82glsw
Everything posted by 82glsw
your motor will have no trouble moving the 17" wheels and tires. they should work fine there isnt to much of a difference in size. the speeddometer wouldnt be off by that much but some. Dimensions DimensionTire A: 185/70 R 14 (24 x 7.28 x 14)Tire B: 215/45 R 17 (25 x 8.46 x 17)DifferenceWidthSidewall heightOverall heightCircumference7.28"(185.00mm)5.10"(129.50mm)24.20"(614.60mm)76.02"(1930.82mm)8.46"(215.00mm)3.81"(96.75mm)24.62"(625.30mm)77.34"(1964.44mm)+1.18"(+30.00mm)-1.29"(-32.75mm)+0.42"(+10.70mm)+1.32"(+33.62mm) Speedometer Error Actual SpeedIndicated Speed with Tire BSpeedometer Error5 mph (8.04 kph)4.91 mph (7.91 kph)-0.09 mph (-0.14 kph)10 mph (16.09 kph)9.83 mph (15.81 kph)-0.17 mph (-0.28 kph)15 mph (24.13 kph)14.74 mph (23.72 kph)-0.26 mph (-0.41 kph)20 mph (32.18 kph)19.66 mph (31.63 kph)-0.34 mph (-0.55 kph)25 mph (40.23 kph)24.57 mph (39.54 kph)-0.43 mph (-0.69 kph)30 mph (48.27 kph)29.49 mph (47.44 kph)-0.51 mph (-0.83 kph)35 mph (56.31 kph)34.40 mph (55.35 kph)-0.60 mph (-0.96 kph)40 mph (64.36 kph)39.32 mph (63.26 kph)-0.68 mph (-1.10 kph)45 mph (72.41 kph)44.23 mph (71.17 kph)-0.77 mph (-1.24 kph)50 mph (80.45 kph)49.14 mph (79.07 kph)-0.86 mph (-1.38 kph)55 mph (88.50 kph)54.06 mph (86.98 kph)-0.94 mph (-1.51 kph)60 mph (96.54 kph)58.97 mph (94.89 kph)-1.03 mph (-1.65 kph)65 mph (104.58 kph)63.89 mph (102.80 kph)-1.11 mph (-1.79 kph)70 mph (112.63 kph)68.80 mph (110.70 kph)-1.20 mph (-1.93 kph)75 mph (120.67 kph)73.72 mph (118.61 kph)-1.28 mph (-2.06 kph)80 mph (128.72 kph)78.63 mph (126.52 kph)-1.37 mph (-2.20 kph)85 mph (136.76 kph)83.55 mph (134.42 kph)-1.45 mph (-2.34 kph)90 mph (144.81 kph)88.46 mph (142.33 kph)-1.54 mph (-2.48 kph)95 mph (152.85 kph)93.37 mph (150.24 kph)-1.63 mph (-2.62 kph)100 mph (160.90 kph)98.29 mph (158.15 kph)-1.71 mph (-2.75 kph)105 mph (168.94 kph)103.20 mph (166.05 kph)-1.80 mph (-2.89 kph)110 mph (176.99 kph)108.12 mph (173.96 kph)-1.88 mph (-3.03 kph)115 mph (185.03 kph)113.03 mph (181.87 kph)-1.97 mph (-3.17 kph)120 mph (193.08 kph)117.95 mph (189.78 kph)-2.05 mph (-3.30 kph)125 mph (201.12 kph)122.86 mph (197.68 kph)-2.14 mph (-3.44 kph)130 mph (209.17 kph)127.78 mph (205.59 kph)-2.22 mph (-3.58 kph)135 mph (217.22 kph)132.69 mph (213.50 kph)-2.31 mph (-3.72 kph)140 mph (225.26 kph)137.60 mph (221.41 kph)-2.40 mph (-3.85 kph)145 mph (233.31 kph)142.52 mph (229.31 kph)-2.48 mph (-3.99 kph)150 mph (241.35 kph)147.43 mph (237.22 kph)-2.57 mph (-4.13 kph)155 mph (249.40 kph)152.35 mph (245.13 kph)-2.65 mph (-4.27 kph)160 mph (257.44 kph)157.26 mph (253.03 kph)-2.74 mph (-4.41 kph)165 mph (265.49 kph)162.18 mph (260.94 kph)-2.82 mph (-4.54 kph)170 mph (273.53 kph)167.09 mph (268.85 kph)-2.91 mph (-4.68 kph)175 mph (281.57 kph)172.01 mph (276.76 kph)-2.99 mph (-4.82 kph)180 mph (289.62 kph)176.92 mph (284.66 kph)-3.08 mph (-4.96 kph)185 mph (297.67 kph)181.83 mph (292.57 kph)-3.17 mph (-5.09 kph)190 mph (305.71 kph)186.75 mph (300.48 kph)-3.25 mph (-5.23 kph)195 mph (313.75 kph)191.66 mph (308.39 kph)-3.34 mph (-5.37 kph)200 mph (321.80 kph)196.58 mph (316.29 kph)-3.42 mph (-5.51 kph) If your speedometer has been calibrated for 185/70 R 14 (24 x 7.28 x 14) tires, replacing them with 215/45 R 17's (29 x 8.46 x 17's) would result in the speedometer reading low by 1.71%. Odometer Error Actual MileageIndicated Mileage with Tire BOdometer Error1 mi (1.61 km)0.98 mi (1.58 km)-0.02 mi (-0.03 km)5 mi (8.04 km)4.91 mi (7.91 km)-0.09 mi (-0.14 km)10 mi (16.09 km)9.83 mi (15.81 km)-0.17 mi (-0.28 km)50 mi (80.45 km)49.14 mi (79.07 km)-0.86 mi (-1.38 km)100 mi (160.90 km)98.29 mi (158.15 km)-1.71 mi (-2.75 km)500 mi (804.50 km)491.44 mi (790.73 km)-8.56 mi (-13.77 km)1000 mi (1609.00 km)982.89 mi (1581.47 km)-17.11 mi (-27.53 km)5000 mi (8045.00 km)4914.44 mi (7907.34 km)-85.56 mi (-137.66 km)10000 mi (16090.00 km)9828.88 mi (15814.67 km)-171.12 mi (-275.33 km)50000 mi (80450.00 km)49144.41 mi (79073.36 km)-855.59 mi (-1376.64 km)100000 mi (160900.00 km)98288.82 mi (158146.71 km)-1711.18 mi (-2753.29 km)
You can try checking with this post http://www.ultimatesubaru.org/forum/forumdisplay.php?f=12 he has some good info about the clocks there
hard to shift and hard clutch pedal
82glsw replied to BlueRu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the cable itself doesnt fix your problem check the bushings on the clutch pedal. I had the same problem for a while then i replaced the bushing and cable with oem stuff and havent had a problem since -
82 GL 125k 89 RX 155k 91 Legacy 145k
SVX Lovers
82glsw replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
my friend has had to replace to diffs and they ran about 1000 bucks a piece -
SVX Lovers
The svx is a very good car my friend has four of them and they all run great. The only major problem with them is the diff usually takes a crap on them. other then that there just like any other subaru really depenable. I would love to have one but they are hard to come by in the york pa area. -
the 15 should be the fuse in the drivers side kick panel fuse box. as for testing the aftermarket stereo u can tie ur yellow and red wires together and hook the to a positive battery terminal and put the black on the negative. The unit will power up that way. that way you know ur aftermarket stereo works
Tachometer sticking when cold
82glsw replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my 82 gl wagon does the same thing but it doesnt bother me enough to worry about fixing it. if you know how to drive stick you dont need it anyway -
that site has to be a scam u cant add anything to a cart to buy. price is just way to low. i would beware of calling the number on the site
i dont know if its even worth everyone trying to help this moron out. he will just find a way to screw his car up. just let him do it. once he modifys something on the awd system and it breaks he will want to take it to the dealer to have it fixed and they wont do anything for him since he modified. then he will wish he had took everyones advice.
the other fuel filter is located under the car on the passenger side near the rear tire its mounted on a plate that u will have to take off to access
