New Subarus and Problems!!!!
1 Lucky Texan replied to Capri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, its like, as long as the airbags are intact,ECU and tranny and engine OK, keep the car no matter what. Airbags are, like, $800 each! My new Soob has 4 of 'em!
1999 Subaru Outback Wagon-ringing rear wheel-STUMPED!
1 Lucky Texan replied to sunking247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFascinating. If you want to fool around with it, instead of taking it to a different mechanic, the first thing I'd try is swapping LR, RR rotors. (I'd of course inspect them and the backing plates). See if the problem either goes away, stays on the right (possible wheel bearing issue) or travels with the rotor (then what?). My bet is on wheel bearing but a ringing noise does seem odd. I suppose a whistling noise could be a torn grease boot or something. I dunno
Bird bomb/ cleaning recommendations
1 Lucky Texan replied to Zephyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a little vinegar - or the vinegar windex as suggested above.
Brake Indicator Light-What does it mean?
I think they were refering to the 'diode trio' inside the alt. I HAVE seen one car (an Oldsmobile we had)that the alt light was on VERY dimly and it was the alt that was bad. But other cars, it was some general weirdness as already mentioned that ended up being caused by a bad alt. Maybe instead of a voltmeter there needs to be a 'ripple' detector to let us know when the alt diodes go bad. I dunno
My daughter's Nissan does it too. Most likely to happen after an unusually cool night if the fluid level is marginal. Could this also be an indication the brake fluid needs to be flushed out/replaced? maybe too much moisture in the system makes it contract more? i dunno
odd timing belt question
1 Lucky Texan replied to chilly b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible to inspect it? Perhaps the shop used a non-Subaru part that is marked differently? (any indication of that on the repair history for the other parts?) Is there any mention in the labor side of the ticket of TB replacement? Is there a numerical amount recorded that is approx. the right price for a TB with a blank or duplicate part description next to it? too bad, but yeah, you may need to change it to be safe. Think of it as karma for the mistaken price reduction! lol! Carl
Sudden Squealing from Right Front
1 Lucky Texan replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you're fixed up! I sometimes get sudden squealing from the front right seat if my wife doesn't like the way I take clover-leafs!
RPM and MPG
1 Lucky Texan replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess Bill Gates needs hyper-drive! or does this mean I can break the sound barrier if I quit my job? (actually, you'd hear my WIFE's sonic boom if I quit my job!)
RPM and MPG
1 Lucky Texan replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the case a of a hurricane, I'd say the potential for damage is MORE than the square increase in force due to increased mass of flying debris!
2005 Forester driver seat back too short
1 Lucky Texan replied to trnmd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome soobs have a seat base adjustment/thigh support. I'm not familiar with the Forester and I'm sure you know your car - but just in case, make sure another driver hasn't mis adjusted the control if your car is so equipped. just a suggestion
1 Lucky Texan replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossibly a piece of gravel between the backing plate and the rotor. But, to be safe, a knowledgable person should inspect the brakes.
So many Questions...
1 Lucky Texan replied to johnnyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight actually be easier and just as much fun to make a sand rail or dune buggy. Soobs are light and with the right tires can swim up dunes that other 4-bys have trouble with.
I have a new Subaru and you don't!
Yeah, I agree, most photos are taken from a low angle that sorta exagerates it. I'm not convinced its a winning look for Subaru - but there are worse vehicles out there. I'm kinda a 'form follows function' guy personally, though I appreciate aesthetic elegance. Not sure Subaru ever achieved that. Some cars I would have kept longer, but you sometimes have to make sacrifices for family reasons. Didn't make sense to keep the Datsun SRL 311 at the time I sold - but I wish i could've kept it. Technically, my wife's Sube is my first, though we probably split the miles put on it between us. It's unlikely my WRX will be driven by anyone else except in an emergency - so yeah, it's as much my car as a car could be. Looking forward to enjoying it for a long time.
2004 Forestor XT Turbo
What was the conclusion? Carl
If I understand how the ECU and knock sensor work - that technique would be worse than just switching to mid-grade. There will be several start cycles where you've paid for for the hi-grade but the ECU has not changed the map back to advanced timing. Plus, there is 'some' eveidence that not running hi-grade gas is a false economy due to poorer mileage with lo-grade.
Strong gas smell after starting?
1 Lucky Texan replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless there are other symptoms like carbon deposits on plugs or noticeably poorer gas mileage - maybe it's just the vapor recovery system? A cracked plastic connector or purge valve issue? just a wag.
I understand the concerns in this issue - and it's possible I could get into a heated argument someday, but it's fairly well known that you can change you own oil or have other service done outside the dealer network and still get warranty service. The dealer doesn't want scrutiny from SOA over a bunch of illegitimate claims, but they don't want to scare away a future customer or source of sales referals. There ARE folks that will chip their car, swap out up pipes, install NOS, blow it up, swap all the mods back out for stock, and go back the the dealer for a new transmission. I hate that. But Subaru used to give away SCCA memberships with new cars - and now they even sell a car THEY call 'tuner ready'. I doubt a muffler, a boost gauge or some wheels would be a big issue. I could be wrong and I really don't like confrontations. But maybe I won't have to find out the hard way! Carl
1 Lucky Texan replied to johnnyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've read that tires for snow (I guess snow on pavement) should ideally be narrower than stock - certainly not wider. But off road I'd expect you want a serious lift and/or rolled fenders to accomodate very large tires. Then again, less offset in the rims will stress the bearings. Again, not an issue with a 'beater'. getting a dual range tranny from overseas or something would be a huge blessing but others may know if thats do-able. sounds like you're planning a fun project! Carl
I live at Green Oaks and I20 (on the poor side of Perkins) . Work near the stadi - the Ballpar - Ameriq - whatever! lol! You in a sedan or wagon? Carl
Thanx. Although I do have history of more short term than longterm ownership of vehicles, I suspect this one will be with me a long time - more like my '81 Civic Wagon was - 16 years. And I only dumped it when my Mom couldn't drive her Avenger anymore. Carl'
Yeah, it seems to be the engine and drivetrain from the Forester as near as I can tell. maybe different final drive ratio or something. I only repeat wjat I've read as the only other soob we have is the wife's '03 OBW. I suppose that vehicle caused me to wast..uh....INVEST too much time in online soob forums - which led to catching the 'fever', and I finally had the means to treat myself. So, many of the arguments about how ugly the new nose was, etc. just didn't matter to me. I can see how, if I already owned an '02-'03,etc. that I was happy with, well, yeah probably not worth trading in. But it was kinda no brainer for me. Biggest issues were stick or slush and what color. It only has 30 miles on it right now but, no problems yet! Carl
Well, you may be right. But I doubt they'd fight too hard to not replace the CD player if it went out after I installed a muffler. Or replace a seized A/C compressor after I put aftermarket wheels on. I guess we'll see.
2.0 & 2.2 Diesel Boxers For Europe Next Year
1 Lucky Texan replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince I was a kid I always thought it would be cool if a car engine could be designed that would be cooled, lubricated and fueled by the same liquid. Might require a catalyst and some exotic engine materials but it seems like we may be close to it now. Carl
I want my thermometer to read in °C not °F!!
hah! Maybe its 135 after its warmed up!
1 Lucky Texan replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAdditionally, likely Toyota is losing money on each Prius. My bil and my fil/mil have Prii. My bil's just went to the shop with a problem they said couldn't happen without warning - the 308v battery pack is completely dead. Requires a 'special tool' to recharge when in that condition. Seems there is only one of these devoces for every muti-state area and his car had to wait a coupla days for shipping the thing into D/FW area. Got his car back Monday morning. Dead again Monday night. haven't heard what the new diagnoses is. 80k miles on the clock. the inlaws love their prius and I had some pressure to get one instead of my WRX wagon. I'm happy with my new soob. So far.
