January 26, 201016 yr Are all ea 82 seats interchangeable? How about early legacies, foresters, etc? Edited January 26, 201016 yr by pierman2
January 26, 201016 yr from what i recall EA82 seats are interchangeable. most EJ stuff is interchangeable, though there are some variations through the years. are you talking between EA82 or wanting to swap from EA82 to EJ? EJ stuff usually doesn't bolt right in to an EA82 but can be made to work. some EJ stuff will make you sit a good bit higher in the car if you fit them into an EA82. haven't spent much time in other EA stuff but in an XT it gets tight if you're tall.
January 26, 201016 yr Yeah - EJ seats will sit you higher when put into EA vehicles. Plus they require welding and other modifications to bolt up. EA82 seats are interchageable - sometimes you do have to swap the rails around as when putting Loyale seats (auto belts) into older GL's. GD
January 26, 201016 yr I'm thinking about swapping bases from my '08 FXT seats into my '91 Loyale. All I know at this point is that the FXT seats definitely do not bolt in to the Loyale.
March 18, 201016 yr subscribed... i have a GL10 EA82 86 and really need something done with the drivers seat. hoping that i can find another one around.
March 20, 201016 yr Plus they require welding and other modifications to bolt up. No, they don't. Edited March 20, 201016 yr by Redcap
March 21, 201016 yr Just drilling and cutting and bolting if you don't have a welder. More things to watch loosen as you drive. I'm sitting in outback seats in my 82'. They are too big by the way and barely slide forward or back due to friction.
March 21, 201016 yr Just drilling and cutting and bolting if you don't have a welder. More things to watch loosen as you drive. I'm sitting in outback seats in my 82'. They are too big by the way and barely slide forward or back due to friction. Nylocks. The driver's seat in my red wagon is a Legacy seat. Took about 30 minutes of my time to prepare and mount it to the EA82 seat bracket, including threading the spacer, the mounts on the Legacy seat and drinking a couple beers. Just drilling, no welding or cutting required.
March 15, 201115 yr Does anyone have any pics of their subies with different seats in them. I replaced my wrx seats with sti limited seats so I want to put my wrx seats in my xt
September 20, 201114 yr I swapped my old seats on 86 GL hatch with newer (i think 04 wrx) seats which i find the most comfortable, even better than sti ones (i like them for removable headrests) bought them from wrecker for $180 and actually bought both passenger's side because they are usually in much better shape spent couple of days making bases and fitting the rails but quite satisfied with the results. can't wait for the next rally oh eah, and while on it i also made a hub from my old steering wheel and bolted Momo on it =o) Edited September 20, 201114 yr by alexinvancouver
September 20, 201114 yr I swapped my old seats on 86 GL hatch with newer (i think 04 wrx) seatswhich i find the most comfortable, even better than sti ones (i like them for removable headrests) bought them from wrecker for $180 and actually bought both passenger's side because they are usually in much better shape spent couple of days making bases and fitting the rails but quite satisfied with the results. can't wait for the next rally Oh man those seats look Shnazzy:slobber: +1 i am also wondering if seats out of an older GL or XT will bolt right in to my 90 loyale? cheers all!
September 20, 201114 yr i don't know if there's a direct fit but i'm sure one can make any seat fit as long as it's not overly wide for this seat swap i had to manufacture base and weld it to the new seats and then just bolted sliders to it. once i was driving my daughter's acura rsx and i though " man, these are the most comfortable seats"! and i was gonna buy those and make them fit. but decided to stick to OEM Subaru's parts so, why don't You just unbolt one of Your seats (it'll take couple of minutes anyway) and try what ever You like and go from there but i'd recommend to go with seats as newer as possible. BECAUSE IT'S YOUR back and butt man! Oh man those seats look Shnazzy:slobber: +1 i am also wondering if seats out of an older GL or XT will bolt right in to my 90 loyale? cheers all! Edited September 20, 201114 yr by alexinvancouver
September 21, 201114 yr I put early Legacy seats in my 86 Brat, no pics of it. Put 90's Mitsubishi Eclipse seats in my 85 Brat. I had XT6 seats in my RX, but they were to stiff, so I found another pair of Mitsu Eclipse seats.
September 21, 201114 yr those are nice i like it when headrests are actually made for ... head to rest
September 21, 201114 yr I am thinking about throwing some Outback seats into the Brat eventually, but at the moment I am wanting some Subaru floormats like Alex has. Would love a Subaru logo seatcover as well but am having no luck.. Emailed Subaru themselves and they said they dont have any. Told them I wanted to put the new logo seatcovers on a Outback or Baja, implying I wanted to buy a new vehicle and they told me not to put seatcovers on them, some nonsense about the airbags...
