92 Legacy wagon overheating while idling
1 Lucky Texan replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to confirm the fan cycles in 15 minutes or less idling in the driveway. I'd suspect the fan or its controller or a partially clogged radiator - but do investigate it properly. good luck (good thinking on the heater fan too.) Carl
94 Legacy 2.2L Low Compression Drivers Side
1 Lucky Texan replied to skeeter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow old is the timing belt? maybe one cam slipped a tooth or 2 ? I forgot, does it idle? Try holding a slip of paper at the tailpipe, if it sucks back inside the exhaust during any part of the revolution, maybe slipped timing or leaking/broken valve. I got nothing. Carl
wheel vibration
1 Lucky Texan replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOld but not necessarily worn tires can exhibit vibration from partial tread seperation Plus you could have 2 problems at once I think I'd begin by rotating the tires and see if the noise and/or vibration travel with the tire Carl
EMERGENCY smoke and noise under hood
1 Lucky Texan replied to terryb52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould the sound have been more a sizzling or arcing sound? maybe you have a major electrical short? I dunno, but I vote with Setright, make CERTAIN the actual problem is diagnosed and corrected before leaving town Carl
1 Lucky Texan replied to terryb52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it smell like roasted marshmallows? kinda sweet? Did you get a cel or a high temp on the coolant gauge? Could the fan blades have gotten into the radiator somehow? Carl
1 Lucky Texan replied to skeeter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX205! seems like you'd need a compression ratio of 14:1 to read that. Maybe that side is carboned up? Also, I've always wondered how a wet compression test would work in a horizontal cyl. I gues it wicks up the control ring or something? Carl
Help Quick...
1 Lucky Texan replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet creative! is it in a spot where you could hacksaw out the offending part, use some short pieces of hose and hose clamps, and insert a 'T' of some kind? maybe something cut out of a junker at the yard? Some kinda copper plumbing fitting or something? Carl
WTB Stabilizer End Links for '96 OBW (FNT & RR)
1 Lucky Texan replied to mal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoupla ideas, folks frequently upgrade those itmes with aftermarket - less on the Legacy models than the Imprezas but still....- you might ask the marketplace forum here and over at www.nasioc.com for some take-offs. One of the nicer mailroder dealers is www.subarugenuineparts.com - ask/email Jamie and confirm they can ship to the great white north. Carl
Help Quick...
1 Lucky Texan replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou didn't mention if the gauge showed an overheating condition - which could point to the overflow bottle being the source of the coolant. Yeah, you need to do some detective work. Off the top od my head, check the radiator cap (especially if its the original!), check that hor air actually come from vents if heater is on, the rad fan function when operating temp is acheived. Collapsed hoses when circulation starts. Bubbles in radiator when circul;ation starts, white vapor in exhaust, one plug with distinctly different appearance then the other 4.... depends on where these things lead you. oh, of course the trouble code from the ECU (I dunno how the initiate that on you car - someone else here will.) good luck
grease fittings
1 Lucky Texan replied to soldthe4d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe it's just a bushing on the sway bar or something - see if you can creaet the sound bouncing the corners of the car. carl
Help TURBOING a 2.2 liter outback
1 Lucky Texan replied to L67cooled's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome engine specs; http://www.ravensblade-impreza.com/techdocs/enginespecs/enginespecs.html
N/A 2.2L mods?
1 Lucky Texan replied to renyo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake a look at the Stromung dual tip muffler (axelback) they have at boxer4racing . I tried to do as much reading/research as humanly possible and have one of those on order. My goal was a sportier sound, not high pitched whiney, not so loud as to get the attention of the squeezers (young folks call them the po-po I believe) or drone tto much on the highway. My WRX wagon has not arrived yet but that is the muffler going on it. There are FAQs over at http://www.nasioc.com by a guy called Unabomber that will help with exhaust questions. That forum also has a lot of modders and tuners and is a good resource - just a little more, um, wild than this forum - not less helpful but has more knuckleheads/trolls. Try searching around over there for some ideas about beefing up your car. here are some other sites you might like; http://www.ravensblade-impreza.com/ http://subydude.com/osc/index.php?cPath=143 http://www.subarureview.com/ Carl
E85 Fuel?
1 Lucky Texan replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI doubt E85 will be more than a blip in the search for 'alternative' fuels. abusive to internal componenets in many vehicles and reduced mileage make it a real oddball. I'd ignore it. Carl
1 Lucky Texan replied to L67cooled's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think the 2.2 NA has the oil squirters for the underside of the pistons. Turboing without doing some internals could reduce the lifespan. A swap IS probably the best way to go. Carl
N/A 2.2L mods?
1 Lucky Texan replied to renyo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLighter wheels and (if manual tranny) lighter flywheel(not less tha 13-15 lbs or so) will free up a few ponies. If it's an auto, MAYBE (very controverisal) a few ponies can be freed up with lightened(no under-driven) crank and accesorry pulleys. If your manual calls for premium gas - stay with it, if you switch back and forth, likely the ECU will not re-advance the timing without being reset. As said, personally speking with Dale at http://www.boxer4racing.com will get you a sway bar that will fit. Again, lighter wheels and better tires and maybe dialing in some more front camber will improve handling too. Jamie (http://www.subiegal.com) who works at http://www.subarugenuineparts.com likes the bar from IPD . I dunno if they offer one for your car though. Cusco, Eibach others offer them too. It's unlikely you could get more than 10-15% more hp with bolt ons for your engine. Probably about the same as running with only a third of a tank of gas and removing the passenger seat! Carl
Sand in my tranny?
1 Lucky Texan replied to SubDave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a little disappointing to read as I think, from what I've read - no personal experience, soobs ahve a good reputation for swimming through sand - I guess because they are lighter than some other 4-bys. was your car loaded with heavy stuff? I dunno - just ignore me! lol! Carl
Sand in my tranny?
1 Lucky Texan replied to SubDave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas your clutch slipping? Did the car feel like it was 'pulling' at all? very strange Carl
'97 OB Speedometer Death/Loss of Power/2 Error Codes
1 Lucky Texan replied to rideabmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould this something as simple as a bad/corroded ground or electrical connection somewhere? I dunno, but I would definietly pursue the IAC issue first. The speedometer is the least useful gauge on the instrument panel! (yeah, I know the vss also feeds the computer.) Carl
i thought they were ugly?!...
1 Lucky Texan replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your driving a WRX correctly, the appearance of the rear is more important! Carl
Check engine light & reading codes, again!!!!!!!!!
1 Lucky Texan replied to subaru20gl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless you can locate a friendly mechanic to read them for you, wyou will need a 'scanner'. here is a link to one example; http://www.troublecodes.net/articles/equus/Equuis_OBD_II_code_reader.shtml Carl
Feeling bad
hmmm, I dunno now, maybe some kind of fuel starvation? fuel filter clogged or weak pump or bad fuel regulator? If it is in neutral, will it rev to redline? Does it idle smoothly? Does it only happen if its cold? Or if it is rainy or misty? Has anyone tried to get codes from the ECU? Have any sensors or parts been replaced to try to fix it? We need a few more specifics. Carl
Feeling bad
wow! um - (caution! wild guesses ahead) I'd check for a slipped timing belt or a clogged catalytic converter. very odd Carl
Looking At Subaru
1 Lucky Texan replied to forester01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have not owned as many or been an owner as long as most folks here. But from reading the fourms, I would likely avoid all 4EAT trannys before whatever (sorry - anyone recall???) year they got the steel sleeve in the tailshaft. Additionally, I'd be cautious about how the 4EAT was treated by the prevoius owner - did they understand their AWD system and not abuse it with mixed size tires,etc. Imprezas with rear wheel bearing probelsm are a minor annoyance. Oil leaks from various places. Some ticking timing belt tensioners. A coupla years of sensitive knock sensors, a recent 1-2 years of cold weather fuel leaks.(TSB or recall on this IIRC) Of course the internal leaking head gasket problem. Not much else comes to mind. Carl
Anyone ever Polish a windshield?
1 Lucky Texan replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd expect it would work well for 'haze'. That's usually the biggest issue with visibilty anyway. Likely a cerium oxide polishing agent. It would be hard to screw anyting up with it. If you wanted to practice first, start on the passenger side low and bnear the post. Or get a winshield from the wrecking yard. Don't tlet the runoff harden or it could be difficult to remove. Also, I'd use filtered or distilled water, maybe with 1-2 drops of detergent as a wetting agent, and a new or recently well washed buff - keep it covered up so as not to get contaminated with a dust particle or dirt. Don't do this on a gravel driveway during windy conditions! Carl
Rear Brakes on 98 Forester
1 Lucky Texan replied to zonk3939's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile there can be a little noise for the first few stops while the pads 'wear in' ,if you've never done a brake job before, I can see where it would be easy to throw the shims/plates away accidently. Everything's the same color and those shims are stuck on sometimes with the anti'rattle grease/stuff so it isn't obvious it's a seperate component. I dunno about a metallic screeching - more like squealing. Still, quite likely. Carl
