mirrors were touching. Once i replaced the wires put a fuse in and all is well.
  13. no service history is known before 138k. i purchased wires and plugs today will put them in tomorrow and post results if any.
  14. Ill try the plugs and wires and see if that helps will prolly be a few days till i get them. any reconmendations on plugs? i like running ngk but is there a certain one thats better to run.
  15. thats what im sort of leaning towards myself since im not sure how long they have been on. The oem wire are ngk correct?
  16. 150k i have not changed the O2 sensor since i got the car had it since 138k
  17. or at least use spell check
  18. yea blogs and hesitates then it will backfire sometimes
  19. it only does it under acceration. air filter is brand new. also has new fuel filter on. tank level makes no difference.
  20. if i were to give the car a tuneup would ngk wires from advance auto be suitable for the car. i know i read oem or magncor but i beleive ngk is what oem are
  21. Glad to hear you got the bulbs. as far as a grounding point im not sure what to tell u on that everything plugs into the black box above the glove box which plugs into the main harness running behind the dash. Id check to see if ur battery terminal connection are completely tight.
