So. California EA82 Wheeler
Ohh! I wanna join you in march!
I'm gonna need a lift;)
-Garrett
  • Replies 480
  • Views 123.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • moar pictars! ttiwwop
  • JacksonRally
    JacksonRally
    My only major gripe about this car is the fact that there is no cup holders So I'm gonna make some.
  • actually, you are supposed to use your right hand, cupped perfectly over the bottom of the can......it allows the bottom of the can to sit right on the shifter ...voile' no cup holder:grin:   but se
Messed with the car a little today. I got the 2001 heater controls mounted in the dash.
I am planning on putting 4wd hi and lo indicator lights just above the heater controls. However those are not priority right now.
If you get out towards Durango, let me know.
Drop me a note if you come through Moab too, of coarse! ;)
:headbang:
:headbang:
Of course! But I think Utah and Colorado are a little much for the maiden voyage. We are just going to find a route from my house in Sage to Laughlin NV and maybe Mojave Road. Depending on what exactly we do the Mojave Road will take 2 days and we are going to be in Laughlin for 2 days or so.
Made some good progress lately. Its dark out so pics will have to wait til tomorrow.
-mounted guage cluster
-made super plenum/ducting for heater to heater vents in dash
-radiator mounting done
-a/c condensor mounting done
Placed order for some firewall boot/grommets, heater hose and a radiator cap. I also ordered some pre-bent 2.25'' u bends, 2.25'' straight tubing and 1.625'' for mods to the factory exhaust manifold. I will keep the factory cats but relocate them for a touch more clearance. Cat back will be 2.25'' :cool:
Edited by JacksonRally
I can't wait to see this monster done! And I'm sure you will have an insaine amount of articulation for a subaru...:)
-garrett
word!
just sayin' ;)
keep in touch :headbang:
-mark-
Took some pictures today :clap:
First is the guage cluster. Its mounted and functional, later I will make some filler pieces to clean it up a bit but right now I just need it mounted.
Now onto the super vent plenum. I still need to connect a hose to the far right of the dash, but that vent does not even exist right now.
Here is the radiator
Lower condensor mount
Radiator and condensor together
And I made up some power steering lines today. I also re-O-ringed the power steering reservoir.
i like your cv boot clamps
Safety wire is the only way to fly. I do that on all of my cars including the rally car. Its cheap, it works and always the right size.
Temps should be close to 70 today. Im hoping to paint the raw metal on the front of the car and assemble what I can.
that is awesome. NO sarcasm...ima start doing that now, my tool is a worthless pos, and i have oodles of wire. thank you:grin:
I love that cluster in there. Great work. Every time I see an update on this I start drooling.
Thank you. Its a ton of work. I cant wait to be up and running again.
Welp, I think everything under the hood is done :clap: Still not ready to fire because I have to make the exhaust. Other bottom side duties include oil pan skid plate and adapt my old aluminum skid to clear oil pan. I still have to tap the tie rods on the wrx rack for a few more threads. There are still a few other things to do but thats one of those lists that never ends.
Crap, forgot to mention the factory headlights no longer fit due to the larger a/c condensor.
Solution to come soon :cool:
Can't wait to see the headlight design. Maybe some shallow Hella 500 ff's?
I believe the speed sensor that works with your harness and plugs into the transmission where the cable used to go in will be putting out the wrong pulse frequency. Let me know and I can build a pulse matching circuit for it. I've already tested such a thing.
My next project will be a front end rebuild with many modifications like extended radius rods, slight camber modification, etc... a lot like the ones here http://www.ultimatesubaru.org/forum/showthread.php?t=136259
Good guess on the Hella's, thats what I am going to run.
Now why would the speed sensor (still need one) be wrong? 01 harness, 01 sensor, 01 guage cluster
I was all ready to paint the new stuff the other day and realized I didnt have a hood latch any more. So I put off the paint a few hours and figured out how to mount the factory latch. It seems to work a little better than before :cool:
All painted
And a few shots of the engine bay. The intake (free) is temporary til I fashion it into a snorkel.
Very nice hood latch, radiator & condenser mount setup you got there! What will you do for vitals protection? Expanded metal for the grill?
Or go for the 'Road Warrior' grill - many 1/4 x 1" horizontal steel flat stock bars on edge? ;) Just kidding of course.
Its the right sender. I mean it won't show accurate speed because of the different final drive and the larger tires.
Awesome work,
Curious as to why you pushed the firewall foward on the spare tire area tho
