105
Thank's Ido, I should keep-up better with this stuff. I bet they paid a lot and now haven't got any relief. Ashmason, you probably have a warranty if this shop has decent reviews and seems legit, take the car back and tell them it isn't fixed. Give them a chance to make it right. But, you may have to bail-out on them if they seem uninterested or incapable of diagnosing the car.
it's a manual? didn't know that was available in Tribeca if so, typical failure symptom for manual's center diff viscous unit is to work OK when stone cold, then grab when warmed-up. a Colorado shop should know this so....I may be wrong. Either get the car up to retroroo in Denver and let Shawn check it out or, one idea, contact user 'traildogck' over at subaruoutback.org - he even does mobile repairs and casts his own line of bushings! Might come down to Pueblo for you....
no sign of brake fluid dripping anywhere? does kinda seem like master cylinder could be at fault - very old car, sitting unused for a long time....add full travel pedal excursions and I could see the MC seals being bad.
a rare condition can occur whereby the bottom of the overflow tube 'seals' itself to the bottom of the o'flow tank. many folks cut the bottom of the tube at a 45* angle. If the tank has debris in the bottom, one way to clean it is with ice cubes, remove it, fit some ice cubes in it and shake them around. make sure the little o'flow tube is clear. The rad cap has a valve 'should' allow one-way flow from the tank back into the radiator - it may be bad which is why we jumped on that first.
If it has only leaked it's fluid and seems otherwise solid, I'd keep driving. I did replace them (sorta twice) on our 03 - if it helps, here's a link to the old thread; (pictures sadly gone - unless there's an image shack hack available for your browser) https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
It can be tricky to burp all the air out of a recently drained/filled soob cooling system. did you replace the thermostat? it MUST be OEM-style (see pic below) jiggle pin at 12 o'clock. get nose of car up on ramps/curb, squeeze hoses, confirm the rad is full with a good rad cap and the overflow tank is at proper level or a little above. Run car till fans come on, rev the car to get good flow, let it cool for hours, check that rad is full, top-off overflow, run again till fans come on, let it cool. Re-check overflow. The system 'should, be able to purge a small amount of air this way. If it still overheats, there is a problem. When the gauge maxed-out, was coolant pushed out of the overflow?
well, belt needs to come off, leave the crank where it is, but re-position the cams , re-install the belt. on my WRX, the DS intake cam REALLY wants to flip - it can be tricky and some folks have tried to use document clips and visegrip pliers, etc. to keep things in line. there are several videos that give some pointers, here's one;
more info on engine would help. if you pulled the pin on the tensioner, re-compress it VERY slowly or seals inside can be damaged. search on-line for pics of the front of your engine type for alignment details, maybe a youtube video even. search also for the tooth count. After alignment and pulling the tensioner pin, rotate the crank sprocket with a wrench 2 times to bring the marks back around - do a tooth count to triple check before starting the car.
When the ECU is reset, the car is reverted back to a stock ROM 'map' of settings - ignoring the sensors until after a coupla 'drive cycles' and the montors are complete. That is, the computer has not learned anything from the sensors and starts with a 'locked in' A:F setting and 'typical' ignition advance. If there's little/no difference in how the car runs after a reset, I doubt you have a bad sensor. I think you should perhaps look for vacuum leaks, cap/o-ring issue on fuel pump, dropped valve guide or burned valve, transmission problem ,etc.
440, very possible hole in fuel filler pipe (behind the plastic) or destroyed seal on gas cap on a '98, you can probably ignore the 136 for now (post cat o2 sensor) 1510/16 point to IACV, some folks have had luck cleaning it - some needed to clean it again, others have found bad wiring/connectoer - some need to replace it. 106, intake manifold pressure - saw one post that indicated a small vacuum line was loose? If you have a smartphone, Torqu app and a cheap bluetooth adapter can get you live data - check amazon for bafx or veepeak ELM327 BT adapter
maybe look up - frankenmotor ;
yes, many dealerships will try to brow-beat owners into an 'accelerated' maintenance schedule. They just do it for $$$ reasons. Insist on following the schedule in the manual (which, you can have done by anyone, including yourself or independent shop) UNLESS the car actually is used in an 'extreme duty' manner.
generally, swaps are doable but are EXTREMELY involved. you can, however, make changes to the suspension and braking of your current car that will make it more fun to throw around the corners. Refresh the struts, heavier rear sway bar or even stiffer springs, sportier exhaust, lighter weight rims...
