105
	Maybe someone remembers the specifics, but I have a vague memory of there being a TSB or recall for knock sensors. I just can't remember the year/model. And I think it was because they were too sensitive. Do the plugs look good? if you had a carbon buildup a seafoam or other treatment may clear som out. Carl
	When everything is working (no failed devices) slip is detected and the pulse train sent to the duty solenoid C is altered to help distribute power to the front or rear of the car away from the slippage. If 12 Volts continuous is supplied to the solenoid (by putting in the fuse in the proper slot under the hood) the system becomes front wheel drive. I suppose removing voltage from the solenoid or if it were 'bad' (open) would give you 4WD all the time - UNLESS the wet clutch pack were bad in the tailshaft of the tranny. Assuming your rear diff isn't blown or some odd part of the rear drive line were missing - I'd say the clutch pack is burnt up. Carl
	If you are new to Soobs PLEASE search here for coolant flushing/filling posts - it can be a little trickier to refill soobs confidently. I think Setright has a good procedure outlined somwhere. basically, you have to fill in 1-2 certain ways and burp the system multiple times to assure no entrapped air. Carl
	Wow! I hope someone chimes in on this. I got nothing solid - but I THINK the ECU compares the front O2 to the post cat O2 but how it decides one versus the other I'm not sure - so perhaps the cat is bad or the rear O2 is bad and the ECU is mis-reporting/fooled. I would expect the fron one to go bad first. Do you know the history of this car? Has it ever run rich for extended period? Already had any sensors replaced? Any recent work done? Any signs of rust/corrosion in the engine bay? Any weird dimming of lights? How have you been reading and clearing the O2 code? A clogged cat can rob power but I've never read of one surging like you explain. If you're not getting any cylinder misfire codes, it would seem to be a fuel/air issue or a sensor intermittent - not high voltage related.. Maybe TPS, MAF - I got nothing but guesses. Carl
	No - no. With car parked, lower the driver's side window completely. Using one hand on the tweeter area inside the car, and the other directly outside on the mirror housing/whatever, push together. This should tighten the 'slot' the window rides up into. This MAY fix the noise. Try not to close the door pushing on the window, reach down and push on the metal. If that doesn't do it, try putting 2-3-4 inches of masking tape (at a time) in different areas and test drive to locate where the noise is coming from. Carl
	I';d suspect the rear brakes you could do yourself for maybe half that with NEW rotors. I might be wrong. On some vehicles (I haven't looked at my wife's OBW alternator) there can be a lot of diassembly to get to the alternator. Sometimes it's quite easy. Even diassembly is just extra time. I admit I farm out some jobs I could do myself if I could create the time or had a better set of tools maybe. Sorta pick and choose - some things I do, some jobs go to an indie mech at $52.50/hr, some to the dealership at -what - maybe $80/hr? You can also find some good tutorials with pics on-line. http://www.ravensblade-impreza.com/modifications/brakes/rotors/rotors.html I also just bought some parts from Jamie at www.subarugenuineparts.com did my own cabin air filter swap and threw in an intake filter. Took a soob oil filter and crush washer and 6 qts. of Mobil 1 to the indie mech - changed the oil for $10 while I waited. Carl
	Eibach, whiteline and others have springs that may not be too much stiffer than stock. You probably don't want much lowering either or you may be operating the new shocks outside of their designed 'sweetspot'. It doesn't show the lowering (which you might be able to fix anyway with some type of shim?) amount but this site; http://www.ravensblade-impreza.com/techdocs/spring/spring.html shows the stiffness. Carl
	Yeah, my very first thought was a voltmeter - then I thought an ammeter would be better but didn't know if they existed. Seems like here in Texas - a battery does well to last 3 years and some idea of when it was getting weak might be useful - dunno if ALL failure modes would show themselves but maybe overcharging would show itself? I dunno. Another thing I've always felt was odd is when folks want to measure something but then have now way to make a change or do nothing with the information. I suppose I can see where a boost gauge or a vacuum gauge would be useful for controlling the lead foot. And might also point out probelms developing - what? I dunno. And is there really any useful reaction to - say - oil temp?(is it just a redundant coolant temp indicator?) this could be an educational thread for me - keep 'em coming! Carl
	I haven't decided if I even want to add any gauges but I do intend to keep my new car ('06 WRX wagon) as long as reasonably possible. Given that, I wonder what gauges you guys feel would be most beneficial. probably many of us have been in the position of noticing some slight difference in a gauge and been able to ward off a serious problem. last winter I noticed a slightly lower position on the temp gauge of my Avenger and replaced the thermostat - it was stuck open. I probably saved myself a few bucks in gas as the mileage would likely have suffered eventually - or who knows - maybe some carbon/sludge would have developed. So, given that nowadays the ECU measures a lot of stuff and an OBDII reader may be enough, I wonder what gauges you guys feel would be helpful to monitor in the long run? Carl
	In addition to a few sports parts sold through the dealerships (try jamie at www.subarugenuineparts.com - she also races! www.subiegal.com i think) there are many places for parts and info for modding/tuning. You could learn a LOT by using the search engines and reading for hours bith here and over at www.nasioc.com . I just ordered a muffler from www.boxer4racing.com for my WRX that hasn't even been delivered to the dealer yet! a good place to start shopping for tires wheels might be www.tirerack.com . www.scoobymods.com would be fun to poke around in. http://www.kastleskorner.com/store/index.php has been around a long time. Most of the forums have links to vendors. have fun! Carl
	You're right of course - it will have some effect. I think , in most normal driving, shifting slowly and carefully should allow the rpms to drop and the synchronizers to do their jobs well. The clutch is a wear item and I think Subaru engines are fairly tough under a wide range of driving conditions. I'm not trying to fault anyone elses driving style. Just pointing out that 'babying' an engine can be counterintuitive to what is actually 'easy' for it. Also, I tend to sacrifice my brakes when decelerating - instead of engine braking. That's not to say, as I'm slowing I don't select the correct gear if an emergency maneuver should call for me to move quickly, I just use the brakes a lot. So , maybe, I'm robbing Peter to pay Paul. Of course, heel-toe and other techniques would be required for racing (techniques I probably should practice) but - ahh - I guess I just take the lazy way out! hah!
	Assuming you're car is past the 'break in' period (please - no arguments over that - do asearch for those discussions) I see NO reason not to regularly go to or a little past the peak torque point when driving(say - 4500 rpm or so). Lugging an engine causes more local heat buildup and excessive pressure. I don't think ALL driving situations call for going to redline - but I would never feel redline needed to be avoided either.
	Is it auto or manual? Do you have the owners manual? (if not call jamie at www.subarugenuineparts.com ) The 4eat autotrannies have a fuse box under the hood. There is an empty position there that you put a spare fuse (15amp IIRC) into to disable AWD (FWD only) but it really isn't designed for long term use. maybe days-weeks would be OK, a year is probably not gonna be OK. It supplies a constant 12V to the duty soenoid 'C' which is normally getting pulses.(again IIRC) as said, the mods for the 2.2 are more like, reducing wheel, pulley or flywheel weight, or intake/exhasut mods. Some of these will shift torque curves while adding a few ponies but it is gonna be difficult to get more than about 10-12% more hp without doing some changes internally. Or an engine swap for a turbo'ed plant. lots of tuners over at www.nasioc.com I'd suggest lighter wheels and maybe some other suspension mods to increase the fun factor - forget about drag racing (except in the rain where you will OWN the other cars!) Carl
	I personally have learned a LOT of good information by posting what I thought was right! lol! Trust me, sometimes on the 'net , folks will keep quiet - UNTIL questionable information is posted - THEN come the links, videos, notarized references, government experts, eyewitness accounts, etc. to the way it really is! In fact, instead of asking how much the stock wheels weigh on an '06 WRX - I shoulda posted that I weighed one and it was 30lbs. THEN someone would call me an idiot and post the actual weight. hah! I'm gonna try that over at nasioc right now! Carl
	How much can you spend? First thing is make sure you buy premium gas (is that the recommended grade for your car?) Better performance and usually better mileage - 2 for 1 at just pennies a gallon difference! Next , you will get more 'zippy' acceleration with undersized tires. Of corse, the engine will be revving higher, mileage would likely suffer, and you speedometer/odometer will be off. Oh, and any warranty left might be voided.(this MAY be true for any cold air intake/oiled filter too - depnds) you could try never filling the tank - leave it at 1/2 even 1/3 .Rule of thumb says 1hp equals something between 8-11 lbs. of weight in the car. If you have around $600-$800, lighter wheels will free up a few ponies, maybe look better (bling!) and perhaps improve handling/ride. Lastly, don't be afraid to get the revs up - torque doesn't start making it's appearance till around 3800-4000 rpm I think on your car. It's actually good for the engine as it runs a little cooler and there is a little less stress at higher rpms. Get a sporty muffler, it'll SOUND faster! Drive with all the windows down - it'll FEEL faster! lol!
