82glsw
Everything posted by 82glsw
id take it off. brats look much better without them
This doesn't look good...
82glsw replied to Corolla Frenzy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks fine to me -
deffinatly put a aftermarket mechanical guage on. you will be surpised how far off the factory guage is. i just put one on my 82 gl and when the car is warm factory guage will read about 20psi and the after market one reads about 40psi
Alien in my driveway***Now I need HELP!***
82glsw replied to Turbone's topic in Non Soob Cars and Bikes Discussion
any new news on this project -
yea there are really 2 near me. just never had time or money to tear into them not to many people seem to know about the yard for some reason
not to upset u monstaru but there 2 of those cars in a u pull it yard near me the engines can be had for $130 a piece and the harnes run $20. just dont have the money to get any
the drain holes are located in the very front corners of the sunroof and there also some in the very back of the sunroof. never had any problems with the rears one. when i had a leak i tryed clearing the drain hole and couldnt get anywhere so i pulled the part of the inner fender out where the drain tube run and found a large build up of dirt in there. cleaned it out and havent had a problem since. ill try to post a pic of the drain holes later today.
ea71 usually rev it to about 6500 no problems as of yet
82 subaru gl sw 91 subaru legacy ls sw 89 subaru rx 01 hyundai tiburon
Old Gas - Problems, Tips, Tricks?
82glsw replied to Crabman's topic in Historic Subaru Forum: 50's thru 70's
I would drain all the old gas out and put new in -
Hopefully everything else goes well for you. glad to hear its almost out -
Dont let the car intimadate u there not that bad to work on. the first motor swap i ever did was a 91 mitsubishi eclipse with the same motor as the galant. if you take ur time it wont be bad at all -
As bratman said it has to come out as a whole unit. it is alot easier to take it out together then to seperate the tranny in the car. Make sure u mark all vacum line so they go back in the right place there are quite a bit of them on the 4g63t as for the wiring harness it will usually fall right back in place for each connection. -
Most likely the factory tape player will not work with the aftermarket mp3 player
legacy doors
82glsw replied to 82glsw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
thanks thats what i thought just wanted someone elses knowledge -
that is a good example of a donor car but i wouldnt offer him more then 400 for it
Torque Bind
Has anyone ever used royal purple automatic transmisson fluid -
If it were my car id work at to keep it going. at 203k its just getting started. As long as u have the time and the know how or someone who does it can be fixed. i fixed a 82 in far worse shape then that.
theres plenty of older subaru's on the east coast between myself and my friend we have 20 2 ea81's 1 first gen legacy 4 svx's 3 xt's 10 ea82's
Torque Bind
How much additive should i add to the fluid -
How Do I Delete My Account???
82glsw replied to pickle-rally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is the best board i have been. Hardly ever have to start a new thread because of all the information u can find by just searching
