Everything posted by BlindSight
Vac. leak, what is this part!?
yeah im in dallas tx.....so need the egr still...will try re-timing it next time I get a chance..has been about a year or so since the last time I did..and have done alot to it since then....so are you sure 18-20?..I remember looking up the specs in my manual and it did say 8.
the best subaru project from israel = must see this thing.
personally think the tail lights are kinda blah and the spoiler shouldn't slpe down so far...but other than that I think it is realy awesome...I mean....just because it is so unique and you know there isn't anything out there even slightly close to it.......kudos.
well after I fixed my idle problem the first time i noticed my car started backfiring when I would let off the gas to change gears...so you think maybe if I replaced it it would solve my backfire problem possibly?
Carbed EA82 87 Subaru GL Wagon 4WD 5spd Manual. This is the front passangers side of the engine bay...there are small holes in the bottom of this that air was being sucked through causing a really rough idle...im assuming there was something else on the bottom that came off but for nw there is a piece of tape accross the bottom....any way to fix this or what part is it so I can get another one?
Summer Lift Kit Group Buy
so when should we be expecting to recieving them?
yeah...really would be nice.
yeah...if it doesn't get in before the end of august I wont be able to drive my friggin car till december....so yeah...ill be realllllly pissed especially since I was told it would take up to 4 weeks.
lol yeah we have a hyundai accent coming in for 2 new tires sometime this week ...they locked em up and flatspotted them but other than that they should last a while so after we take them off im going to put them both on my spare steelies so ill have 2 just in case I HAVE too use them.
anything...lol I guess we all know why you call yourself shady.
ditto
anything?
will be waiting your response eagerly
I believe he said he was checking on the status of them yesterday so hopefully we shall here from him today since I suppose he didn't have time to get on and inform us last night.
maybe they dont have 3 bald/warped tires that could blow out at any moment?
alrighty, thanks...look forward to hearing from you wednsday night or thursday sometime hopefully.
yeah and again, estimate on when i should be expecting this...pretty darn important
Struts/Springs? Bilstein, Gabriel, Monroe? others?
and what do you mean by adjustableness...adjustable dampening or what? Personally a little bit softer than stock...stock....or even a bit stiffer than stock doesn't really matter that much to me...as long as its not a reallllly big difference but right now all of my struts are squeaky and not doing much damening and all of my spreings are nice and weak so the ride is pretty crappy. Doesn't really need to be adjustable as long as the ride isn't wayyyyy different from stock.
Anyone with pictures of two tone paint jobs? (loyale wagons)
yeah and with the white ringed tires it gives you an ultra-gangsta look
coolness, any estimate on when I should be expecting mine? pretty important...refer to my previous post if you didn't notice it.
Oil Pressure
before you shoot the pump..replace the sending unit...real easy to get too and just turns right off with a wrench or pliers even if your desperate...doesn't cost too much. Had the same problem with my loyale, everything seemed to be running fine but the pressure just started reading low, then eventually it started dropping to 0 at idle, I just replaced the little sensor/sending unit and it jumped back up to normal on the gauge. my $.02
what about springs?
need to replace all 4 struts as well as springs.
CF Hood Interest
Very interested in a hood with a scoop or spot for a wrk scoop to be mounted for an EA82.
Brat & XT6 CarbonFiber Hoods
Am really interested in a CF or even FG hood for my EA82, would also love some bolt on fender flares...I think the fender flares would be a big hit with all of the offroading EA82's out there, something so if we have to cut our fenders for a little more clearance it will cover the areas...nothing too huge but maybe an inch or two of added flare...anyways, any updates?
bumpage, any updates? Would it be easier if I called?
