105
hmmm, I think I once learned from someone here that soobs won't fire off the ignition if oil pressure doesn't come up to some minimum during cranking. I dunno if that's true or not - but it does beg the question, 'is the ECU having all it's logic satisfied to allow starting?'. Could be back to a crank angle sensor or even the aforementioned ground condition. many folks have solved problems by cleaning or rewiring engine and chassis grounds. I dunno
yeah we're good! hah! Probably a lot more miatas around than soobs (or maybe the break more often? *****ducking*****) anyway, often subtle changes in a sensor, or a small vacuum leak or something won't throw a CEL. engine temp sensors have been notorious for causing problems related to cold vs warm idling. I wouldn't rule out possible high voltage problems. If you pull plug wires one at a time while the engine is idling roughly, you might locate a cyl. that causes NO diiference when disabled. If so, that cyl may have a bad plug or wire or injector orsome other issue. Subtle and intermittent problems are the worst! I dunno
If it is under vacuum when you remove the cap, either the 'new' cap is bad or the line/dip hose associated with the o'flow tank is clogged. If the line were cracked, you may very well collect coolant in the o'flow that does not return, but there would not be a vacuum as air would likely be sucked in through the crack.
First - it isn't a joke, I just did it in my '06 WRX wagon. It will not disable the initial chime - just the repeat chiming. I used the 'on' postion. dunno if ACC works or not. I did the buckle/unbuckle starting immediately after switching to the 'on' (not starting though) position. I probably did it over 20 times in under 30 seconds, confriming that the warning light in the gauge cluster went off each time. It helps to sit on part of the belt after pulling it all the way out or otherwise prevent the retraction spring from pulling on you during the procedure. I postioned my right hand on the release button and concentrated left hand duties for insertion and 'catching' the tab when ejected after pressing the release button. I HAVE read of folks trying multiple times to get it to work. Perhaps I was just lucky. haven't tried it on the wife's '03 OBW so I don't know what years' cars this is effective on. fyi
yeah like they said, have a dealership flush everything, maybe change the oil. I suppsoe you could push for the gas station to buy some kinda extended warranty or put some money in escrow fro fuel system/emmisions work for a year or so. prolly need a 'mouthpiece' (lawyer) for something like that. Can you find the other folks thois happend to? maybe pool funds for a lawyer. I dunno
It is worth trying a 'gas dryer' if you suspect bad gas. Cheap and easy. Pulling off one plug wire at a time while idling, will tell you if the problem is specific to an individual cylinder. When THAT plugwire is removed, there will be no change in the idle - cause that cyl. was not firing anyway. If you DO have one bad cyl. the engine will likely die each time a 'good' cyl is diabled. Be careful, high voltage can cause you to jerk your hand away such that you hit something else and get a cut. If there is no definitive problem with a single cyl. likely it is a general air/fuel problem. Do you have a check engine light on?
Good info on the glass distortion. Also, some people develop headaches from 'outgassing' of plasticizers in new cars, or after carpet/upholstery work. I wouldn't discount the possibility of an exhaust leak either. My wife's last car, Ford Windstar van, would sometimes cause 2 fingers on my left hand to get numb on long drives. It had 8 way electri adjustable seats IIRC but I never was able to make the problem better. No other car did/does that to me.
Was there any tire/wheel installation done? Could you have smaller tires? I dunno, but this is a manual, and 'assuming other normal factors' the symptom reported is diagnostic for slipping clutch. Yes, if it's cable operated (someone here should know) it may need an adjustment, less likely with hydraulic but perhaps there is a blockage not releasing pressure completely or something. I'm going with Occam's Razor til more info is introduced. She said - what 115K? has it ever had a clutch? Wouldn't it be due for one? I dunno
So, in theory and as reported by some folks, a tranny 'flush' seems to sometimes be able to free up a solenoid stuck closed by sludge/gumminess. Once the pressure can be released, a 'good' clutch pack will begin working normally. What constitutes a 'bad' clutch pack and , assuming normal C solenoid function, what would the symptoms be? thanx
Setright is correct as far as the engine not being at risk. However, you really need to get this investigated. A simple adjustment now may save a coupla' hundred or more later. If the clutcth material IS actually worn away (quite likely at your mileage - and perfectly normal BTW) you will only get poorer gas mileage and destroy the flywheel, it may be damaged now. Really, have someone take a look ASAP. Soon, even engine braking will be reduced and you will only lose more and more 'driveability'.
