105
You still have diffs on each axle. When something is broken or wrong, you can get weird behavior. Subaru's sensitivity is why, when things are normal, the system works so well. But it can't 'know' the difference between a slipping wheel, or one that is rotating faster because it is undersized. And if something is broken - can't expect it to compensate for that.
Keep in mind that dealerships probably average $70-$80 an hour for labor. And they likely are charging a markup on parts. It's quite likely you could put on new rotors and pads yourself and not spend $100 (I just did this on the front of a Dodge Avenger for $45) Maybe you can find a buddy next time to walk you through it in exchange for a coupla beers. Or find an independent garage - they may have a labor rate $20-$30 less than the dealership.
I am gonna get one of those plate backing units from Autozone for my OBW. It looks like it will allow some vertical position options as well as stiffening the support of the plate. I am loathe to put a plate on my WRX however and may wait until the 'squeezers' suggest I do so. And when that happenes I may try to make a plate holder that uses the front tow hook recepticle.
IF she needs an auto, avoid the older ones. At some point the 4EAT got a steel sleev or something to upgrade a commonly failed aluminum part. Someone here will know when the switchover occured. Have you considered a Forester? (although it has yet to driven on anything other than pavement and some smooth turf - my wife likes her '03 H6 OBW)
Does this car have any of those bulbs with dual elements in them? maybe there is a brake light bulb with a broken element drooping onto a turn signal/parking light element causing some weirdness. Just a wag but that can cause some odd symptoms. When the shop tested your alt. I wonder if they have a way to do it under load or look for excessive ripple if a diode pack is bad? I dunno
We may never know unless more problems show up. I suppose, if the crankcase were overfilled initially, that an incline could cause 1 or 2 things, possibly in combination. (wild speculation mode ON> the shop overfilled the crankcase by maybe a liter or more(maybe the nozzle was set for a 3.0 H6), the incline caused the rear of the crank to beat the oil, sending oil and oil vapor through the PCV valve system and creating some misfiring in one or more cylinders as well as causing the catalytic converter some grief/smell. Possibly also causing some asynchrony between the crank and cam angle sensors. < END wild spec mode) I dunno
I ocasionally monitor 2 soob forums and a soob usenet group. PS is NOT a known weak point. I don't recall ever hearing about it being a problem. You're just unlucky. My friend's Toyota Highlander blew its PS pump in west Texas - horrible time trying to find a dealership - then he had to wait on a part! sh ! t happens. good luck
